Distributor advice needed
ncstagger
ncstagger is offline
PostPosted: Wed Mar 27, 2013 5:47 am    Post subject: Distributor advice needed Reply with quote
I'm currently running an 009 with a 34 PICT3 on a 71 AE 1600.
Ran across a 205Q DVDA which is the correct stock distributor for my bus and was having it rebuilt but have hit a snag. It is apparently missing an advance spring. The guy doing the rebuild says he could swap in a spring or even the whole adv mechanism out of a similar model. Is this a good idea?
I want to have either the correct DVDA or an SVDA as my primary distributor and keep the 009 as a backup. Was going to go for the SVDA 034 before I ran across the 205Q. Any advice is appreciated.
71 Westy Tintop - 1600 DP 34PICT3/009 - Pastel White
Resto thread here: http://www.thesamba.com/vw/forum/viewtopic.php?t=549162
"Take your most realistic time frame and dollar amount.. then add half of that amount. When you get that total... double it. Only then will you be in the ballpark." - sofaking
SGKent Premium Member
SGKent is offline
PostPosted: Wed Mar 27, 2013 6:26 am    Post subject: Reply with quote
wait for one that works. Keep the can if both sides are good. If it is missing a spring it has been apart before. There is no way he can match the curve it came with. Save the old one for parts. I like the idea of using the parts that it was designed with if you can find ones that all work. My old 1971 with the DVDA ran like a charm when it was tuned right. You can use the 009 until you find one.
George Carlin:
Skills@EuroCarsPlus:
ncstagger
PostPosted: Wed Mar 27, 2013 6:45 am    Post subject: Reply with quote
Sounds like solid advice, thanks.
busdaddy
busdaddy is offline
PostPosted: Wed Mar 27, 2013 7:47 am    Post subject: Reply with quote
Do some research in the distributor list on Oldvolks, some auto Cali bug distributors have very similar mechanical advance curves, with your vacuum can it is possible to build yourself a frankenstien facsimile.
Слава Україні!
ncstagger
PostPosted: Wed Mar 27, 2013 8:51 pm    Post subject: Reply with quote
Thanks BD. Looks like both 205D and 205AH have the same mech advance curve data listed as the 205Q. Does that mean the adv mechanisms interchange?
busdaddy
busdaddy is offline
PostPosted: Wed Mar 27, 2013 10:03 pm    Post subject: Reply with quote
Someone like Glenn would have better knowledge of that but IMO it's much closer than many of the other curves, like I said....frankendistributor that's really close Smile
Слава Україні!
Wildthings
Wildthings is offline
PostPosted: Wed Mar 27, 2013 11:54 pm    Post subject: Reply with quote
I have swapped parts between many Bosch distributors, they will typically interchange. You want to limit the amount of mechanical advance, no more the 20° is usually all you want.
