Engine stalls out and dies
DanRSA
DanRSA is offline
PostPosted: Wed Jul 16, 2014 1:30 pm    Post subject: Engine stalls out and dies Reply with quote
My beetle cuts out every now and again, and I lose all power. I switch the ignition off and try to start it and it starts but dies immediately. I try to rev it to get it idling but it seems like it doesnt get enough fuel. As I dont hear the car revving as loud as it should, in relation to where the pedal is. Once i do get it started it runs fine without cutting out, and I can drive perfectly.
But like I said, it happens only every now and again. But is becoming more frequent.
Could it be the air and fuel mixture not being right?
Any help and advice will be greatly appreciated
1976 Beetle
Northof49
Northof49 is offline
PostPosted: Wed Jul 16, 2014 1:48 pm    Post subject: Reply with quote
You might be able to eliminate whether or not its a fuel supply problem. Next time it happens, before attempting to restart it, remove the air cleaner and look down the carburetor bore. Move the throttle linkage and observe whether the accelerator pump squirts fuel. If you have an accelerator pump, and it has gone dry, that will tell you that it starved of fuel (ie fuel tank, lines, filter, fuel pump problems).
1958 Karmann Ghia owner
Volks Wagen
Volks Wagen is offline
PostPosted: Wed Jul 16, 2014 1:50 pm    Post subject: Reply with quote
When you say you lose all power... do you mean electrical power or engine power? Maybe your needle/seat in the carb is sticking. But it could be a lot of things, you'll need to provide more info.
1973 1303 with AB-motor - sporadic
reconstruction as time permits, 1986 ex-Bundeswehr Doka - on the road again.
I'm definitely, probably, the worlds greatest lover.
Aithníonn ciaróg ciaróg eile.
DanRSA
DanRSA is offline
PostPosted: Thu Jul 17, 2014 2:30 am    Post subject: Reply with quote
it was the fuel pump, that was faulty. It wasnt squirting in as much fuel as it shouldve. Thanks for the help.
1976 Beetle
