Removing rear skirt Ghia
hiho
hiho is offline
PostPosted: Mon Jan 07, 2019 8:57 am    Post subject: Removing rear skirt Ghia Reply with quote
I want to make the rear skirt and valance to make motor work even easier.
Anyone able to give me the Coles notes for removing these 2 pieces? Am I drilling out spot welds from where?
Read some discussion on choosing the right spot welds.
TDCTDI
Samba Advocatus Diaboli
TDCTDI is offline
PostPosted: Mon Jan 07, 2019 9:31 am    Post subject: Re: Removing rear skirt Ghia Reply with quote
A Ghia is already pretty flexible structurally, I wouldn't go out of my way to weaken it any more.
Unless you're yanking the engine every or every other weekend, the time spent drilling & hacking the rear apron off is sure to waste more time than what you'd spend working around it.
crazy tarzan
crazy tarzan is offline
PostPosted: Mon Jan 07, 2019 9:57 am    Post subject: Re: Removing rear skirt Ghia Reply with quote
Of course if you're planning on a subie swap Blue Ghia , it makes a little more sense. . . Twisted Evil
slalombuggy
slalombuggy is offline
PostPosted: Mon Jan 07, 2019 12:44 pm    Post subject: Re: Removing rear skirt Ghia Reply with quote
You just have to look at the panel seams to see where the spot welds will be. each panel has a stiffening fold and flange and the welds are underneath along those flanges. You have to drill out all the welds on the flanges from underneath. But I agree, the back end is going to be pretty floppy without that panel in there solid, If you were racing, ya, make it removable but on a street car it will be way easier to remove the rear engine tin and drop it out.
brad
