Any value in a "junk" case?
ncstagger
ncstagger is offline
PostPosted: Sat Mar 16, 2013 1:33 pm    Post subject: Any value in a "junk" case? Reply with quote
I have an AS41 case with a hole in the top where a rod busted through.
After stripping everything off/out of it I was wondering if anybody wanted it or does it have any use to anyone? I can't think of anything it would be good for but I seem to be having a real hard time throwing away any VW parts so thought I would ask.
71 Westy Tintop - 1600 DP 34PICT3/009 - Pastel White
Resto thread here: http://www.thesamba.com/vw/forum/viewtopic.php?t=549162
"Take your most realistic time frame and dollar amount.. then add half of that amount. When you get that total... double it. Only then will you be in the ballpark." - sofaking
williamM
williamM is offline
PostPosted: Sat Mar 16, 2013 2:11 pm    Post subject: junk case Reply with quote
Some of the bigger meets have a "case burning" event where one is torched and fire trucks pour water on it- AND a good time is had by all.
I accidentally left one in a pile of cases going to the line borer and it came back cut to .80.
some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any!
[email protected]
Samba Peckerhead
PostPosted: Sat Mar 16, 2013 5:23 pm    Post subject: Reply with quote
if the pick up tube survived, it is worth saving as they are better than the pick up's in the new cases
gprudenciop wrote:
[email protected] wrote:
Jake Raby wrote:
Brian wrote:
SGKent Premium Member
SGKent is offline
PostPosted: Sat Mar 16, 2013 5:32 pm    Post subject: Re: Any value in a "junk" case? Reply with quote
scrap. If the case is busted, welding will warp the main webs if they aren't already from the heat when the rod failed.
"There are no great men, there are only great challenges that ordinary men are forced by circumstances to meet." - Adm William F. Halsey Jr
Caveat: I am not telling you what to, or what not to do. When a suggestion is offered, it is wishing you the best, and is based on my experiences as a mechanic, automotive machinist, and from racing in the era your bus came to life. My only goal is to share what has been learned on my path. Smile
1971 (sold)
1977
