Santaji Samba Member
Joined: December 29, 2007 Posts: 105 Location: Mumbai, India
Posted: Thu Mar 05, 2015 1:00 pm Post subject: Bus suddenly developed an issue - not running |
Had a problem with my '78 FI Westy yesterday. The Bus was driven around a bit during the day on some errands, mostly in heavy stop and go traffic.The Bus ran all right until the evening when the engine started to miss and eventually stalled. The Bus had been idling for around 10 minutes when this happened.
The engine seemed extremely hot afterwards, definitely seems to have overheated.
Now the Bus starts but doesn't idle. It will just barely stay running if I hold the wiper arm in the AFM open but still misses and splutters badly.
All the vacuum lines seem OK. Checked all the plug wires too and they're all attached securely. The rotor and the distributor cap are in perfect condition too.
I'm wondering how the problem appeared so suddenly after the Bus had been running OK all day? _________________ '78 Westfalia '63 RHD Beetle '62 Fiat 1100 |
Randy in Maine Samba Member
Posted: Thu Mar 05, 2015 1:08 pm Post subject: Fuel volume test injected |
| Can you test the fuel volume to see if the pump is able to pump 1 liter of fuel in 30 seconds? |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 53222 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Thu Mar 05, 2015 1:28 pm Post subject: |
Have a look at the points, is the plastic block that rubs on the distributor cam intact?, is the gap OK? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
PITApan Samba Member
Joined: November 09, 2014 Posts: 1058 Location: Northern Colorado
Posted: Thu Mar 05, 2015 3:31 pm Post subject: |
check wiring to the injectors too.
The overheating may be secondary to an underlying problem. |
Posted: Thu Mar 05, 2015 5:34 pm Post subject: |
| busdaddy wrote: |
| Have a look at the points, is the plastic block that rubs on the distributor cam intact?, is the gap OK? |
The Bus has pertronix ignition. _________________ '78 Westfalia '63 RHD Beetle '62 Fiat 1100 |
timvw7476 Samba Member
Posted: Thu Mar 05, 2015 5:40 pm Post subject: Bus suddenly developed an issue-not running |
It's time to test-swap the points & condenser for the Pertronix.
You kept them in the glove box, right? |
Tcash Samba Member
Joined: July 20, 2011 Posts: 12843 Location: San Jose, California, USA
Posted: Thu Mar 05, 2015 5:56 pm Post subject: Pertronix Module Testing |
