tanhis Samba Member
Joined: July 23, 2005 Posts: 659 Location: Rauma Finland
Posted: Tue Apr 15, 2014 7:19 am Post subject: How to: Mechanical AAR Auxiliary air regulator cleaning |
I had to clean and rebuild mine and could not find any pictures or any good instruction what to do so here is some pictures what to do.
And as a side note I must say that I am not a expert or anything in this stuff.
Directly out of the car you can see the adjustment screw and scale on the body of the aar.
Top cower remowed.
Shaft pushed up and off the bi metallic spring.
Better pic of the adjustment.
The shaft of my aar was really tight (tight enough that bi metallic sping would not turn it) to the body of the aar and cleaning an polishing did not help and finding a replacement part ower here might be hard so I decided to put some metal polishing compund to the tight part and spin it gently whit a drill. Few cleaning and retrying later I got the shaft spinning freely.
After this I cleaned all whit carb and brake cleaner and reassembled whit a smear of molykote BR2+ (slide bearing grease)
When everything was back to gether I adjusted the thing in water to fully close at 50*C I tested the fully closed position by blowing to pipe that I attached to the aar.
I also did a new aar to the engine seal from a regular fuel pump seal.
And here are some test pictures showing the aar opening.
~20*C
~-15*C
So I hope that this helps someone in the future.
_________________ -58 Typ2 ambulance
-62 Typ 34
-65 Typ 34
-73 411 variant all metal custom
-69 typ 2, 9 seater
-89 vanagon camper conversion matkaaja
-08 3.0tdi phaeton |
Lionhart94010 Samba Member
Joined: January 04, 2005 Posts: 1418 Location: SF Bay Area / Silicon Valley / So Cal
Posted: Tue Apr 15, 2014 10:15 am Post subject: |
Learned something, did not know about AAR's(my VW's do not have them), now I do, thanks to your post :0) _________________ Current VWs 71 T2 Westy SO-72/6(Miami), 71 Crew Cab, 2015 GSW TDI
Other owned VW’s 59, 68 1500s, 69 & 71 Bug’s; 72 & 73 S-Bug’s; 67 Westy, 67 Deluxe, Other 71 DC, 72 KG GT that now lives in Australia, 12 JSW TDI, 2015 GSW TDI, 2023 Tiguan
VW technical information sights
thesamba - www.ratwell.com - www.shoptalkforums.com/ - www.vw-resource.com - http://www.type2.com/
http://bobhooversblog.blogspot.com/ - www.aircooled.net/gnrlsite/resource/articles.htm |
Tram Samba Socialist
Joined: May 02, 2003 Posts: 23022 Location: Northwest of Normal
Posted: Tue Apr 15, 2014 11:54 am Post subject: |
Excellent tutorial and a thorough job. It's rare that one is found that stuck, but it happens! _________________ Немає виправдання для війни! Я з Україною.
| Bryan67 wrote: |
| Just my hands. And a little lube. No tools. |
Those who can- do.
Those who can't? Subaru. |
akokarski Samba Member
Posted: Sat Jun 15, 2024 8:12 am Post subject: Re: How to: Mechanical AAR Auxiliary air regulator cleaning |
| that's too bad that pics are all gone. |
tanhis Samba Member
Posted: Sat Jun 15, 2024 8:13 am Post subject: Re: How to: Mechanical AAR Auxiliary air regulator cleaning |
Thanks for reminder, I try to repair the links. _________________ -58 Typ2 ambulance
-62 Typ 34
-65 Typ 34
-69 typ 2, 9 seater
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 23567 Location: Kimball, Mi
Posted: Sun Jun 16, 2024 7:39 am Post subject: Re: How to: Mechanical AAR Auxiliary air regulator cleaning |
| tanhis wrote: |
| Thanks for reminder, I try to repair the links. |
Or re-post them to your Samba gallery, it's free and will keep your posts whole. I know I've got pics posted from 2003 or 2004 that are still here. _________________ Bob 65 Notch S with Sunroof
| Tram wrote: |
| "Friends are God's way of apologizing for relatives." |
| Tram wrote: |
| People keep confusing "restored" and "restroyed". |
