Was my mechanics charges fair? |
Yes, you should use him again |
41% |
[ 13 ] |
Yes, but maybe shop around for better options |
35% |
[ 11 ] |
No, it shouldn't cost you that much |
16% |
[ 5 ] |
No, you were clearly overcharged |
6% |
[ 2 ] |
Total Votes : 31 |
Pastelweis Samba Member
Joined: June 02, 2010 Posts: 92 Location: Stockholm / Los Angeles
Posted: Mon Mar 02, 2015 8:49 am Post subject: Was my mechanics charges fair? |
Hi!
I just had my recently purchased all original 1979 Mexico Beige Westfalia overseen by an experienced air cooled Volkswagen mechanic here in Los Angeles. Curious as to what the opinions are here on the Samba regarding what I was charged.
Work performed:
• General tune up excluding oil change as we agreed it looked as there was no need. Wish I knew exactly what this included but assuming that means timing adjustment and replacing the air intake and oil filter. Talked about changing the gasoline filter but not sure if he did
• New air filter
• Transmission oil change
• Replaced front brakes
• Tightening of fan belt
• New CV joint on both sides
Total charges for parts and labor 890 USD incl tax.
Fair or unfair? Elaborated opinions appreciated. Thanks! |
Jim Hunter Samba Member
Joined: February 14, 2014 Posts: 107 Location: MB, Slovenjia
Posted: Mon Mar 02, 2015 9:00 am Post subject: |
Seems too high for me , but I need more details on some things :
This may vary from brake pads change to new rotors, rebuilt or new brake calipers , brake hoses , bearings etc.
Also here : how many CV joints are replaced 2 or 4 ? |
Bala Samba Member
Joined: December 04, 2003 Posts: 2613 Location: Austin, TX
Posted: Mon Mar 02, 2015 9:05 am Post subject: |
Two things that stand out to me are...
-A "tune up" should always include an oil change in my opinion. If he didn't change the oil I'm guessing he didn't change the filter.
-If he didn't change or even asses the fuel/vapor lines that would make me nervous.
For what he did, the price is not outrageous unless compared to what you could have saved doing it yourself. _________________ 1976 Westy
1966 Beetle |
borninabus Samba R&D Dept.
Joined: May 18, 2006 Posts: 4541 Location: Arizona Highways
Posted: Mon Mar 02, 2015 9:07 am Post subject: |
agreeing with the previous poster in that front brake replacement & new CV is a little vauge.
assuming new rotors, bearings, pads, calipers & complete axle service; it sounds about right.
keeping in mind that the bunch of gringos here are probably not the best judges of the sweedish labor exchange rate
_________________ 88 Van WBX, A/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport |
SGKent Samba Member
Posted: Mon Mar 02, 2015 9:09 am Post subject: |
not meaning disrespect, the question is a bit arrogant. If you had doubts about him you either should not have used him, or you should have spoken with him about what he charges before the work. We also have no clue what quality parts were put in, and you probably don't either. You can save labor cost next time by getting your own hands greasy. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
TomWesty Samba Member
Joined: November 23, 2007 Posts: 3482 Location: Wyoming,USA
Posted: Mon Mar 02, 2015 9:11 am Post subject: |
borninabus wrote: |
He said it was done in Los Angeles. _________________ If you haven't bled on them, you haven't worked on them.
Visit: www.tomcoryell.com and check out my music! |
bwaz Samba Member
Posted: Mon Mar 02, 2015 9:25 am Post subject: |
you didn't say if there was a charge known at the start to do an "inspection" of what kind of work was needed to be done. Many shops have standard pre-purchase inspection... here it's @ $150? If you knew what work you wanted done before you started, you should have asked for a ballpark price... then, no surprises. No paperwork to show what was done to know if the fuel filter was done... often there's parts prices shown on an invoice to know if you got new rotors and calipers too. |
Brian Samba Moderator
Posted: Mon Mar 02, 2015 9:37 am Post subject: |
From a DIY perspective, yea that's ludicrous. But if I was not a DIY, that is still high. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
Posted: Mon Mar 02, 2015 9:38 am Post subject: |
New CV joints alone could be $300 in parts and who knows as far as the brake work, brake parts could be anywhere from $50 to several hundreds of dollars.
Also for what it is worth, you can't look at oil and have any real idea of its condition. Dark looking oil can lube just fine while clean looking oil can be shot. |
timvw7476 Samba Member
Posted: Mon Mar 02, 2015 11:16 am Post subject: Was my mechanics charges fair? |
Seems fair to me.
But '79, and any hydraulic VW engine,
loves to get new oil.
It's like a tune-up for the lifters.
So that choice is odd. |
lil-jinx Samba Member
Joined: August 14, 2013 Posts: 1109 Location: New Brunswick,Canada
Posted: Mon Mar 02, 2015 11:17 am Post subject: |
Sort of like saying I went out for dinner and paid $30 for a meal,did I pay too much. |
cliveawn Samba Member
Joined: December 07, 2010 Posts: 481 Location: Southern Sweden
Posted: Mon Mar 02, 2015 11:31 am Post subject: |
If you elaborate i bit more about what was exactly was changed im sure I could tell you if it was a fair price.
Im in Sweden..... _________________ ---------------------------------------------------------
Green 78 Westfalia Helsinki,
2056 with 41 x 34 valves,ported heads
Fully balanced
8,5:1CR
JPM Custom made cam
JPM 7075 dual taper pushrods
IDF 40's with 28mm venturi's
Python CSP 42mm exhaust.
115 HP
Daily driver 2017 Volvo V60 D5 hybrid
Rica stage 2 tune 345hp.
''Funny thing about common sense is that its not very common''
Seismic gun mechanic |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22677 Location: NYC/Upstate/ROW
Posted: Mon Mar 02, 2015 11:39 am Post subject: |
Location marker Stockholm, but OP posts "here in Los Angeles"
Nomad requires clarification before he sterilizes....
FWIW I see 4 hours labor easily, so 400 in parts for CV, brakes, tuneup easily makes 1000 USD reasonable. _________________ .ssS! |
Vince Waldon Samba Member
Joined: November 07, 2010 Posts: 451 Location: Edmonton, Alberta
Posted: Mon Mar 02, 2015 12:23 pm Post subject: |
lil-jinx wrote: |
.....and posting that question to a forum of arm-chair chefs.
In most markets supply and demand also play a role. For example, in my city, there is maybe *one* mechanic who will still work on air-cooled VWs... and only if he feels like it. Meaning... he can pretty much charge whatever he wants and people are happy to pay. _________________ Vince Waldon Edmonton Alberta CANADA
1970 baywindow |
VWsArent4Hippies Samba Member
Joined: April 13, 2005 Posts: 3079 Location: The Bull City
Posted: Mon Mar 02, 2015 12:37 pm Post subject: |
What's the shop rate? What's the break down of parts vs labor? Exactly what parts were replaced?
This is a very vague post and nobody that has voted in your poll or commented either way in this thread can honestly make a judgment. |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16976 Location: San Diego, California
Posted: Mon Mar 02, 2015 1:09 pm Post subject: |
Here's what I would have charged you.
Air filter $15 plus .2 labor
Tranny oil $20 plus .5 labor
Front pads $30 plus 1.0 labor
Fan Belt .1 labor
CV's (one per side) $100 plus 2.0 labor
This comes to $165 for parts
and 3.8 labor
Now most shops are going to mark up the parts a bit higher but I'd say somewhere around $600 would have been a good deal. Pretty sure though I left out a few tune up parts he probably used. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
bwaz Samba Member
Posted: Mon Mar 02, 2015 2:11 pm Post subject: |
aeromech wrote: |
Fan Belt .1 labor
and 3.8 labor
Now most shops are going to mark up the parts a bit higher but I'd say somewhere around $600 would have been a good deal. Pretty sure though I left out a few tune up parts he probably used. |
And if you needed new front rotors and calipers? CIP1 shows calipers at $100 each and rotors at $64 each. Add $300 to your $600, not including the labor... seems about right, guessing at what's been done. |
SGKent Samba Member
Posted: Mon Mar 02, 2015 2:34 pm Post subject: |
$325 for lobro CV kits.
$35 turn front rotors
$40 front pads
$15 air filter
$20 trans oil
_________
$435 parts
$ 30 tax
$ 15 misc fees
________
$480 parts total
Labor at $100 - $150 per hour shop rate. 4 hours x $100 = $400
$400 labor
$480 parts
_______
$880 total _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
air-h2o-air Samba Member
Posted: Mon Mar 02, 2015 2:47 pm Post subject: |
tax
shop supplies
hazardous waste charges
and any other charges associated with doing business in California
all need to be added as well |
Joined: January 01, 2007 Posts: 16893 Location: sticksville, ct.
Posted: Mon Mar 02, 2015 4:05 pm Post subject: |
I feel he undercharged you by 200....
without seeing the actual slip, I dunno what was done...
you have to remember, for a guy to even put the key in the door of a business, not some side gig in his driveway, he needs to make X amount an hour.
from a business standpoint, he (in my opinion) undercharged you. just digging the shit out of the CV bolts is a daunting task alone.
now he has to mark up the parts. why? every minute on the phone calling you, calling for parts etc has to come from somewhere.
this is the problem with "hobby" cars...everyone jumps on some forum to have 1/2 of it's cheap ass members say "yo, you got ripped off" or you could have done it cheaper yourself....well, if you could do it yourself I am sure you would have.
from your description, what you had done is a "no money job" in my book. it's not like it's a 2012 GTI and it will come apart easily, you can get genuine parts that fit, you don't have to modify any parts to make them work...
I have 2 more buses to do. then I'm done doing work for the aircooled crowd. they will piss and moan about every inch of the project, but will pay 5k for a new transmission for their surburban without batting an eye
sorry for the rant! but from a mechanics standpoint, there is a lot that the customer never ever takes into consideration...like the 100K in tools the guy has. for example, if he has been at it 18 years, and has 100k in tools, that is 5,555.00 per year he has "paid" to do your job
ask yourself this...(and you can't count college/education cost) what job on this planet requires an employee to spend 5k a year just to punch in so he/she can work? breathe in brake clean vapors, be around brake dust, oil and beat the living shit out of his body for under (well under) 100k a year. _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
