cfelke Samba Member
Joined: October 05, 2007 Posts: 136 Location: Greenwood, Indiana
Posted: Thu Nov 06, 2014 10:26 am Post subject: My new 1964 Beetle project |
My 1964 Volkswagen Beetle as it was found after sitting broke down in a garage for 37 years. There is some rust (it's from Indiana) but the heater channels are pretty solid and not a bit of rust in the floor pan. The car was covered with a sheet of plastic when the roof of the garage started leaking on it. Look at all of that mold on the door panels from the moisture not being able to escape! These photos are from the first day I got her!
cfelke Samba Member
Posted: Thu Nov 06, 2014 10:42 am Post subject: |
Next morning I decided to clean her up. The paint shined up pretty well with a little rubbing compound and elbow grease. The door panels look much better after scrubbing the mold. The seats look much better after removing the seat covers and finding the original seats under them.
VolkswagenVMan Samba Member
Joined: September 25, 2003 Posts: 186 Location: Valparaiso , Indiana
Posted: Thu Nov 06, 2014 11:02 am Post subject: |
The Ford hubcaps are interesting! _________________ Master Tech at Team Volkswagen
VW's at work , VW's at home!!!!
1967 EMPI GTV
1966 Bug early
1966 Bug late
2000 New Beetle 2.0l 200,000 miles and going! |
cfelke Samba Member
Posted: Thu Nov 06, 2014 11:06 am Post subject: |
Plans for the beetle are not to have a show car but a semi ratty daily driver. I bought a stainless roof rack, all new brake parts, cb performance 2" narrowed beam. I plan to drop the rear one notch. I got rid of the 14" Ford wheels and adapters to use stock smoothies with 145/65/15s on the front. Now the work begins! |
WD-40 Samba Member
Posted: Thu Nov 06, 2014 11:20 am Post subject: |
Looks like it is cleaning up nicely!
What's the story on those wheels? _________________ "The new Volkswagen 1303. We've made so many improvements, they're beginning to show." |
cfelke Samba Member
Posted: Thu Nov 06, 2014 11:24 am Post subject: |
Those are what was on it when I got it. They were 14" ford wheels, with pretty cool looking Allstate whitewalls but they had to go plus they had been on the car since 1971 (yes, the receipt for the tires was in the glove box). Stock smoothies are going on her! |
siemonw Samba Member
Posted: Thu Nov 06, 2014 11:29 am Post subject: |
Nice find. |
Posted: Thu Nov 06, 2014 11:43 am Post subject: |
Its a very nice find!! _________________ Master Tech at Team Volkswagen
1967 EMPI GTV
1966 Bug early
1966 Bug late
v_dub_ya Samba Member
Joined: April 07, 2003 Posts: 85 Location: North Carolina
flyboy161 Samba Member
Joined: December 26, 2009 Posts: 2091 Location: Perry, GA
cfelke Samba Member
Posted: Thu Nov 06, 2014 12:00 pm Post subject: |
Nice, wish mine was that clean!
Here is my 64 I built back in like 91 when I got out of high school.
before (just a shell)
After (so not what I would do with a car these days but at 19 years old, your ideas are different from what they are when you get older, although I would still graft a ragtop into a hardtop today)
cfelke Samba Member
Posted: Tue Nov 11, 2014 11:40 am Post subject: |
Had the day off and wanted to lift the body from the pan. Nobody is around to help so I decided to drop the pan instead of lifting the body Much easier on my back). The floorpan slid out pretty easy! Now I can see how bad the cancer is and get started on this project.
cfelke Samba Member
Posted: Tue Nov 11, 2014 4:17 pm Post subject: |
Got my new front beam today along with a bunch of other parts from cb performance. It would have been nice had they at least put tape over the holes in the beam so it wasn't filled with packing peanuts.
bladerunner80 Samba Member
Joined: February 13, 2011 Posts: 255 Location: Fife, WA
57BLITZ Samba Member
Joined: June 12, 2012 Posts: 2385 Location: DEEK - U.S.A.
Posted: Tue Nov 11, 2014 7:41 pm Post subject: |
COOL!!!
Are ya goin' with anthracite? _________________ Jesucristo es mi Seņor y Salvador! |
cfelke Samba Member
Posted: Wed Nov 12, 2014 4:21 am Post subject: |
I do plan on going with anthracite but It will be a while before she gets painted. I am guessing she will be red with gray primer for the first year.
Got the front beam un-assembled and now time for cleaning and painting, then the new beam goes on.
Before
After
cfelke Samba Member
Posted: Sun Nov 16, 2014 5:35 pm Post subject: |
Ok, I have a question... The short (driver side) tie rod end is bent on one end. Is this how it is supposed to look? My old one was straight on both ends! It looks like it should work fine if I use that end on the steering box drop arm.
I am getting her together slowly, it will take a while to get the alignment figured out plus I have no idea what angle the steering box will be until I put the body back on.
Posted: Sun Nov 16, 2014 7:47 pm Post subject: |
cfelke wrote: |
It looks like it should work fine if I use that end on the steering box drop arm. |
According to both of my manuals, you are correct.
My guess is that some point, the P.O. used a right-side/outer tie-rod end there instead of the proper left-side/inner tie-rod end. _________________ Jesucristo es mi Seņor y Salvador! |
cfelke Samba Member
Posted: Sun Nov 16, 2014 7:55 pm Post subject: |
Thanks 57blitz |
MacLeod Willy Samba Member
Joined: February 18, 2014 Posts: 933 Location: Ontario Canada
Posted: Sun Nov 16, 2014 8:40 pm Post subject: build |
WOW you should have it running by the end of the week!
Nice cleanup on it. |
