Door straps
The Splitman
The Splitman is offline
PostPosted: Wed Feb 05, 2014 11:53 am    Post subject: Door straps Reply with quote
Who can help me with pictures of the door straps fastening of the cargo doors left and right. I have a fixed bracket right but the left is nothing. Who helps me Question
durfeec
durfeec is offline
PostPosted: Wed Feb 05, 2014 3:22 pm    Post subject: Reply with quote
I dont think a bus came with a strap on the left hand side. Just the rubber bumpers so it doesn't hit the body. The reason for the strap on the right is so you cannot open the cargo door into the front door and shut the front door on the cargo door. At least that is what I have read. It makes sense. Laughing
1960 Bus Panel/Camper
NVNATIVE
NVNATIVE is offline
PostPosted: Wed Feb 05, 2014 3:54 pm    Post subject: Reply with quote
Not sure it helps but my deluxe has straps on both doors. There is no place to put those bump stop things on the body as the deluxe molding takes that spot.
I don't have any pics on this computer but can take some later if no one else does.
64' Notch (Notcho)
67' 13 Window Deluxe (Maxwell)
type47fan1
type47fan1 is offline
PostPosted: Wed Feb 05, 2014 4:10 pm    Post subject: Reply with quote
I have had buses with straps on both. On the left door it was attached with the same type of bracket that mounts to the door. One is a deluxe and the others were not. The deluxe obviously did not have the bumpers but the others did.
JLD
My 60 Mango Build
http://www.thesamba.com/vw/forum/viewtopic.php?t=581699
My 66 Westy Build
http://www.thesamba.com/vw/forum/viewtopic.php?p=5825134#5825134
PostPosted: Wed Feb 05, 2014 5:19 pm    Post subject: Reply with quote
Yes, the left is the same as the right side. Same brackets.
Photo of my '63 15-Window:
Strap is detached from the cargo door so I can open it all the way.
kenshapiro2002
kenshapiro2002 is offline
PostPosted: Wed Feb 05, 2014 5:27 pm    Post subject: Reply with quote
You said... Embarassed
Looking for a correct 1967 rear seat
Looking for '67 Engine / Block HO 183xxx - HO 194xxx
flemcadiddlehopper
flemcadiddlehopper is offline
PostPosted: Wed Feb 05, 2014 6:44 pm    Post subject: Reply with quote
My '67 came with a strap on both sides, and (standard) a bump stop on the front passenger door too. Both straps could be unhooked by lifting the pin out of the loop.
Gordo.
Everybody Dies....Some Never Live.
Retrograde Garage. Vintage Aircooled, and others.
Clara Premium Member
Clara is offline
PostPosted: Wed Feb 05, 2014 11:03 pm    Post subject: Re: Door straps Reply with quote
Microbuses had straps for both cargo doors.
Kombis & panels only had the strap for the front cargo door.
NVNATIVE
NVNATIVE is offline
PostPosted: Wed Feb 05, 2014 11:12 pm    Post subject: Reply with quote
Does anyone make a slightly longer strap? My front door doesn't quite make 90 degrees and regular closes itself. Something about an inch longer would be awesome.
64' Notch (Notcho)
BarryL Premium Member
BarryL is offline
PostPosted: Thu Feb 06, 2014 8:53 am    Post subject: Re: Door straps Reply with quote
What is your "left"? What side are your cargo doors on? What side is the steering?
Stocknazi
Stocknazi is offline
PostPosted: Thu Feb 06, 2014 9:02 am    Post subject: Reply with quote
I have always made my own straps; old vw dealer seat belt material sometimes came in green and has a close pattern to the og.
Does anyone know when VW started using the sheet metal type screws instead of threaded screws for holding the strap brackets?
WANTED:
Thomas Jefferson
CaLiBus
CaLiBus is offline
PostPosted: Thu Feb 06, 2014 9:18 am    Post subject: Reply with quote
Door straps and brackets (black mounts) are slightly shorter for commercial buses due to no inside panels and outside deluxe trim.
Clara is offline
PostPosted: Thu Feb 06, 2014 9:33 am    Post subject: Reply with quote
I was not aware of that.
There are different versions for high hinge and low hinge buses, though.
CaLiBus
CaLiBus is offline
PostPosted: Thu Feb 06, 2014 9:48 am    Post subject: Reply with quote
Yup. I'll compare the two with some pics soon.
CaLiBus
CaLiBus is offline
PostPosted: Thu Feb 06, 2014 10:33 am    Post subject: Reply with quote
Here you go Clara ..
PostPosted: Thu Feb 06, 2014 10:37 am    Post subject: Reply with quote
I always wondered why some were taller but I guess it needs to clear the door panel trim.
CaLiBus
CaLiBus is offline
PostPosted: Thu Feb 06, 2014 10:49 am    Post subject: Reply with quote
Deluxe mount starts with 841 part no. Commercial starts with the 211 no.
The Splitman
PostPosted: Thu Feb 06, 2014 10:52 am    Post subject: Re: Door straps Reply with quote
The cargo doors are on the right side the steering is left
Stocknazi
PostPosted: Thu Feb 06, 2014 1:43 pm    Post subject: Reply with quote
Maybee i am missing something, but the shape of those cargo door strap brackets look the same to me. The one marked commercial has an 841 number on it as well.
WANTED:
Thomas Jefferson
CaLiBus
CaLiBus is offline
PostPosted: Thu Feb 06, 2014 3:13 pm    Post subject: Reply with quote
Instead of having all 9 numbers in such a tight space the 211 was left out. 211841###...
Spray some windex on that computer monitor. Deluxe is taller.
