yycwesty Samba Member
Posted: Thu Nov 01, 2012 3:45 pm Post subject: Rear heater & 2.5 subie |
2.5 subie installed and would like to pull the rear heater under the seat. Do I form a loop with the lines that are left in or cap each one off
Cheers
Al |
GrindGarage Samba Member
Joined: October 14, 2008 Posts: 710 Location: Ocean City, NJ
Posted: Thu Nov 01, 2012 3:59 pm Post subject: |
plug the lines. If you put them together the loop bypasses the front heater. If you think it will never be put back remove the T fittings from the main hoses (I had one snap in 10 deg F) _________________ -cliff
91 Vanagon AUTO
97 Single Port EJ22 all smallcar.com |
Posted: Thu Nov 01, 2012 4:13 pm Post subject: |
Hey grind
What did you use to plug the lines
Al |
presslab Samba Member
Joined: September 29, 2008 Posts: 1730 Location: Sonoma County
Posted: Thu Nov 01, 2012 4:21 pm Post subject: |
It depends on how your cooling system is configured. My cooling system with the KEP method must have a bypass in the heater circuit. Plugging the lines would cause the engine to overheat.
Best thing is to ask whoever did your conversion. _________________ 1986 Vanagon Westfalia EJ25
1988 Subaru GL-10 EJ20G --- 2000 Honda XR650L
2010 Titus El Guapo --- 2011 On-One 456 Ti |
dobryan Samba Member
Joined: March 24, 2006 Posts: 17147 Location: Brookeville, MD
Posted: Thu Nov 01, 2012 6:35 pm Post subject: |
presslab wrote: |
Best thing is to ask whoever did your conversion. |
X2!
DON'T plug those lines until you know how your feedback to the thermostat works. If it uses the heater loop you must leave the lines connected or you will overheat or at the least run too hot. If the thermostat feedback loop has to go thru the front heater it will fool the thermostat into thinking that the engine is running at a much lower temp than it really is. Please talk to the engine conversion shop first. _________________ Dave O
The Western Syncro build
Franklinstower Samba Member
Posted: Thu Nov 01, 2012 6:37 pm Post subject: |
presslab wrote: |
mine too, I have the Vanaru coolant system - the rear heater hoses must be connected if the heater is removed to provide the necessary water for the T-stat to operate.
If you have Tom Shiels Coolant plate at the T-stat housing, I think you can plug those rear heater hoses.
Paul _________________ '89 Westy - EJ25/22 Frank 4.44 5mt
'75 Miami Blue Sunroof FI Standard Bug
YITB |
Posted: Thu Nov 01, 2012 6:56 pm Post subject: |
I'm running smallcar setup with just front heater without rear tees and all good here tested 10f-100 deg _________________ -cliff
91 Vanagon AUTO
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5930 Location: Tsawwassen, BC
Posted: Thu Nov 01, 2012 7:32 pm Post subject: |
+ 100 Make sure that your heater loop isn't the feedback circuit for the thermostat before capping those lines! You can always put a restrictor in there (1/4" ball valve) so you can control the flow. _________________ '84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com |
Posted: Thu Nov 01, 2012 8:08 pm Post subject: |
actually looking to make a little more space. Talked to Hans tonight, from Vanaru, and he suggested looping the lines..
Al |
Posted: Tue Sep 17, 2013 12:36 pm Post subject: |
You bet but if you notice on that post last year my concern was to loop or not whereas this post I wanted to know the best way to work on the pipes from the top or the bottom |
