thomast Samba Member
Posted: Mon Jan 21, 2019 8:20 am Post subject: non-power steering, steering wheel - going smaller - bad idea? |
As I still ponder my engine swap choices and as I put aside a starter issue / coolant leak in sub zero weather issue that happened this weekend...just breath...., I've been contemplating a steering wheel swap for a while.
I have the larger (brown) 1985 non-power steering wheel steering wheel. Not a fan of how large it is and have thought about going smaller. I'm wondering if anyone has tried putting a smaller later model wheel on or a Eurovan steering wheel on a non-steering wheel van? Would it dramatically change how hard it would be to turn the wheel? _________________ 1986 Westy Syncro SVX |
shagginwagon83 Samba Member
Joined: February 07, 2016 Posts: 3804 Location: VA/TN
Posted: Mon Jan 21, 2019 8:28 am Post subject: Re: non-power steering, steering wheel - going smaller - bad idea? |
I'm in the same boat. I dig the huge wheel. I think it would be hard to turn (especially parallel parking).
This is how I feel driving the van
_________________ Brandon
Instagram @joannthevan |
bobbyblack Samba Member
Joined: May 21, 2015 Posts: 4353 Location: United States, Iowa
Posted: Mon Jan 21, 2019 8:44 am Post subject: Re: non-power steering, steering wheel - going smaller - bad idea? |
Small wheel on manual is only super difficult to turn if you are not moving. Once you get going a bit, it can be turned more easily. My upper arm strength gets a workout when I drive my mom's 1951 McCormics/Farmall M. Many folks with modern vehicles just don't get the idea you got to allow the wheels to move a bit in order to turn if you don't have power steering boost. _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
Posted: Mon Jan 21, 2019 8:48 am Post subject: Re: non-power steering, steering wheel - going smaller - bad idea? |
Also OP some people are adding electric power steering to their manual steering vans. _________________ Brandon
wcdennis Samba Member
Joined: July 20, 2004 Posts: 955 Location: Winston-Salem NC
Posted: Mon Jan 21, 2019 8:51 am Post subject: Re: non-power steering, steering wheel - going smaller - bad idea? |
You could put some marks on the spokes of your wheel at the diameter of the smaller wheel and try turning with your hands in that "choked-in" position. Not exactly the same motion, but it would give you an idea of how much extra force you would need to exert. |
?Waldo? Samba Member
Posted: Mon Jan 21, 2019 8:55 am Post subject: Re: non-power steering, steering wheel - going smaller - bad idea? |
I prefer the larger wheel for better visibility of the gauges. |
CanStan Samba Member
Joined: October 16, 2005 Posts: 1039 Location: Calgary, AB
Posted: Mon Jan 21, 2019 9:31 am Post subject: Re: non-power steering, steering wheel - going smaller - bad idea? |
?Waldo? wrote: |
Agreed! I had an '84 with the bigger non-power steering wheel. I replaced it with a later wheel that was in better condition. I didn't really notice much difference in the strength it took to turn it. As bobbyblack says, without power steering it's easier to make sure you're moving while turning the steering wheel.
What frustrated me was how the smaller wheel blocked my view of the gauges. I know it depends a lot on your height and seating position, but for me the new wheel covered up the tops of the speedo and tach where the needles spend most of their time on highway drives. I was constantly leaning over or trying to crouch down to see them. If memory serves me right, the P/S wheel is about 2" smaller in diameter. So if the top of the steering wheel is right at the top of your gauges now, it will block the view with the new wheel.
Maybe it's not a make or break to some, but personally it bothered me enough I eventually switched back to the original wheel. |
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
Posted: Mon Jan 21, 2019 9:32 am Post subject: Re: non-power steering, steering wheel - going smaller - bad idea? |
?Waldo? wrote: |
Exactly! I also prefer the way the bigger wheel keeps my chest open and puts the wheel rim in my hands with my arms on the rests. Its much less tiring to drive than the smaller wheel. _________________ '84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com |
Posted: Mon Jan 21, 2019 10:22 am Post subject: Re: non-power steering, steering wheel - going smaller - bad idea? |
Thanks for the input. Never dawned on my about it blocking the instrument panel. So, with later model vans, is the steering wheel blocking the panel, or are the interior dimension of the vans different? _________________ 1986 Westy Syncro SVX |
Paulbeard Samba Member
Posted: Mon Jan 21, 2019 10:37 am Post subject: Re: non-power steering, steering wheel - going smaller - bad idea? |
?Waldo? wrote: |
Why I swapped the small P/S wheel for the non-P/S one.
thomast wrote: |
So, with later model vans, is the steering wheel blocking the panel, or are the interior dimension of the vans different? |
The console/panel is the same. You lose the ability to see the tops of the gauges (like your highway speed and RPMs above 2000). Not ideal. Maybe take a piece of paper and cut an arc that represents the visibility you would lose and tape it to the wheel and see for yourself. _________________ Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
Formerly -> Steward of a 73 Super Beetle (Beater) and 67 Beetle 1300 (Little Max) both names by POs
— dhaavers |
Gnarlodious Samba Member
Joined: September 28, 2013 Posts: 2323 Location: Adobe Jungle USA
Posted: Mon Jan 21, 2019 11:03 am Post subject: Re: non-power steering, steering wheel - going smaller - bad idea? |
It was damned hard steering after bolting on the wide tires (225/55R17) so I installed power steering. I originally thought I would upgrade to the PS wheel for more leg clearance getting in and out. However it turned out the PS was weaker than I expected. After 18 months of PS I have completely lost the desire to run a smaller steering wheel.
FYI this ’83 has the PS spindles and the diesel Jetta pump. If you put PS on the manual steering spindles you get more leverage. I’ve been told the Jetta pump is a big improvement over the Vanagon pump, but that would be unverified. _________________ Vanagon ’83 diesel AAZ w/Giles injection, 5spd 4.57R&P+TBD and a '78 diesel Rabbit |
Timwhy Samba Member
Posted: Tue Jan 22, 2019 3:49 am Post subject: Re: non-power steering, steering wheel - going smaller - bad idea? |
This Jetta wheel is in both of my vans. My Tintop had a bad PS Rack and I ran with no belt for a while turning it into a manual rack.
It really was not hard to turn the wheel and my wife had no problem driving it like that either.
You will lose the tops of the gauges with the smaller wheel but you can still see the needles and you should know where they are
pointing too regardless of the wheel size.
For me I like the smaller wheel and all of its drawbacks.
_________________ '15 Audi A3 Quattro
'09 VW Tiguan (dead)
'87 VW Westy
'91 Tin Top
'90 Cabby
http://www.youtube.com/user/TIMWHY2?feature=mhee |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32639 Location: Reading Pennsylvania
Abscate Samba Member
Joined: October 05, 2014 Posts: 22671 Location: NYC/Upstate/ROW
Posted: Tue Jan 22, 2019 4:57 am Post subject: Re: non-power steering, steering wheel - going smaller - bad idea? |
I think he's just a cutout. They don't think much. _________________ .ssS! |
