cefalu Samba Member
Joined: May 14, 2012 Posts: 135 Location: San Francisco Bay Area, CA
Posted: Tue Apr 16, 2013 4:08 pm Post subject: Hard starting solved (sort of)-Pertronix and Kadron carbs |
I have been frustrated with what I considered to be "cold blooded" Kadron carbs I recently bought from the Kaddie Shack. I though the problem was related to the fact Kadrons didn't have chokes.
At the same time I installed the carbs, I also installed an SVDA distributor with Pertronix points that came with the Kadrons.
The cranking time at start up seemed excessive, and oddly, the engine seemed to want to start when I stopped cranking the starter motor. It got me to thinking that maybe the electronic points were not getting enough voltage until the starter motor was released.
I hooked a hot jumper wire directly from the Battery + to the coil and gave it a try.
Boom! instant start and nice cold idle, just like my old Weber ICT's.
I don't know why I am getting such a voltage drop at the coil. My ignition switch is brand new too. Old age seems to take its toll.
I am thinking that maybe I will use the old ignition hot wire to activate a relay which can supply good battery voltage to the coil.
I also removed and replaced the old crimp connectors onto the coil wire connections in hopes a bad crimp was the culprit. I also swapped in another coil but it made no difference.
Any ideas as to why the low voltage? _________________ 1970 Jeepster Commando
1974 Volkswagen P27 Westfalia Camper
1974 Mercedes SL350 Euro Market Model
1974 Jeep J-20 ZZ
1985 Alfa Romeo GTV6
2005 Toyota 4Runner V8 Sport
2008 Mercedes E350 Wagon
2018 Lexus GX460 |
GusC2it Samba Member
Joined: June 23, 2005 Posts: 1376 Location: Orlando, Florida, USA
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16822 Location: State College, PA
Posted: Tue Apr 16, 2013 4:58 pm Post subject: |
Assuming that in addition to the connectors being replaced, you cleaned the tabs that they slid on to. I would look further upstream. Keep going backwards - like you have the conenction from the coil to I assume the switch. But what do you have on the other side of the switch? Weak voltage feeding it can still cause your issue. See what I mean?
Fix it right instead of putting on bandaids..... _________________ D-Dubya Manx clone 1914. Ex wifes car.
Maxine 61 Cal-look bug - Ex-wifes car.
telford dorr Samba Member
Joined: March 11, 2009 Posts: 3631 Location: San Diego (Encinitas)
Posted: Tue Apr 16, 2013 5:41 pm Post subject: |
Agreed. There are only a half dozen or so connections between the battery and the coil. A little time with a voltmeter will trace it out. Don't forget the ground straps.
_________________ '71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST) |
cefalu Samba Member
Posted: Tue Apr 16, 2013 8:48 pm Post subject: |
Thanks for the diagram. I agree that getting the circuit cleaned up is the right approach. I will try that first before I resort to a relay.
But, I have to say, what a difference it made to get full battery voltage on the coil. It totally solved what I thought was a carb problem _________________ 1970 Jeepster Commando
1974 Jeep J-20 ZZ
2018 Lexus GX460 |
Posted: Tue Apr 16, 2013 9:54 pm Post subject: |
Years ago I went with a coil that takes an external ballast resister and rigged up a bypass for the external resister during start up. This system was found on many rigs back in the day and gives improved coil output when cold over what the OEM VW system would even with a relay added.
