Snoww_ Samba Member
Joined: September 25, 2015 Posts: 78 Location: California
Posted: Wed Sep 30, 2020 12:47 pm Post subject: CA legal catalytic converter for a Tiico? |
Here we go again.
I've got a kinda weird setup but I'm just looking to get one smog test out of the way before I swap engines next year.
I've got a '91 Vanagon with a 2.0 Tiico engine in it. So far i've been to 2 smog test shops and the inline 4 vs flat 4 hasn't been an issue (the second guy hadn't seen under the "hood" of a Vanagon before). The issue I'm running into is that the previous owner that did the swap put on a cat that doesn't match the van so I'm getting flagged as having a modified cat, not to mention I was running 6x the NO on the sniffer when I did get a test.
The cat I have now is D-193-112 which is a universal OBD-II but I've got no clue how old or worn out it is. I think replacing it will fix my NO issue but I'm trying to save some cash since this engine just needs to get me another couple years. I've been looking at this one from the BusDepot https://www.busdepot.com/025131701 but I'm not sure how a cat designed for the stock engine will work on my Tiico.
I'll post the test results this evening.
Any insight or info is appreciated as always. Thanks! _________________ 1991 Tiico Vanagon Carat
1961 Baja Bug |
Californio Samba Member
Posted: Wed Sep 30, 2020 2:04 pm Post subject: Re: CA legal catalytic converter for a Tiico? |
| If you're in Richmond, go see Felipe at 523 Rods. There are smog places around there as well that will take care of you. |
pdm777 Samba Member
Joined: August 06, 2012 Posts: 348 Location: Clovis, CA
Posted: Wed Sep 30, 2020 5:44 pm Post subject: Re: CA legal catalytic converter for a Tiico? |
Several years ago I bought a Magnaflow cat. with flanges.
YIKES!!! now the price is $800+ and 'unavailable'.
I don't have the part number.
Passed CA smog no problem.
A cheap weld on is probably your best bet here.
Reduce the NOx - Retard timing, run high percentage ethanol gas = pass _________________ 1990 Westy Full Camper |
termuehlen  Samba Member
Joined: May 02, 2012 Posts: 1036 Location: Redwood City
Posted: Wed Sep 30, 2020 6:13 pm Post subject: Re: CA legal catalytic converter for a Tiico? |
The Tiico Executive Order D-573 says the original Vanagon catalytic converter is retained. So a CA compliant cat for your model year Vanagon should be acceptable. _________________ 1988 Westfalia automatic Subaru OBD1
1986 syncro tintop wbx |
Posted: Wed Sep 30, 2020 7:13 pm Post subject: Re: CA legal catalytic converter for a Tiico? |
Here is the link to the executive order:
https://ww3.arb.ca.gov/msprog/aftermkt/devices/eo/d-573-1.pdf
Does your engine, intake manifold and ecu match the ones described in this order? _________________ 1988 Westfalia automatic Subaru OBD1
markswagen Samba Member
Joined: January 28, 2018 Posts: 1554 Location: san diego
Posted: Wed Sep 30, 2020 7:19 pm Post subject: Re: CA legal catalytic converter for a Tiico? |
who has the EO, i didn't know there was one, I'd be interested reading more.
| termuehlen wrote: |
| The Tiico Executive Order D-573 says the original Vanagon catalytic converter is retained. So a CA compliant cat for your model year Vanagon should be acceptable. |
_________________ markswagen {mobile mechanic} san diego area all early VW's cared for.
619 201 0310 |
16CVs Samba Member
Joined: February 22, 2004 Posts: 4296 Location: Redwood City, California
Posted: Wed Sep 30, 2020 11:06 pm Post subject: Re: CA legal catalytic converter for a Tiico? |
Post a picture of what your Cat looks like and how it's mounted. Is it welded or bolted in?
Stacy _________________ 1987 Syncro Westfalia Triple knob (bastard)
Samba member # 14980
Don't let your van end up in an "abortions" thread. |
Snoww_ Samba Member
Posted: Thu Oct 01, 2020 1:34 pm Post subject: Re: CA legal catalytic converter for a Tiico? |
Californio: Good advice on Felipe at 523 Rods if I can't figure this out on my own that will be my next stop.
pdm777: This is what I'm leaning toward:
termuehlen: Thanks for the EO that was very informative, I didn't realize the Tiico swap was ever officially recognized. Unfortunately none of my numbers match go figure.
16CVs: here's a pic of what I have now. I've got access to a welder and have some experience so I'm not afraid of cutting the old cat out and getting a stock van replacement welded in.
1961 Baja Bug |
16CVs Samba Member
Posted: Thu Oct 01, 2020 6:54 pm Post subject: Re: CA legal catalytic converter for a Tiico? |
That is one fugly set up. I would would proper flanges on it so that you can install a Factory style cat right off the shelf.
These vans are expensive toys, If you had flanges on it you could round up a Legal cat and just slip it in and out.
People that do work like that need to find a new profession.
Snoww_ Samba Member
Posted: Thu Oct 01, 2020 9:14 pm Post subject: Re: CA legal catalytic converter for a Tiico? |
Agreed, the entire swap has had a few issues where some things were botched (timing belt idler was installed backwards) but I'm doing my best to bring it back to life.
I've already got my hands on a good running 1.8T that I'm going to swap in with Stephens Kit so I'm not too worried on making it nice I just want to get it to pass this time and next time she'll have a new heart.
1961 Baja Bug |
