Paul Jeffries Samba Member
Posted: Sun Aug 18, 2013 8:17 am Post subject: Syndrome problem ? |
1989 2.1l auto digifant Vanagon US version now in UK
Engine runs ok then dies, sometimes restarts, sometimes not , had 3 tows home in last month from camping trips.
All at intermittent mileage, 150 miles, then only 5 miles.
Fitted new coil, lambda, new leads, plugs, all filters, dis cap, new hardstart relay, VW -302 signal harness, checked ECU and AFM, injectors etc, all earth grounds are ok.
What else could it be and how can I diagnose a solution.
All constructive ideas considered. |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32988 Location: Reading Pennsylvania
juanb Samba Member
Joined: December 03, 2009 Posts: 538 Location: San Francisco, CA
Posted: Sun Aug 18, 2013 1:41 pm Post subject: |
You say it doesn't start... What does it do? Does it crank? Do you hear the fuel pump buzz when you turn the key to contact just before starting?
Those are things that would help folks here help you.
Also: a good booklet to have is this:
http://www.cabby-info.com/Files/DigifantProTrainingManual.pdf
Follow the instructions there and you can figure out pretty fast what might be wrong. Last time it happened to me, it was the hall sender connector into the distributor that had a bad contact. Previous time, it was the ignition switch. I'm a newbie, and both times I figured what it was on my own. _________________ 1989 Westy AT, 2.2 GoWesty.
We drove it to Argentina: http://www.vanenvan.com |
Posted: Sun Aug 18, 2013 2:41 pm Post subject: |
it cranks but wont fire up - the fuel pump does buzz first, the hall sender tested ok, not checked ignition switch
many thanks for your reply Juan |
