vergen34 Samba Member
Joined: February 03, 2004 Posts: 2 Location: seattle, wa
Posted: Tue Feb 03, 2004 6:27 pm Post subject: i need brake advice!!! |
HI all,
I just recently took my 64 type 34 ghia out of storage of six years and am getting her show, and road worthy again. I replaced my leaking rear wheel cylinders and bled the brakes about four times. I cant seem to get any pedal pressure unless I pump them up. there doesnt appear to be any leaking, or air in the lines anywhere else. should I replace my master cylinder? It seemed to work when the rears were leaking.. when I pump up the brakes they work great. Ten seconds later the pedal hits the floor. I feel like i've overlooked something. |
brent67 Samba Member
Joined: December 31, 2003 Posts: 515 Location: Port Townsend,WA
Posted: Tue Feb 03, 2004 8:51 pm Post subject: |
Are you losing brake fluid (have to keep topping up reservoir) or does the pressure just bleed away? If you are not losing fluid I think the logical culprit is the master cylinder. IMO, I would replace all the flexible lines after sitting for so long and flush all the old fluid from the system. Better safe than sorry. _________________ DSD
Dark Side Disciples
(Inner Circle/4th degree) |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22440 Location: Kimball, Mi
Posted: Tue Feb 03, 2004 8:58 pm Post subject: |
I agree with Brent. You might also try adjusting the brakes a little tighter, so the wheel cylinder doesn't have to travel as far to bleed. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Gary Person of Interest
Joined: November 01, 2002 Posts: 17069 Location: 127.0.0.1
Posted: Tue Feb 03, 2004 9:09 pm Post subject: |
Definitely check the flex lines. Hell, I'd say spend the $$$ and replace them outride. Your life depends on properly functioning brakes, and there's no sense in skimping in that department. _________________ West Virginia State Board of Education v. Barnette, 319 U.S. 624 (1943) |
Posted: Wed Feb 04, 2004 7:45 am Post subject: brakes |
Thanks everbody,
Im going to replace the master cylinder today and replace the flex lines with stainless braided ones. hopefully this will help, itll be a nice rainy saturday project, again!! |
