Yellow head bolt sealant not hardening - problem?
IdahoDoug
IdahoDoug is offline
PostPosted: Fri Jul 29, 2016 9:59 pm    Post subject: Yellow head bolt sealant not hardening - problem? Reply with quote
So, the yellow sealant that comes in the engine gasket set from Reinz. It is not hardening after 2 days. I may be over reacting and perhaps it needs engine heat to cure and perhaps nobody's ever noticed this, but I habitually put a bead of sealants I use on the bench on a piece of scrap to see how they behave. I toss them when things work out. That sample is still exactly like it was when I squeezed it out - like toothpaste.
What say the faithful?
Merian
Merian is offline
PostPosted: Fri Jul 29, 2016 10:05 pm    Post subject: Re: Yellow head bolt sealant not hardening - problem? Reply with quote
is it anaerobic?
IdahoDoug
PostPosted: Fri Jul 29, 2016 10:19 pm    Post subject: Re: Yellow head bolt sealant not hardening - problem? Reply with quote
Dunno, but I'm going anaerobic hyperventilating at the thought of pulling the heads off now that they're on. I'm ready to relax and finish the easy stuff up. Argh...
I've seen it referred to as a "non hardening" sealant in other spots, but this seems like it would washout.
Merian
Merian is offline
PostPosted: Fri Jul 29, 2016 10:56 pm    Post subject: Re: Yellow head bolt sealant not hardening - problem? Reply with quote
either check the spec. sheet or clamp 2 pieces of metal with it for a day then try to pull apart
or put them in the oven for a while, then try
or... check the date code on the stuff Exclamation Exclamation Exclamation
DwarfVader
DwarfVader is offline
PostPosted: Fri Jul 29, 2016 11:41 pm    Post subject: Re: Yellow head bolt sealant not hardening - problem? Reply with quote
I'd for sure find out what sort of adhesive/sealant it is... If it's anarobic then it sitting on a sheet of paper isn't going to do beans. (Other than make you nervous.)
I don't have your answer... but I'll say this much... you can't be the first to have these thoughts. (Someone here probably was though.)
- oderint dum metuant -
I'll find my van someday, or it will find me.
djkeev
djkeev is offline
PostPosted: Sat Jul 30, 2016 1:06 am    Post subject: Re: Yellow head bolt sealant not hardening - problem? Reply with quote
No, not a problem.......
Curious, does the tube ID whats in it?
Many sealants are designed as non-hardening.
But......
I didn't use the sealant provided. Unknown tubes of goo go into the trash.
There are better more modern alternatives than 1980's technology.
Right Stuff for the Win!
Also some discussion.....
http://www.thesamba.com/vw/forum/viewtopic.php?p=3739089
I do wonder though if Permatex Ultra Copper Maximum Temperature would be a good choice over aviation for the metal cylinder seals? 🤔
https://www.permatex.com/products/gasketing/ultra-...ket-maker/
Elring fails to explain what us in the tubes.... Sealant for acorn nuts and sealant for rubber gasket...... Set #692.664
The larger black tube is Dirko
http://ows-cdn.tecdoc.net/elring/home.jsp?server=6...7091d203fa
Dave
Ghia
Vanagon
Beetle
ftp2leta
ftp2leta is offline
PostPosted: Sat Jul 30, 2016 5:41 am    Post subject: Re: Yellow head bolt sealant not hardening - problem? Reply with quote
Ha ha Dave, that is an old page!
I only have one product in the shop since 7 years.
And it's your first image Smile
Ben
Working with rust, grease, dirt and dust is a sad truth.
FI part for sale: http://www.benplace.com/parts_sale1.htm
My site: http://www.benplace.com/vw2.htm
Subi conversion: http://www.benplace.com/vanaru_eng.htm
Youtube http://www.youtube.com/user/ftp2leta
the joker
the joker is offline
PostPosted: Sat Jul 30, 2016 7:15 am    Post subject: Re: Yellow head bolt sealant not hardening - problem? Reply with quote
my rebuild was 5 years old and the yellow sealant is still clay like on the outside nuts but no leaks hope that helps ease your mind Confused
AtlasShrugged
AtlasShrugged is offline
PostPosted: Sat Jul 30, 2016 7:26 am    Post subject: Re: Yellow head bolt sealant not hardening - problem? Reply with quote
The yellow sealant always stays like soft clay..until it is pressed between two metal parts. It works fine for our Vanagon head nuts..if the head surface and nut face was clean when torqued down the nuts.
The "right stuff" on the rubber gaskets for sure.
IdahoDoug
PostPosted: Sat Jul 30, 2016 11:22 pm    Post subject: Re: Yellow head bolt sealant not hardening - problem? Reply with quote
OK. Probably fine then. I cleaned the head nut clamp surface on the head with a red 3M pad and brake cleaner, then same on the nut's face after cleaning it completely with brake cleaner. So, I think we are good to go on. Thanks very much for the input.
