Anovib Samba Member
Posted: Thu Dec 18, 2014 7:58 am Post subject: Transmission I'd help |
I have a 73 camper bus. I know the engine is not original. Coded AK
I need help identifying the transmission. Code CK04
The transaxle has two codes. 002301173A and 002301103D
Thanks in advance |
borninabus Samba R&D Dept.
Joined: May 18, 2006 Posts: 4539 Location: Arizona Highways
Posted: Thu Dec 18, 2014 8:13 am Post subject: |
OK, I'd help.
you have a "3 rib" or 002 trans on your hands.
it is era correct for your bus, but if it is "original" to your bus may be hard to determine. _________________ 88 Van WBX, A/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport |
Tcash Samba Member
Posted: Thu Dec 18, 2014 9:10 am Post subject: |
Trans codes |
Anovib Samba Member
Posted: Thu Dec 18, 2014 9:46 am Post subject: |
Thanks.
The AK 1600 is a dog and the bus cannot get out of its own way. Not sure what I will do either build it up or replace. Biggest concern is if the present transmission and transaxle can handle the load |
mikedjames Samba Member
Joined: July 02, 2012 Posts: 2745 Location: Hamble, Hampshire, UK
Posted: Thu Dec 18, 2014 10:40 am Post subject: |
Its unlikely anything you do with a stock 1600 will overload any transmission.
And if the 1600 is running well, there are one or two small Japanese and Korean "city cars" that your bus will out-drag at the lights _________________ Ancient vehicles and vessels
pioneer1 Samba Member
Joined: February 11, 2008 Posts: 2069 Location: Ontario Canada
Posted: Fri Jul 20, 2018 1:19 pm Post subject: Re: Transmission I'd help |
I've searched but I just need a simple answer please. I'm restoring a 76 westy,the engine/transmission were not installed when I brought it home.
The engine numbers are right for the year.
Before I send out the transmission for a refresh I need to know if is right. it's a CK 18 12 2
4
002301103D
Thanks _________________ "Always waiting for tomorrow ruined everything"
'85 Porsche 911 Targa
'76 Westfalia project |
CarlosZ Samba Member
Joined: April 23, 2016 Posts: 319 Location: Los Angeles
Posted: Fri Jul 20, 2018 2:35 pm Post subject: |
mikedjames wrote: |
And if the 1600 is running well, there are one or two small Japanese and Korean "city cars" that your bus will out-drag at the lights |
I’m in Tokyo right now. These ”Kei” cars over here will probably smoke a stock 1600 bus. Under 650cc but can out rev the type 4. HP to weight ratio is a big factor. You’re correct. There may be a slow dog that the bus might take, but it’s rare. |
SGKent Samba Member
Posted: Fri Jul 20, 2018 2:38 pm Post subject: Re: Transmission I'd help |
pioneer1 wrote: |
4
002301103D
Thanks |
a 1976 bus can be either an early or late 1976. The late 1976 is a 2L "GD" engine. The transmission would be a six rib "CP" or later.
Everything after 1973 is CN or later.
https://www.coolairvw.co.uk/Category/0/VW_Model_Information~Baywindow~Gearbox_Codes.html
Also
_________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Fri Jul 20, 2018 2:48 pm Post subject: Re: Transmission I'd help |
Thanks SG. I guess what I need to know now is will this transmission take me down the road or do I need the 6 rib for a comfortable ride? _________________ "Always waiting for tomorrow ruined everything"
Posted: Fri Jul 20, 2018 3:30 pm Post subject: Re: Transmission I'd help |
The six rib was mated with the 2.0L engine and should do you fine. There is always an off chance that the gearing has been changed though for some reason. You do not want longer gearing as that will kill your acceleration and hill climbing abilities. Stock is what you want. |
Posted: Fri Jul 20, 2018 3:36 pm Post subject: Re: Transmission I'd help |
Thanks. Shopping for 6 rib. _________________ "Always waiting for tomorrow ruined everything"
Posted: Fri Jul 20, 2018 3:56 pm Post subject: Re: Transmission I'd help |
ivwshane Samba Member
Joined: May 19, 2011 Posts: 1920 Location: Sacramento ca
Posted: Fri Jul 20, 2018 4:40 pm Post subject: Re: Transmission I'd help |
pioneer1 wrote: |
Thanks. Shopping for 6 rib. |
Good luck! Hopefully you'll find something local. All the trans places I called didn't have a 6 rib to buy outright.
I just bought one from bustedbus.com and they may have one left ~700. I've seen them in unknown condition going for $450-$900.
What year was the 5 rib for? 73-74? _________________ 77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab |
Tcash Samba Member
