Type 3 brakes on 63 Panel
roundhouse72
roundhouse72 is offline
PostPosted: Wed Jul 03, 2013 12:29 pm    Post subject: Type 3 brakes on 63 Panel Reply with quote
My 63 panel has IRS in the back and I put on Type 3 brakes but it has been nothing but a headache. Just last night they would get super tight after a little driving. The pedal would get rock hard and it felt like I was pulling an extra 1000lbs! Then it loosened up, ran fine? But they are super hot all the time. We used the micrometer and measured 100x and they shouldn't be rubbing? We've triple checked we have all the right parts and we've gotten them backed all the way off....any ideas?
I finally have it to a point I can cruise it and this is pissing me off!
PLEASE HELP. (of course the stock bus fronts work perfectly Exclamation )
joe56vw
joe56vw is offline
PostPosted: Wed Jul 03, 2013 12:50 pm    Post subject: Reply with quote
are the soft lines good? when they get old they collapse and don't release the fluid from the wheel cylinder
'60 15 window walkthrough
why is there no sarcasism button on here?
mandraks
mandraks is offline
PostPosted: Wed Jul 03, 2013 1:08 pm    Post subject: Reply with quote
i bet that is it
regards
Uli
Erik G
Erik G is offline
PostPosted: Wed Jul 03, 2013 1:10 pm    Post subject: Reply with quote
soft lines for sure. only other possibility would be the tabs for the star adjusters on the backing plate missing, and the stars rotating and adjusting themselves in and out. but I'd bet on the rubber lines
roundhouse72
PostPosted: Wed Jul 03, 2013 1:36 pm    Post subject: Reply with quote
Every single part is brand new, hard lines, soft lines, adjusters and all. The adjusters function normally too. It has been a real fight getting the drums on and off each time though, to the point I had to replace one because of cracking from hitting it too hard.
Erik G
Erik G is offline
PostPosted: Wed Jul 03, 2013 1:42 pm    Post subject: Reply with quote
What else will cause that kind of issue, messing with the master cylinder rod, so it's not releasing just the rears? Could be I suppose, I never mess with that rod
the hoses could of course still be bad, new or not I suppose
mandraks
mandraks is offline
PostPosted: Wed Jul 03, 2013 1:48 pm    Post subject: Reply with quote
if your rear brakes don't release, it would be hard to get the drums off.
regards
Uli
joe56vw
joe56vw is offline
PostPosted: Wed Jul 03, 2013 1:59 pm    Post subject: Reply with quote
I have had brand new wheel cylinders stick most of the new stuff is cheap Chinese crap
try taking the wheel cylinders apart and check the seals and plungers to see if they are good
the last set of cheap wheel cylinder I got I had to hone out the inside because there was machining marks that the plungers were sticking on
BarryL Premium Member
BarryL is offline
PostPosted: Wed Jul 03, 2013 6:55 pm    Post subject: Reply with quote
Make sure there is a tiny gap between the end of the brake push rod and the master cylinder piston. It has to have some gap.
PostPosted: Wed Jul 03, 2013 10:26 pm    Post subject: Reply with quote
Yes, it is 1mm measured underneath or 10mm measured at the pedal.
delx23
delx23 is offline
PostPosted: Thu Jul 04, 2013 2:20 am    Post subject: Reply with quote
did you pay attention at the adjusters screw ends ? where the shoes are locked in place basically is different from the bus and that metal piece has an angle and will only go one way to allow the shoes to rest, if you turn it the other side even with the adjuster all the way back the drum will not fit or have way to little play..
So check the angle of the adjustment screw..
good luck
roundhouse72
PostPosted: Thu Jul 04, 2013 6:57 am    Post subject: Reply with quote
Thanks guys, dad and I will check these things and let you know....happy 4th!
delx23
delx23 is offline
PostPosted: Thu Jul 04, 2013 11:29 am    Post subject: Reply with quote
Let us know
Happy 4th
BarryL is offline
PostPosted: Thu Jul 04, 2013 6:53 pm    Post subject: Re: Type 3 brakes on 63 Panel Reply with quote
It probably was just hitting on the ground and had no where to push to.
Cuz it was rubbing on the ground.
roundhouse72 wrote:
Then it loosened up
Stopped over a sink hole?
roundhouse72
PostPosted: Fri Jul 05, 2013 4:11 pm    Post subject: Reply with quote
Very Happy funny...it's not THAT low!
cdennisg
cdennisg is offline
PostPosted: Fri Jul 05, 2013 4:46 pm    Post subject: Reply with quote
I bet a dollar that this is the cure. I have had it happen when I replaced a M/C.
plane_ben
plane_ben is offline
PostPosted: Fri Jul 05, 2013 4:55 pm    Post subject: Reply with quote
Pedal free play and what was said about the adjusters. If they are in wrong, they can actually cut into the brake shoe and hold the shoe farther away from the wheel cylinder and closer to the drum.
I have been victim of bad soft lines right out of the parts bin too. Don't discount them just because they are new.
I'm at the age were "fuck off", "fuck you", and "fuck it" answer most questions.
Mile High Puma
Mile High Puma is offline
PostPosted: Sat Jul 06, 2013 8:08 am    Post subject: Reply with quote
I had a master cylinder that would build brake pressure as I drove it until the rear brakes would get tight and lock up until I let it sit for a while. Found that the piston inside was not retracting back far enough to completely open the bleed port which let's fluid back into the reservoir. If you take it out and shine a light into the bleed port while pushing in the rod you should be able to see the piston seal go past it, it should not be blocked when off the brakes.
1965 Velvet Green DC
1990 Westfalia Syncro
cdennisg
cdennisg is offline
PostPosted: Sat Jul 06, 2013 9:59 am    Post subject: Reply with quote
Pretty sure that this is exactly what happens there is not enough pedal/pushrod freeplay.
roundhouse72
PostPosted: Tue Jul 09, 2013 6:31 am    Post subject: Reply with quote
Hey Guys....got back on the brakes this weekend and I think we solved the mystery. We changed out the shitty AutoZone "type 3" (I put that in "" because I think they are just a one size fits all BS part #) wheel cylinders with nicer German units. The difference was immediately noticeable, the AutoZone cylinders were 3mm bigger each side and were pushing the pads too far out then not releasing correctly. The size difference was only really noticeable when you compared overall length with the German cylinders.
Took it out for about a 20 minute cruise and got no pedal stiffening, no buildup of heat and it performed much, much better.
Thanks for all your help and suggestions, moral of the story is don't take the easy way and buy shit parts from local chains. Spend a little more and get the good stuff you can count on.
