How to prepare new HT Leads
DoctorP
DoctorP is offline
PostPosted: Fri May 03, 2013 9:48 am    Post subject: How to prepare new HT Leads Reply with quote
I'm working on getting my 73 bus started. Currently focusing on the spark plugs. I have to replace 1 lead because the existing one is hard and crispy. The PO looks like they put in new spark plugs. In any case, the new Bosch leads have a retaining wire in each connector and their too small to accommodate a spark plug. Am I supposed to somehow custom fit it?
DP
Air-Cooled Novice
1973 Westphalia Campmobile
Proud owner since April 19, 2013
Engine Code GE009830
Skoolieman
Skoolieman is offline
PostPosted: Fri May 03, 2013 9:52 am    Post subject: Reply with quote
You need to pull the cap off the sparkplug. there is a small threaded rod inside that they go over
Edit: Here is a pic
'69 Westfalia Camper~Cassidy
1600dp with H30/31 carb 009 distributor and alternator conversion
kreemoweet
kreemoweet is offline
The screw-on tip is supposed to be removed from the plug end. The connector clip you show
is mangled, must be fixed or replaced.
'67 bug: seized by the authorities
busdaddy
busdaddy is offline
PostPosted: Fri May 03, 2013 9:53 am    Post subject: Reply with quote
Unscrew the terminal off the end of the spark plug.
Слава Україні!
aeromech
aeromech is offline
PostPosted: Fri May 03, 2013 10:27 am    Post subject: Reply with quote
Yep, unscrew it. If your wires are bad just replace the entire set. Shouldn't be more than about $30. I like to use Bosch wires and I always stay away from those colorful "bling" wires some people buy.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
DoctorP
DoctorP is offline
PostPosted: Fri May 03, 2013 11:17 am    Post subject: Reply with quote
Thanks for the replies everyone. I'll now get that done. I definitely don't trust the current wiring anymore, nor the PO who installed them. This will get me started.
DP
Air-Cooled Novice
ivwshane
ivwshane is offline
PostPosted: Fri May 03, 2013 11:26 am    Post subject: Reply with quote
On busdepot they say these are better than the Bosch wires:
http://www.busdepot.com/021998031a
If they are better then why are the Bosch wires so much more expensive?
http://www.busdepot.com/09171
77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab
VDubTech
VDubTech is offline
PostPosted: Fri May 03, 2013 12:42 pm    Post subject: Reply with quote
Since when does price have anything to do with quality?
First Trip in the RustyBus:
http://www.thesamba.com/vw/forum/viewtopic.php?t=279077&highlight=
borninabus wrote:
a measurement of your rod would be extremely useful.
notchboy wrote:
my dad wasnt a belittling cock when he tought me how to wrench on cars.
One photo = good for reference.
10 photos = douchebaggery
ivwshane
ivwshane is offline
PostPosted: Fri May 03, 2013 12:46 pm    Post subject: Reply with quote
I don't know that's why I'm asking;)
77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab
aeromech
aeromech is offline
PostPosted: Fri May 03, 2013 12:47 pm    Post subject: Reply with quote
Actually I found out that Bosch T4 wires are more like $60 a set.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
SGKent Premium Member
SGKent is offline
PostPosted: Fri May 03, 2013 12:48 pm    Post subject: Reply with quote
the skin on the Bosch ones tears easily. The other ones BD carries are better IMHO.
George Carlin:
Skills@EuroCarsPlus:
