Just had Bus Depot (AVP) rebuilt 2.1 installed
DJSNOWFLAKE
DJSNOWFLAKE is offline
PostPosted: Tue Feb 25, 2014 9:50 pm    Post subject: Just had Bus Depot (AVP) rebuilt 2.1 installed Reply with quote
Im about to get my 86 wolfy out of the shop, Its having a Bus Depot rebuilt 2.1 installed, also new clutch, radiator, exhaust, belts hoses etc… Ive realized that Bus Depot uses AVP to rebuild their engines and come to find out they don't have a very good reputation.. so my question is how many people out there have used Bus depot/AVP rebuilds and whats your experience?
The only info I can find is from the early 2000's and the newest being from 2006, Im hoping AVP has improved since then..
am I totally F'd or do you think ill be okay?
Jeff's Old Volks Home
Jeff's Old Volks Home is offline
PostPosted: Wed Feb 26, 2014 4:16 am    Post subject: Re: just had bus depot (AVP) rebuilt 2.1 installed Reply with quote
What is the warranty? BusDepot is the one you paid for the engine, they stand behind everything they sell just fine. We all have things to worry about, don't waste your worry about something that hasn't happened... Save it for something better. Wink
Jeff
www.jeffsoldvolkshome.com
2004 Jetta TDi Wagon
2002 Smyth Ute TDi
1990 Vanagon weekender Syncro AAZ
1987 Syncro Doka AAZ...soon to be TDI Smile
2014 DL650ABS Xpedition
1986 Weekender Syncro (Under construction)
1987 Westfalia (Under construction)
1987 Syncro Single cab
djkeev
djkeev is offline
PostPosted: Wed Feb 26, 2014 5:20 am    Post subject: Reply with quote
I got Two AVP "remanufactured" heads.
They were so poorly machined and so lacking in critical quality control details that I returned them. My concern was excessive pitting in the green Oring seal surface and being flycut to a larger diameter in the green ORing area than the factory cylinder cut diameter.
I was accused by AVP in so many words as being a picky customer!
".........if the customer is uncomfortable with those, then we probably won't be able to make him happy......."
In their defense, they did not fight taking the heads back and did offer to look for better heads that weren't as decayed / badly cut, but I declined.
If must look for better heads than you send out routinely....... Do I really want them? And even saying that ....... yes, there are better examples available, I will look for them if you want........tells me that they KNOW what quality they are shipping out!
I should note, Bus Depot was great handling my concerns!
I do question the wisdom of selling the product and did mention my concerns to them. Who knows? They probably have me classified as a problem customer! Rolling Eyes
Dave
Ghia
Vanagon
Beetle
insyncro
Banned
insyncro is offline
PostPosted: Wed Feb 26, 2014 7:31 am    Post subject: Reply with quote
RonS and BD are awesome about warranty issues.
Sure there are more detailed engine rebuilders, but the cost is much higher.
Just run it.
DJSNOWFLAKE
PostPosted: Wed Feb 26, 2014 7:18 pm    Post subject: Reply with quote
Okay i feel a little better, I called bus depot and they said that most of the bad reviews on AVP are old (which is what i noticed as well) they say they sell about an engine a week, so I can't imagine them selling that many bad engines as there would be more feedback out there..
Im going to stop worrying, and start looking forward to driving this beast..
thatvwbusguy
thatvwbusguy is offline
PostPosted: Wed Feb 26, 2014 11:26 pm    Post subject: Reply with quote
AVP is usually considered one of the better large volume engine rebuilders. If you had purchased a GEX rebuild instead, then you would really have something to worry about Wink
Jay Brown
'85 Zetec Westfalia
Newmarket, NH
If you want others to be happy, practice compassion.
If you want to be happy, practice compassion.
MightyChin
MightyChin is offline
PostPosted: Tue Mar 18, 2014 8:56 am    Post subject: Reply with quote
@djsnowflake any issues with the install? Any issues to report, big or small? How's the break in going?
My vanagon is in the shop right now getting an AVP rebuild installed. The engine is actually in place, but we are getting lots of oily smoke when it heats up and it's running rough. My mechanic is working through it and I'm wondering if anyone else on the samba has had recent experience with an AVP engine.
HeadyBrosevelt
HeadyBrosevelt is offline
PostPosted: Thu Apr 24, 2014 2:07 pm    Post subject: Reply with quote
djsnowflake- how is that engine working out for you. i am currently in the process of wanting to put an engine in my '82 aircooled so i can rebuild mine (i lost compression). i am split between trying to find a decent used one or getting a reasonably priced refurbished. the bus depot is on my radar because of their good reputation, but i have heard mixed reports about AVP. If you get a chance, let me know your thoughts. Thanks!
Randy in Maine
Randy in Maine is offline
PostPosted: Thu Apr 24, 2014 2:36 pm    Post subject: Reply with quote
You should also consider this place for an aircooled engine....
http://www.headflowmasters.com/
Key words...new improved heads.
LB Sammy
LB Sammy is offline
PostPosted: Wed Feb 18, 2015 9:35 am    Post subject: Mid america motorworks?? Reply with quote
great info in here, thanks! Anyone have experience with purchasing newly manufactured engines from Mid america motorworks? I'm looking into one for my 81 aircooled Vanagon. Thanks in advanced!
thatvwbusguy
PostPosted: Wed Feb 18, 2015 10:05 am    Post subject: Reply with quote
It looks like Mid America Motorworks only sells remanufactured (rebuilt) engines for the Vanagon: http://www.mamotorworks.com/VW/product/remanufactured-engine-2000cc-with-hydraulic-lifters_319444
The newly manufactured engine cases and crate engines from MAM are for the Type 1 (upright) engines that were used in Beetle's, Ghia's, Thing's (and Buses until 1971) among others. This engine type is not designed for use in an aircooled Vanagon.
Jay Brown
'85 Zetec Westfalia
Newmarket, NH
LB Sammy
LB Sammy is offline
PostPosted: Wed Feb 18, 2015 11:16 am    Post subject: I feel silly Reply with quote
Apparently I didn't do my research very well. Thanks for being more on it then me ! Can you or anyone recommend a couple companies that sell newly manufactured engines for my '81 van? Thanks!!
Also, any advise for me in regards to buying one of these and having someone install vs. rebuilding my current one?
djkeev
djkeev is offline
PostPosted: Wed Feb 18, 2015 11:26 am    Post subject: Reply with quote
81, you are air cooled.
You might go onto the Bay Window Bus forum and look around / ask about rebuilders.
The 411/412 used the same basic engine as well.
The Early Vanagons were running essentially the same 2.0 engine. We tend to be much more into Water Cooled here.
I understand they were sold, but Rimco used to be the cats meow for air cooled reconditioning. Not sure where it stands today.
http://www.rimcovw.com/
Good luck, let us know how you proceed.
Do Stay away from GEX, a proven trouble prone company.
This link offers some guidance as well........
http://www.thesamba.com/vw/forum/viewtopic.php?t=128668
Dave
Ghia
Vanagon
Beetle
LB Sammy
LB Sammy is offline
PostPosted: Wed Feb 18, 2015 11:41 am    Post subject: Reply with quote
Thanks Dave!!! Much appreciated sir. I'll check back in later
