Tcash Samba Member
Joined: July 20, 2011 Posts: 12846 Location: San Jose, California, USA
Posted: Sat Jun 14, 2014 2:53 pm Post subject: Installing Door Panels |
To link to this post copy and paste
Code: |
[url=http://www.thesamba.com/vw/forum/viewtopic.php?p=7242921#7242921]Installing Door Panels[/url] |
Removed old panels. Cleaned with 409 and used brake clean on a rag to remove the old adhesive.
Applied rope caulk to doors. I bit thick, so I rolled it out between my hands to make it thinner. Cleaned an lubed door latches.
Installed 12 mil plastic purchased in a roll at the hardware store. Used a x-acto knife to trim plastic. Installed clip seals (condoms) not pictured. Note: next time I am in there I am going to install pieces of plastic on the inside of the openings to form flaps. So moisture will run off the plastic in the inside of the doors.
Note: replacement clip on the left and oe on right. I found it necessary to squeeze the barbs slightly on the replacements for installation.
I coated the backs of the panels with a acrylic spray or lacquer spray. To waterproof them. Lined up the clips and gently installed the door panels.
Rust-Oleum Never Wet
https://www.rustoleum.com/product-catalog/consumer-brands/neverwet/neverwet-kit
Tcash
guymon Samba Member
Joined: October 16, 2012 Posts: 7 Location: United States
Posted: Mon Nov 17, 2014 4:40 pm Post subject: Red? |
Where did you find those red panels. They look great. I want some for my 72 |
Brian Samba Moderator
Tcash Samba Member
Posted: Mon Nov 17, 2014 6:04 pm Post subject: Re: Red? |
guymon wrote: |
They are TMI. |
wcfvw69 Samba Purist
Posted: Mon Nov 17, 2014 8:32 pm Post subject: |
Nice job TCash. Just curious as to why you didn't install some sound deadener inside the doors? I know I want to do that with my 70'. The doors are so light, hollow and tinny... _________________ Contact me at [email protected]
The Samba member since 2004.
Posted: Mon Nov 17, 2014 8:36 pm Post subject: |
I took out the material and it makes shutting the door so loud. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
Tcash Samba Member
Posted: Mon Nov 17, 2014 8:44 pm Post subject: |
wcfvw69 wrote: |
Nice job TCash. Just curious as to why you didn't install some sound deadener inside the doors? I know I want to do that with my 70'. The doors are so light, hollow and tinny... |
Did not think about it. Good idea! |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 13474 Location: West Coast, USA
Posted: Mon Nov 17, 2014 8:51 pm Post subject: |
Brian wrote: |
I took out the material and it makes shutting the door so loud. |
I did mine last month, and anytime someone comes over and compliments my bus to my housemate, she opens and shuts the doors and everyone comments on how quiet and GERMAN they sound.
I enjoy making these cars sound like they should.
_________________ One-on-one tech help for your vintage Volkswagen:
www.airschooled.com
https://www.patreon.com/airschooled |
SamboSamba22 Samba Member
Joined: August 06, 2015 Posts: 2806 Location: Benton, Arkansas
Posted: Tue Aug 18, 2015 8:26 pm Post subject: |
Nicely done Tcash, thanks for the link. Good, clean work. |
curtis4085 Samba Member
Posted: Wed Aug 19, 2015 2:32 pm Post subject: |
That vapor barrier is missing the inner flap _________________ Special Thanks to:
Headflow Masters - Vista, CA
www.headflowmasters.com |
Posted: Wed Aug 19, 2015 2:40 pm Post subject: |
curtis4085 wrote: |
That vapor barrier is missing the inner flap |
Does anybody here know for certain if the factory installed the flaps on early bays without the flow through ventilation vents? I have never gotten a 100% certain answer. _________________ One-on-one tech help for your vintage Volkswagen:
www.airschooled.com
Posted: Wed Aug 19, 2015 2:56 pm Post subject: |
asiab3 wrote: |
curtis4085 wrote: |
Does anybody here know for certain if the factory installed the flaps on early bays without the flow through ventilation vents? I have never gotten a 100% certain answer. |
I have never seen them on early bays. But it's good measure to help direct the water to the holes in the door rather than between door panel and door. _________________ Special Thanks to:
Joined: January 01, 2007 Posts: 17830 Location: sticksville, ct.
Posted: Wed Aug 19, 2015 3:20 pm Post subject: |
asiab3 wrote: |
curtis4085 wrote: |
yes. I can verify that on 69, 70, 71 they had flaps. never parted a 68 so I cant say for sure _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
secretsubmariner Champagne Wrangler
Joined: January 08, 2011 Posts: 3109 Location: Tulsa, OK
Posted: Thu Aug 20, 2015 12:57 pm Post subject: |
skills@eurocarsplus wrote: |
asiab3 wrote: |
yes. I can verify that on 69, 70, 71 they had flaps. never parted a 68 so I cant say for sure |
Cool, thanks. _________________ One-on-one tech help for your vintage Volkswagen:
www.airschooled.com
Posted: Mon Aug 24, 2015 10:48 pm Post subject: |
I'm working on this very project, what flap are we referring to?
'74 Westy with vented doors (blue slider openings on door panels) |
kreemoweet Samba Member
Joined: March 13, 2008 Posts: 4091 Location: Seattle, WA
Posted: Tue Aug 25, 2015 7:38 am Post subject: |
SamboSamba22 wrote: |
The plastic moisture barrier had an extra flap on the outside which draped down into the bottom channel of the door. It kept the
inevitable leakage past the window seal from splashing onto the barrier and running down to accumulate between the barrier and door metal,
and likely eventually soaking into the door panel. _________________ '67 bug: seized by the authorities
Tcash Samba Member
Posted: Tue Aug 25, 2015 12:10 pm Post subject: |
Thanks to amskeptic.
Vapor Barrier Replacement How-To |
Dana Champion Samba Member
Joined: July 06, 2012 Posts: 633 Location: Ventura County, CA
Posted: Tue Aug 25, 2015 12:24 pm Post subject: |
For door panels, those are pretty sexy!... Nice job! |
