LeninCas Samba Member
Joined: February 05, 2013 Posts: 447 Location: Orange County, CA
Posted: Sun Mar 02, 2014 4:42 pm Post subject: How many hours approx. to lower the rear end? |
Approximately, how many hours are involved in lowering the rear end of a 71 bug? _________________ one, two, many
one too many |
Cusser Samba Member
Joined: October 02, 2006 Posts: 33483 Location: Hot Arizona
Posted: Sun Mar 02, 2014 5:21 pm Post subject: |
It's a re-setting of the rear torsion bars. If you haven't done it before, you'd better plan on at least half a day. And that assumes that you've done your calculations right and get it right on the first try.
You'll need tools (if memory holds from 3 decades ago when I did this) such as angle protractor, 17mm allen wrench, 8M triple square drive wrench for the CV bolts.
It's essentially the opposite of adjusting the rear torsion bars to raise a sagging rear end, which is what I actually did then. But what I did to raise the rear of my own 1971 was to buy air-adjustable shocks rather than do the torsion bar thing; yes, likely I took the quick but coward's path.... _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
old DKP driver Samba Member
Joined: March 30, 2005 Posts: 4143 Location: Los Gatos,Ca.
Posted: Sun Mar 02, 2014 6:25 pm Post subject: lowering job |
X-2 with Cusser (the coward)
A minimum of 4 hours to do it right not including READING about it before hand.
Probably the hardest or time consuming part will be putting the cover plates
back on without stripping one of the bolts.
Besides all the tools and a good set of jack stands you should also replace
the inner and outer torsion arm bushings and, you also need some BABY powder to coat them
Have Fun _________________ V.W.owner since 1967 |
Joeys1969 Samba Member
Posted: Sun Mar 02, 2014 6:46 pm Post subject: |
Theres a guy that posted his video on youtube that was lowering the back of his squareback, watch all of those first so you have a good idea what is needed.
Joey _________________ Old VW's and Old Motorcycles. |
jderianSF Samba Member
Joined: June 24, 2013 Posts: 35 Location: San Francisco
Posted: Sun Mar 02, 2014 7:30 pm Post subject: |
I agree with the above time frames. Second side is easier than the first.
To make putting the plates on easier, I bought longer bolts and the hardware store. Once the long ones have brought in the plates, I switched over to the stock ones. (not my idea -- just passing it on)
I also used wratcheting straps to pull the assembly back, to free up the spring plates.
Good Luck! _________________ Jason |
Cusser Samba Member
Posted: Sun Mar 02, 2014 7:54 pm Post subject: |
Hmmm, I should start out by saying that I still haven't read how to do it. I've only looked at my bug and I think I have a pretty good idea of how it's done. I just don't have any idea of how hard it is to actually do.
I would imagine freeing up the splines will not be easy because the car is pretty stock other than what I've done to it. I'll definitely look for that video guys and decide from there if it's something I want to attempt or not. _________________ one, two, many
one too many |
Posted: Sun Mar 02, 2014 8:53 pm Post subject: |
http://m.youtube.com/watch?v=MeNdZCf5AzA
This is the guy, watch all 4 videos in a Row before you do anything. It's not that bad, I've done it on 2 cars now and the first time it might have taken me 2 hours.
Posted: Sun Mar 02, 2014 11:29 pm Post subject: |
the 3rd time will take you 1/3 of the time as the first. This is because all the nuts/bolts come off easily compared to when they hadn't been removed in 40 years. The other reason is you don't spend 1/2 the time staring at the car trying to figure out what to do next. _________________ It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net |
gt1953 Samba Member
Joined: May 08, 2002 Posts: 13959 Location: White Mountains Arizona
Posted: Mon Mar 03, 2014 7:01 am Post subject: |
Took me 5 hrs on the 68. Just be careful. Have all of the correct special tools to do the job. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
Posted: Mon Mar 03, 2014 8:45 am Post subject: |
All these "special" tools are what are scaring me. Are these simple to find? I know the "star" tools to remove an IRS tranny took a little bit of looking before I actually found them. Are these tools hard to find? _________________ one, two, many
one too many |
peteandvanessa Samba Member
Joined: July 01, 2009 Posts: 931 Location: Sacramento
Cusser Samba Member
gt1953 Samba Member
Posted: Mon Mar 03, 2014 12:43 pm Post subject: |
All of the tools are needed. I even had to disconnect the emergency brake cable. To do that I have to remove the brake drum, to do that you need a 36mm socket as well.
Be safe. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
Joel Samba Member
Joined: September 04, 2006 Posts: 11099 Location: NSW Australia
Posted: Mon Mar 03, 2014 1:53 pm Post subject: |
Everyone seems to do this job the long and hard way with fancy tools.
admittedly I've done the job more than a couple times and all my bolts come undone nice and easy but it takes a bit over 30 mins per side with no fancy tools other than an angle finder.
Just unbolt the the spring plate, lower shock mount and the trailing arm pivot bolt.
No need to unbolt the CV joint, brake cables etc
and a length of angle bolted to the spring plate lifts it back up without having to use chains or spring plate tools.....
Been doing it that way for nearly 20 years now.
_________________ Quick little bug, you got a Porsche motor in that?
1974 Germanlook 1303 2.5 Suba-Beetle |
Posted: Mon Mar 03, 2014 4:18 pm Post subject: That looks really easy! |
Joel, that way looks very simple to follow! I'm guessing that all I'd have to do from there would be lift the jack and it will raise the spring plate. My only concern with that is if it messes up the splines?
I know that in time, bugs tend to sag so I wouldn't want to do that and mess up the splines causing my bug to lower itself whenever it wants to  _________________ one, two, many
one too many |
Cusser Samba Member
Posted: Mon Mar 03, 2014 4:43 pm Post subject: |
Once you jack the spring plate higher than the retaining ridge, you need to "pry" it away a little so it doesn't settle right back into place, this can be dangerous, must be careful.
And opposite upon reassembly.
I believe that the "one" time I've done this, I put the jack directly under the spring plate, this way looks better, easier, and safer. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Joel Samba Member
Posted: Mon Mar 03, 2014 5:13 pm Post subject: |
| Cusser wrote: |
I believe that the "one" time I've done this, I put the jack directly under the spring plate, this way looks better, easier, and safer. |
I doubt that.
Just putting the jack straight under the spring plates will lift the whole car due to torsion bar tension.
Thats why its necessery to either chain the jack to the car or use the threaded spring plate tool.......or use my angle iron method _________________ Quick little bug, you got a Porsche motor in that?
Posted: Mon Mar 03, 2014 5:47 pm Post subject: |
NOW I am confused. I figured the weight of the car would allow the spring plate to move up a notch.
I thought the angle iron method was to measure the angle of the spring plate? That way I can compare them and make sure they are both the same level.
Cusser: What you are saying makes sense to me but I am not sure where I will have to "pry" it. I thought I would hear a "click" to indicate to me that the spring plate has moved up a notch. I'm really doing this all on imagination, I have absolutely no idea. I just want to make sure I have a good idea first and then watch the videos to confirm what I think. That way, I will feel confident once I go ahead and do it. _________________ one, two, many
one too many |
