endresta Samba Member
Posted: Sat Mar 07, 2015 5:14 am Post subject: |
The car is very good about rust, only minor work. The paint on the car is from 74 i guess, because there is almost no paint on it. So thats my project, or that was the plan at first
_________________ 1974 Type 13GT03
1967 Type 365
Type 1 are nice, Type 2 are cool, BUT Everyone knows, that Type 3............RULE!\\\\\\\"
Click to view image |
Posted: Sat Mar 07, 2015 6:44 am Post subject: |
May 19. 2014 I parked the car and started strip down.
New csp fibreglas fenders tested
Finished sandblasted
1967 Type 365
Click to view image
Posted: Sat Mar 07, 2015 6:57 am Post subject: |
Now the car was going to stand still for a couple of months, and in december 2014 my good friend Jøran said that it was time to start sanding and to fix all the small dents and stuff
And then finally on december 23 it wa finished with epoxy.
1967 Type 365
Posted: Sat Mar 07, 2015 7:24 am Post subject: |
Of course the doors front hood and all small parts are finished and in very good condition.
The car was back home again
and I wondered what to do now. I could not paint it now and just be finished. I saw that the car needed lift off and to unscrew every bolt and nut.
I started to read on many forums to try to find what kind of parts I needed to make this a good germanlooker.
I want to do something with suspension, steering, gearbox, engine....
Engine is going to be a oxyboxer, this one I have started on, will come back on this.
Gearbox, steering and suspension I dont know yet. I am trying to find whiteline adjustable rear swaybar, think I have this soon now. _________________ 1974 Type 13GT03
1967 Type 365
gt1953 Samba Member
Joined: May 08, 2002 Posts: 13958 Location: White Mountains Arizona
Posted: Sat Mar 07, 2015 7:37 am Post subject: |
Glad to see VW's world wide being taken care of!!! _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
Posted: Sat Mar 07, 2015 7:45 am Post subject: |
Meanwhile it was time for lift off and to start on the rest of the job.
I also have a project on the dash. I do not like the instrument on the 1303 and had to do something.
I think 3 instrument will look best, not finished with the thinking job, but 5 instruments like big brother looked too much. _________________ 1974 Type 13GT03
1967 Type 365
Posted: Sun Mar 08, 2015 1:22 pm Post subject: |
A little time in the garage this evening and right side of irs is almost in pieces. I need some new tools to unscrew the driveshaft. I guess this had been easyer if I had not dismounted the handbrake
I think a new 6 mm umbraco and a big drill will do
1967 Type 365
Posted: Mon Mar 23, 2015 3:22 pm Post subject: |
Finally everything is apart and I can start with the fun part :-/
I am lucky to have a cabinet type industry in my garage for as long as I want, and then its just to start with the parts...
1967 Type 365
Posted: Fri Jul 17, 2015 10:57 pm Post subject: |
Finished sandblasting the floorpan 2 weeks ago. Have been collecting parts to convert to porsche 944 rear trailing arms and brakes. So now I am only missing all the brake parts... 😁
1967 Type 365
Posted: Sun Aug 02, 2015 2:04 pm Post subject: |
Finally have all the parts to convert to 901 gearbox 😊 _________________ 1974 Type 13GT03
1967 Type 365
Posted: Mon Aug 17, 2015 3:09 pm Post subject: |
As usual a lot of more work than i thought, but its going forward.
Rear mount I had to make of an old one and the new front mount also needed some cut an weld...
Almost there with the gearbox.
1967 Type 365
Dodgy Samba Member
Joined: January 30, 2006 Posts: 523 Location: Leicester, UK
RailBoy Samba Member
Joined: March 10, 2008 Posts: 2916 Location: Virginia
Posted: Tue Aug 18, 2015 2:07 am Post subject: |
Damn, that is going to be a helll of a nice car once done, that is for sure...
On Front Air Dams(Spoilers), you can get them out of a company in Australia, forget the name, but the only place I know were to get the Kombi replica ones... Hope this helps...
But yea, very nice work indeed, and a good score on the BBS's that came with it.. RB _________________ [quote="smitty24"]"HELP, I ported my own heads and now have fire coming out my ass" .[/quote]
Posted: Wed Aug 19, 2015 1:40 pm Post subject: |
Thanks both of you. I hope that the car will be on the road next summer. Only with the original engine at first... _________________ 1974 Type 13GT03
1967 Type 365
Posted: Fri Aug 21, 2015 10:08 am Post subject: |
New day, new possibilities or what it says....
The gearbox mounts are finished, next is to close the new gap or hole where the shiftcoupler is.
And when I first have this area open I want to pull new fuelpipes in the tunnel.
1967 Type 365
Posted: Wed Aug 26, 2015 2:38 pm Post subject: |
New fuel lines finished. Thanks to my good friend Kai for all the help, could not have done all this without you.
1967 Type 365
Posted: Mon Aug 31, 2015 2:27 pm Post subject: |
The transmission finished in the rear end. Cut the shift rod 6 cm and weld in again. Make a housing around after. Finished yeyyy 😊😊😊 and the best part, every gear works😃 this gearbox have been in storage for about 15 years so I look forward to try it 😁
1967 Type 365
Posted: Mon Mar 28, 2016 5:36 am Post subject: Re: My -74 SilverBIG |
Its been a while since last update, but a lot of work is done. Floorpan and all parts for wheels and suspension is painted and started to bolt together again.
In the front, new porsche 944 mastercylinder, kerscher ball joint for 944 spindle. Working with the brakelines
Porsche NA brakes redone. New gaskets and pads.
Porsche 901 gearbox painted and mounted. Working with the rear trailing arms and brakes. Hopefully finished with all the work with the floorpan by late spring....
1967 Type 365
Dodgy Samba Member
