karghia74 Samba Member
Posted: Mon Oct 13, 2014 7:02 pm Post subject: 1969 Autostick |
My second Kamrann Gihia, I bought her couple of months ago. 1969 Autostick with what seems to be an original 47K miles.
All things considered the car is mostly unmolested with original paint, so far I replaced oil, spark plugs, points, wire set etc. and engine is burring like a Siamese and just now getting to look into the transmission which had me scratching my head and asking for help.
The transmission will go in all gears while the engine is off, once engine is on I am unable to shift and I am getting the dreaded grinding noise if I try to force shift into any of the gears.
Using my Bentley I was able to
1. Clean and adjust shifter contact.
2. Verify control valve solenoid function.
3. Checked shifter linkage and it looks perfect with minimal play
4. Checked all vacuum hoses and reservoir
5. Checked servo and watched it operate as it supposed to when engine is running and shifter is moved to close the circuit.
6. Checked the clutch operating lever and nothing is loose or broken.
At this point I reached the end of the troubleshooting table in the manual with no luck on locating the problem; any idea on what to look for next? Also I already tried vwar.org and it seems to be having an issue as I canโt reach the forum.
Couple of pictures to sweeten the deal
_________________ 69 Ghia Autostick (Also Gone)
68 Ghia (gone)
560SEC (gone)
530I (gone but not forgotten)
1969
http://www.thesamba.com/vw/forum/viewtopic.php?t=609541
1968
http://www.thesamba.com/vw/forum/viewtopic.php?t=459544 |
jwold Samba Member
Joined: September 30, 2008 Posts: 2088 Location: Portland, OR
Posted: Tue Oct 14, 2014 10:49 am Post subject: |
Nice ghia! I had a 68 autostick.
You have a broken, shorting or disconnected wire that runs to the shifter lever.
Check down under the carpet by the shifter, that wire gets brittle and cracks.
Also check the fuse that feeds the wire...it might be burned out. |
Posted: Tue Oct 14, 2014 11:03 am Post subject: |
| jwold wrote: |
Thank you, I love it because despite of the somewhat rough look it is pretty much rust free
Both wire and fuse were replaced, I think I ruled out the shifter contact and control valve since the servo is operating as expected when the shifter is moved slightly. I am going to check the clutch play tonight since I am at a loss at this point of what the root cause is  _________________ 69 Ghia Autostick (Also Gone)
68 Ghia (gone)
560SEC (gone)
1969
1968
cool karmann collected Samba Member
Joined: November 23, 2008 Posts: 631 Location: Oxford, U.K.
Posted: Tue Oct 14, 2014 1:26 pm Post subject: |
Oooh a sunset red 69 in original paint, what's not to like  |
jwold Samba Member
Posted: Tue Oct 14, 2014 8:53 pm Post subject: |
| I love it when it turns out to be something easy! Congrats! |
Posted: Mon Nov 10, 2014 9:29 pm Post subject: |
I had a lot done since my last post, to list a few. Electric mostly done and now I have turn signals and brake light.
Brakes completed with rebuilt calipers, wheel cylinders and brand new master cylinders and hoses.
Accelerator and brake cluster is once again functional with new accelerator cable, ATF and gearbox oil change. I am sure I forget other stuff but then in an ugly turn of event I managed to strip one of the rear stub axles
After too much head scratching to figure out the root cause specially since this is not my first rodeo dealing with those nasty suckers I found out that the axle nuts I received were the wrong ones!
The wrong nut is 5mm longer than the correct one and in turn it never clears the cotter pin hole which was the reason I continued to tighten the nut until I stripped the axle.
I searched the forum for similar experience but couldnโt locate any, maybe I did not search long enough. Anyway the wrong nuts were ordered from Rockauto but they are also the exact ones that autozone sells so just a heads up.
Below is a comparison of the two
68 Ghia (gone)
560SEC (gone)
1969
1968
Abscate Samba Member
Joined: October 05, 2014 Posts: 24454 Location: NYC/Upstate/ROW
Posted: Tue Nov 11, 2014 1:01 am Post subject: |
Nasty business on that axle nut. At least it's an IRs transmission and you can replace the stub axle! Are stub axles on standard and auto transmissions the same?? _________________ ๐บ๐ธ ๐บ๐ธ ๐บ๐ธ ๐บ๐ธ ๐บ๐ธ ๐บ๐ธ ๐บ๐ธ ๐ ๐ ๐ |
Posted: Tue Nov 11, 2014 8:11 am Post subject: |
| Abscate wrote: |
| Nasty business on that axle nut. At least it's an IRs transmission and you can replace the stub axle! Are stub axles on standard and auto transmissions the same?? |
Agreed, the two axle nuts look so damn similar to the unsuspecting eyes yet the wrong one will have you turn in circles literally.
The stub axles are the same, I already found a pair of originals here in the classifieds, (thanks Mike)
Hopefully I will be back on track by Friday. keep an eye out for those bad nuts! folks. _________________ 69 Ghia Autostick (Also Gone)
68 Ghia (gone)
560SEC (gone)
1969
1968
volksaddict Samba Member
Posted: Thu Nov 13, 2014 8:51 am Post subject: |
| Hey where are the gears on an autostick? 1st is where 2nd should be right? then upshift to where 3rd should be and on to high gear where 4th is supposed to be on a vw? So where is reverse? |
Posted: Fri Nov 14, 2014 7:20 am Post subject: |
| Thanks! |
NOVA Airhead Samba Member
Joined: July 20, 2005 Posts: 5225 Location: Richmond, VA
Posted: Fri Nov 14, 2014 8:49 am Post subject: |
Reverse is down and up.
FWIW I use the Low Range most of the time. It just seems to get the car going better.
I have seen some people say that running through the three gears puts less stress on the torque converter. _________________ Ghia Owner Emeritus |
jwold Samba Member
Posted: Fri Nov 14, 2014 2:56 pm Post subject: |
| That's the way I used to drive mine, like a 3 speed. |
