one4house Samba Member
Joined: July 18, 2009 Posts: 1121 Location: Sherman Texas
Posted: Wed Apr 09, 2014 7:44 am Post subject: Flex Plate Bolts |
What is the secret to installing the three flex plate bolts on a type 3? I have been installing them through a cutout I made in the area under the car. Engine removal takes 45 min. Install takes 2 hours because of these mother fin 3 bolts. There has to be a better way that I don't know about. _________________ My Old 64 Field Find
My Old 66 Squareback
My Old 66 Beetle
My Old 70 Squareback |
Mark Shutt Samba Member
Joined: February 10, 2012 Posts: 482 Location: Doncaster UK.
Posted: Wed Apr 09, 2014 7:55 am Post subject: |
I didn't have a problem, just rotate engine until you have the thread in view then insert bolt? is your engine from an auto trans car? if not it won't have the notch cut out to line up with trans notch so less access... _________________ 1968 1600TL Auto build thread, have a look!
http://www.thesamba.com/vw/forum/viewtopic.php?p=6007222#6007222 |
Posted: Wed Apr 09, 2014 8:17 am Post subject: |
Mark Shutt wrote: |
I didn't have a problem, just rotate engine until you have the thread in view then insert bolt? is your engine from an auto trans car? if not it won't have the notch cut out to line up with trans notch so less access... |
Mine is a universal case. Can you post a picture of the access hole/notch you talking about?
My engine is a gex rebuild, so I am assuming is a universal case and might have all the cutouts. _________________ My Old 64 Field Find
My Old 66 Beetle
Posted: Wed Apr 09, 2014 8:19 am Post subject: |
one4house wrote: |
Mark Shutt wrote: |
Mine is a universal case. Can you post a picture the access hole/notch you talking about?
My engine is a gex rebuild, so I am assuming is a universal case and might have all the cutouts. |
that could be your problem! on the tranny side of the bell housing is a notch, it should be mirrored on the motor side for ease of access.. you can Dremmel this out easy enough..
I'll try and find a picture. _________________ 1968 1600TL Auto build thread, have a look!
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17974 Location: Eugene, OR
Posted: Wed Apr 09, 2014 8:27 am Post subject: |
We ground a 1/4 moon shape out of the case with a rotary file on our drill. If you sweep up the shavings you can start a Hot magnesium fire for a minute or so with a propane hand torch. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Posted: Wed Apr 09, 2014 8:32 am Post subject: |
Mike Fisher wrote: |
We ground a 1/4 moon shape out of the case with a rotary file on our drill. If you sweep up the shavings you can start a Hot magnesium fire for a minute or so with a propane hand torch. |
I would love a picture of said shave area. Are we taking under the car or up top? I was thinking up top last night, but I was also so mad because of it taking so long that I didn't dare go near it with power tools least I might have cut the entire car in half. _________________ My Old 64 Field Find
My Old 66 Beetle
Posted: Wed Apr 09, 2014 8:37 am Post subject: |
Mark Shutt wrote: |
it's underneath to match the cut out in the bell housing side, on the left hand side. |
I will give it a look this afternoon. The car is still on stands right now. Thanks for the tip. I'm sure that something will jump out at me when I am looking. Hell, it is probably right there in my face and I am doing it the hard way for no reason. _________________ My Old 64 Field Find
My Old 66 Beetle
rustyfastback Samba Member
Posted: Wed Apr 09, 2014 8:50 pm Post subject: |
Here is a photo of an automatic case, note the cutout in the lower right.
side by side comparison with a standard case
Multi69s Samba Member
Joined: January 24, 2006 Posts: 5370 Location: Lefty, CA
Posted: Wed Apr 09, 2014 10:49 pm Post subject: |
I like that one. When I was growing up, my dad had a VW / Porsche shop. he did a lot of performance work for both crowds. This was way back when they would run auto crosses in supermarket parking lots and they ran a lot of sportsman classes at Laguna Seca.
Needles to say, I had a large supply of magnesium shavings. They were a little hard to get lit, but when they took off, it was like fireworks. Then I would hit them with a fine spray of water and the flames would shoot up higher then my head. Life was good _________________ 69 road Bug 2110
73 Squareback - 2L, T4, Automatic W/ AC
Gone, but many fond memories 69 Baja Bug 2010 - 5 Rib Bus Transaxle
Gone but not forgotten 72 Baja Bug 2010
My builds
T4 into Squareback http://www.thesamba.com/vw/forum/viewtopic.php?t=458944&highlight=
Auto Trans Rebuild http://www.thesamba.com/vw/forum/viewtopic.php?t=516066&highlight=
AC in Squareback https://www.thesamba.com/vw/forum/viewtopic.php?t=...highlight= |
Posted: Thu Apr 10, 2014 5:08 am Post subject: |
rustyfastback wrote: |
I definitely don't have an automatic case. I have taken a grinder to mine and made a place to get up there, but it isn't as much as the auto case. I would be afraid that there isn't enough material cast in that area on a regular case.
My issue now is that I have to wedge the bolt in, hold behind the hex head with a flat head screwdriver and use open of my wrench pray a thread catches. Because of how I have to hold pressure with the flat head, it often does not want to start.......It is a fcking pain in the ass. That is the nicest thing I can say about it.
I might need to quit being a Pussy and just the grinder back after it. _________________ My Old 64 Field Find
My Old 66 Beetle
Posted: Thu Apr 10, 2014 5:11 am Post subject: |
Multi69s wrote: |
Needles to say, I had a large supply of magnesium shavings. They were a little hard to get lit, but when they took off, it was like fireworks. Then I would hit them with a fine spray of water and the flames would shoot up higher then my head. Life was good |
Surprisingly enough, guitar picks burn in the same fashion. I'm not sure what material they are made of, but they burn baby burn. _________________ My Old 64 Field Find
My Old 66 Beetle
Posted: Thu Apr 10, 2014 5:17 am Post subject: |
The cases were all cast the same. I've seen pictures here of different 1/4 moons & full square cuts like this picture from the Factory & elsewhere later on. They are all one off & different. I just ground our 1/4 moon out until I could start the bolts with my fingers and tighten with an end wrench. _________________ https://imgur.com/user/FisherSquareback/posts
vlad01 Samba Member
Joined: October 27, 2010 Posts: 3069 Location: Australia
Posted: Thu Apr 10, 2014 6:24 am Post subject: |
one4house wrote: |
Multi69s wrote: |
Surprisingly enough, guitar picks burn in the same fashion. I'm not sure what material they are made of, but they burn baby burn. |
probably nitrocellulose like pingpong balls are made of which is an explosive.
yes I have burned vw magnesium parts on the bon fire at home. its like a sun in the paddock that burns for nearly an hour _________________ The best of VW engine development!
https://www.youtube.com/watch?v=BROWqjuTM0g
71 Aussie notchback, the money pit
92 VP vacationer, old faithful never die
95 VR executive, Restored beyond factory
92 VP S Pack, bought it new old |
