beardfoot Samba Member
Joined: September 09, 2012 Posts: 31 Location: San Luis Obispo
Posted: Tue Mar 01, 2022 10:13 am Post subject: GoWesty HD 930 Axle kit |
Hi there has anyone installed the GoWesty heavy duty 930 axle kit?
I've got a broken cv/axle and considering upgrading to the HD, but like many GoWesty products, it's hard to find any reviews.
I do a fair amount of off road type driving and camping, not sure if it's worth upgrading for 1300 dollars...
Also, would I need to replace the wheel bearings at the same time? Are the stubs any different in size than the original VW?
Thanks!
Andrew |
vanis13 Samba Member
Joined: August 15, 2010 Posts: 4639 Location: ABQ NM USA.... Except when not
Posted: Tue Mar 01, 2022 10:23 am Post subject: Re: GoWesty HD 930 Axle kit |
| beardfoot wrote: |
| ... would I need to replace the wheel bearings at the same time? Are the stubs any different in size than the original VW? |
How did GW answer that question? _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
www.SuperVanagon.com - some stuff I make |
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 7310 Location: Honolulu,Hawaii and France
Posted: Tue Mar 01, 2022 10:35 am Post subject: Re: GoWesty HD 930 Axle kit |
I made my own. Stub axles use the same wheel bearings.
It depends on your ride height, otherwise you can stay stock size with Löbro-GKN cv joints, your old German axles. Check the play in your original hub bearing carrier, you can upgrade for a better carrier too. _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
Posted: Tue Mar 01, 2022 10:58 am Post subject: Re: GoWesty HD 930 Axle kit |
Okay I see, so I would need to transfer the bearings to the new stubs? Seems like I would want to just get new bearings, ya?
My van is a 85 camper with GW 1.5"lift springs, Subaru EJ22 Kennedy type setup. I've got 16" GW wheels and general grabber tires. It's sitting up a little but not as much as a synchro or the ppl that replace their trailing arms.
GW is pretty hard to get a hold of, when I talked to someone over there they told me "You will need 2 cans of redline grease, everything else you need is in the kit." |
thatbaldwinlife Samba Member
Joined: August 01, 2011 Posts: 805 Location: Out exploring
Posted: Tue Mar 01, 2022 11:03 am Post subject: Re: GoWesty HD 930 Axle kit |
From what you said I do not think the 930 CV's are needed, especially at the price. We have a similar ride height and take ours off on some pretty rough terrain with no issues. We might look at moving to 944 joints if one of ours breaks though, just for the increased articulation.
nate _________________ 1987 Westy
Insta: @Thatbaldwinlife
Vanagon Adventure and DIY videos:
That Baldwin Life YouTube Channel |
Posted: Tue Mar 01, 2022 11:14 am Post subject: Re: GoWesty HD 930 Axle kit |
thatbaldwinlife
Thank you! That is what I am looking for
It's hard to make these major life decisions without the samba community chiming in. |
dobryan  Samba Member
Joined: March 24, 2006 Posts: 17353 Location: Brookeville, MD
Posted: Tue Mar 01, 2022 11:41 am Post subject: Re: GoWesty HD 930 Axle kit |
dobryan
Thanks! Yea I took our 4 year old camping up in Big Sur last week and heard a clicking on the way back, luckily it didn't break until I was 5 min from our house...But got me thinking about keeping a spare in the van! haha |
riceye Samba Member
Joined: March 09, 2006 Posts: 1715 Location: Caledonia, WI
Posted: Tue Mar 01, 2022 3:23 pm Post subject: Re: GoWesty HD 930 Axle kit |
Always my $0.02 with CV's and articulation. A simple step on assembly, YMMV.
CV clocking _________________ '87 Westy Weekender - daily driver on salt-free roads
There's gonna be some changes made.
“I find that things usually go well right up until the moment they don't.” - Ahwahnee
"Quality isn't method. It's the goal toward which the method is aimed." - Socrates, later quoted by R.M. Pirsig |
GreggK Samba Member
Joined: May 17, 2008 Posts: 1025 Location: Colorado/Philidelphia
GreggK Samba Member
Posted: Tue Mar 01, 2022 11:04 pm Post subject: Re: GoWesty HD 930 Axle kit |
| dobryan wrote: |
| GreggK wrote: |
| I always thought 944's were stock. What are the OEM joints called? |
Vanagon CV joints. also found on Bay Window buses
944s are from Porsche 944 models. 924 and VW Thing
930s are from Porsche 930 models. |
GreggK Samba Member
Posted: Wed Mar 02, 2022 9:35 am Post subject: Re: GoWesty HD 930 Axle kit |
I do not think the 944 joints are considered HD by any means. They can offer more articulation based on the smaller balls in the races which can result in less binding for lifted vans. Then you just need to find boots that can take the constant extreme angles....
