RocketBox Samba Member
Joined: March 20, 2014 Posts: 354 Location: Boise, ID
Posted: Wed Sep 24, 2014 7:36 am Post subject: Awesome tool - Harbor freight engine support beam! |
i was looking into getting an engine hoist, but really hated the idea of storing such a bulky thing. I then found a Engine Support beam that Harbor Freight sells. They didn't have any on display, but the local store had them in stock. I just used it for dropping and raising the engine and I gotta say that this makes the job SOOOO much better compared to jacking and muscling the engine around and lowering transmission and all the other crazy stuff i had to do the first time i installed the engine. I've seen some home made ones, but for the cost and time it saved me, i thought it was a great investment.
It's this guy: http://www.harborfreight.com/1000-lb-capacity-engine-support-bar-96524.html
Just thought i'd share the experience of using this thing... _________________ 84 Vanagon - tintop, 1.9L wbx. Complete Rebuild done August 2014. 2000~ miles on it so far... SOLD
80 Vanagon Camper ASI Riveria - subaru 2.2 conversion project. 1993 Subary legacy donor car + Riveria = AWESOME! |
Gnarlodious  Samba Member
Joined: September 28, 2013 Posts: 2412 Location: Adobe Jungle USA
Posted: Wed Sep 24, 2014 7:44 am Post subject: |
You should post this in the "Official Harbor Freight win or lose thread:
http://www.thesamba.com/vw/forum/viewtopic.php?t=512248
Are you saying it bridges the deck to hold up the engine? Looks like a good product for Vanagons! Post a photo in use. _________________ Vanagon ’83 diesel AAZ w/Giles injection, 5spd 4.57R&P+TBD and a '78 diesel Rabbit |
Posted: Wed Sep 24, 2014 8:28 am Post subject: |
yeah - it spans the engine bay nicely. here it is in action...
raising and lowering done using the threaded 'hooks'. i liked the fact that you can move the engine forward and backward as the beam has a channel that the hooks ride in. each hook is about 16 inches long - long enough if your van isn't raised up on jacks to get it into place without having to reset in mid-lift. It also makes the engle adjustment easy to get the bolts lined up between the transmission and engine.
I'll post it in the HFT - win/loose also _________________ 84 Vanagon - tintop, 1.9L wbx. Complete Rebuild done August 2014. 2000~ miles on it so far... SOLD
williamM Samba Member
Joined: August 07, 2008 Posts: 4343 Location: southwest Arizona
Posted: Wed Sep 24, 2014 8:54 am Post subject: |
Or 2 cinder blocks and a water pipe.- old school/shade tree- and you don't need a hook for the wall to store it. _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any! |
?Waldo? Samba Member
Joined: February 22, 2006 Posts: 10156 Location: Where?
Posted: Wed Sep 24, 2014 9:52 am Post subject: |
I've used this to R+R quite a few vanagon engines in the last decade:
dobryan  Samba Member
Joined: March 24, 2006 Posts: 17374 Location: Brookeville, MD
campism Samba Member
Joined: September 07, 2007 Posts: 4720 Location: Richmond VA
Posted: Wed Sep 24, 2014 10:05 am Post subject: |
| dobryan wrote: |
| ^^^ Cool, where can I get that disembodied hand to help me on my projects? :wink: |
Bicycle repair has long featured tools named Third Hand and Fourth Hand for brake repair. Probably the same thing, only different. _________________ '87 Westy in Wolfram Grey Metallic, tragically crushed by a falling hickory tree in my own driveway and now gone, leaving me Vanagonless and with no plans to replace it, alas. |
danfromsyr Samba Member
Joined: March 01, 2004 Posts: 15413 Location: Syracuse, NY
Posted: Wed Sep 24, 2014 10:07 am Post subject: |
certainly looks safer than the metal sawhorse.
| Abscate wrote: |
| These are the reasons we have words like “wanker” |
Posted: Wed Sep 24, 2014 10:51 am Post subject: |
i was totally considering both those options.... matter of fact - i had purchased the metal sawhorses for the same damn thing, then did some searching and found the beam. I also considered the 2x4 option too... but thought it would take me 3x as long to build it and it wouldn't be as stable and it would have cost about 1/2 the price...