Posted: Wed Mar 02, 2022 9:42 am Post subject: Re: GoWesty HD 930 Axle kit |
| thatbaldwinlife wrote: |
nate |
That is my understanding as well.
AFAIK:
The 930 CVs are the strongest.
The 944 CVs have the greatest articulation and although not as strong as a stock CV apparently are strong enough in most applications. _________________ Dave O
The Western Syncro build
Irishcalifornian Samba Member
Joined: September 08, 2016 Posts: 175 Location: CaliWestyfornia
Posted: Sat Jul 13, 2024 5:30 am Post subject: Re: GoWesty HD 930 Axle kit |
I purchased these about a year ago for preventive maintenance.
Finding out later that I should have gone German.
Now I need to install the right side with the GW kit because I can't afford another purchase.
So my question is, Is the HD 930 Axle kit Chinese crap parts or not? _________________ One Life, Live It |
markswagen Samba Member
Joined: January 28, 2018 Posts: 1554 Location: san diego
Posted: Sat Jul 13, 2024 7:00 am Post subject: Re: GoWesty HD 930 Axle kit |
l see 930 cv joints as a bad idea, especially on a syncro.
l think it's best to have something cheap and easy to fix, that's the weakest point, rather than risking transmission internals again especially on a syncro.
l've had a 930 cv set in a box for years, l thought it a good idea at one time, talking with the guy who builds transmissions for me, he commented that he felt it's best to have something cheap and easy to fix, like a fuse, rather than to risk an expensive repair bill.
that made perfect sense to me. _________________ markswagen {mobile mechanic} san diego area all early VW's cared for.
619 201 0310 |
Sodo Samba Member
Joined: July 06, 2007 Posts: 10907 Location: Western WA
Posted: Sat Jul 13, 2024 7:57 am Post subject: Re: GoWesty HD 930 Axle kit |
I too am worries by the difficulty of obtaining 930 axles, and haven't had much problem breaking the smaller CVs.
I think of CVs as a consumable.
They last pretty long and don't fail catastrophically and replacements are readily available. (except Syncro front CVs could go NLA)
CVs tend to fail due to:
not enough grease
boot failure
miles
over-inspection
I do wonder if "CV clocking" results in the axle staying "centered" and thus concentrating the wear in one location.
I think keeping the axle centered would be great for a race-buggy
....that cycles long-travel suspension from full compression to full droop repeatedly
while the engine is screaming at the top of its torque output,
and the buggy gets new CVs every year whether it needs it or not.
But I don't see these race-buggy conditions as directly applicable to our RVs,
droning down the highway or puttering down a gravel road,
while hoping for 100,000 miles service from a new CV.
On our RVs (I think) it's probably better if the axle floats in/out in the various driving conditions,
spreading, circulating the grease & the wear across a larger area of the star and grooves.
My curiosities:
Those who have been clocking CV axles.... could you post pics of the ball-wear pattern on the inner and outer tracks?
And do your axles "plunge" in & out easily in the boots? Some boots are harder, some are softer.
Thanks! _________________
'87 Tintop, EJ25, cooled filtered (original) gearbox
....KTMs, GasGas, SPOT mtb
All Vanagons should do this:
Add direct starter-to-chassis cable THEN delete ground strap at front transaxle mount.
The best time to do this mod was in 2010. The second best time is TODAY.
If your starter is slow, this is MORE important. |
gbrandt Samba Member
Posted: Sat Jul 13, 2024 8:13 am Post subject: Re: GoWesty HD 930 Axle kit |
I was constantly break CV's on my 1.5" lifted van and peloquin. Went with the 930 from GW and have not broken once since.
I do remove and degrease every year or so and I polished before install. _________________ 'Lucky' our 1987 Red Westy, ALH 1.9 TDI
We've driven in 49 countries and 5 continents to date
Canada to Argentina and back, 2015 to 2017.
Canada to Europe and back (including Turkey, Morocco and Iceland), 2017 to 2019
Mexico 2022-2023
https://www.instagram.com/live.travel.play/
http://livetravelplay.ca |