in the end, i think it is a pretty good tool for droping and lifting a vanagon engine if you don't have and want a hoist. _________________ 84 Vanagon - tintop, 1.9L wbx. Complete Rebuild done August 2014. 2000~ miles on it so far... SOLD
Posted: Wed Sep 24, 2014 10:58 am Post subject: |
| If you are talking about my 2x4/allthread version, it is completely 100% stable, cost about $15 and took 1/2hr to make or an hour if you include the trip to get the materials. The three attachment points and the ability to slide the upper 2x4s means that you can achieve any desired angle/position and have it completely stable. That makes aligning the input shaft/clutch very easy. The metal sawhorse or single ratchet strap both look terribly dysfunctional in comparison. The HF support you used looks almost as nicely functional as my 3-point "hoist". |
sanchius  Samba Member
Merian Samba Member
Posted: Wed Sep 24, 2014 4:05 pm Post subject: |
| williamM wrote: |
| Or 2 cinder blocks and a water pipe.- old school/shade tree- and you don't need a hook for the wall to store it. |
but you will need a really good trauma surgeon after catastrophic failure of the cinder blocks under compression |
Posted: Wed Sep 24, 2014 6:01 pm Post subject: |
The twin steel beams are fine, but they sure aren't the weakest part of that tool and whatever tool you use is only as strong as its weakest part. I'd be more concerned about the un-gussetted verticals and the hooks. Regardless, it looks up to the task.
Cost savings is not at all the reason I have gone with the 2x4 setup. The $60 cost difference is a non-issue. I continue to use that setup because it very accurately places the engine at whatever position or angle I desire and is totally stable when it does. The 2x4 setup is a darn sight safer than the stamped steel sawhorse with come-along. I have used the 2x4s to remove and install a dozen or so engines or engine and transmission combined without any issue. I used it to install my ALH TDI and automatic transmission at the same time. The ALH weighs a fair amount more than a WBX and the automatic weighs more than the manual trans. Regardless, I don't ever get under any engine until it is bolted in place regardless of what contraption is holding it up. |
Posted: Fri Sep 26, 2014 7:54 pm Post subject: |
| Merian wrote: |
| williamM wrote: |
Was thinking that when we signed up for MEDFLIGHT.
Had more grief trying to keep iit balanced on the roller jack. so cinder blocks were actually an improvement.
Weirdest one was a dodge van 318 extraction out the passengers side door using 2 ladders and a pipe in a pipe to slide it all sideways. _________________ some days I get up and just sit and think. Some days I just sit.
Bicycle019 Samba Member
Posted: Fri Sep 26, 2014 11:33 pm Post subject: |
Have the HF tool, used it when swapping out the engine in our van last spring for one that didn't spray coolant out the head.
I found it wasn't enough just to use the support beam, I supplemented with a floor jack underneath to help raise the motor. I felt like just using the supplied chains and threaded rods to do the heavy lifting wasn't enough support for my level of comfort, plus it takes a while to spin the motor up, readjust the chain, and spin some more. What the beam and chain setup does do well is allow you to position the motor much better than just using a floor jack when getting it lined up and bolted in. For me the combo of jack and support beam worked well and took out a lot of the drama and turned this into a pretty easy one man job.
Glad I bought mine, also works well holding up engines on FWD cars as well when ever you have to take a transmission off. Easy to store as well if you don't have a lot of space in your garage. _________________ '89 Vanagon Whitestar
'84 Jetta GLI - built 2.0 ABA
'16 GTI Performance Pack
'17 Golf AllTrack (wife) |
chazz79 Samba Member
Posted: Sat Sep 27, 2014 4:40 am Post subject: |
I have a cheap winch screwed to a board that does the same thing. I think it's a 70.00 hf cheapie but a buddy gave it to me because it wasn't reversible.
It works great! You can look from below the vehicle and sight align items as the engine is raised by the remote. This is handy when you're trying not to pinch anything and are lining up bolt holes by yourself.
I've done this on typical american stuff by strapping the same winch to a peice of 12' angle iron slid through the trusses of my shop. It works out pretty sweet either way. As you get older you keep thinking of better ways to save your back. _________________ One day as a lion, or a lifetime as lamb
The green monster in bits and peices: http://www.thesamba.com/vw/forum/viewtopic.php?t=332556&highlight=green+monster |
Posted: Sat Sep 27, 2014 7:16 am Post subject: |
| Andrew A. Libby wrote: |
I agree completely, these are all excellent points.
I always have 1 or 2 floor jacks and a transmission jack in play as well, plus several jackstands as backup. _________________ The Syncro years (2005-16) - The 2WD years (2017-23) - In Hoosierland (2023-now)
Westy & WBX rebuild spreadsheet - Sanchius & Tuna: The Video
Your gold star membership keeps this awesome list going! |
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10356 Location: N. Idaho
Posted: Sat Sep 27, 2014 8:34 am Post subject: |
Andrew,
Care to share enough info so I can exactly duplicate your rig? I will be yanking a WBX and auto together next week from a yard and it would be great simply to do that. Lengths of boards, length of rod, fitting on bottom of rods, etc. Thanks!
DougM _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1993 Toyota LandCruiser, 2002 BMW 325iX, 1982 Toyota Sunrader |
