Transmission rear seal
volkyrican
volkyrican is offline
PostPosted: Fri Jun 19, 2015 3:26 pm    Post subject: Transmission rear seal Reply with quote
I have a 62 bug,transmission is not original I am not sure if it's German, Brazilian or Mexico I have a leak at the rear seal but as I took off the the throw out bearing there is a solid shaft no bolts to take it out. How the heck do I take that shaft out to Chang the rear seal.
Bruce
Bruce is offline
PostPosted: Fri Jun 19, 2015 3:43 pm    Post subject: Reply with quote
You leave it in place and dig out the seal around it without damaging the surface of the shaft or the bore in the case.
One way is to get a couple of wood screws and screw them into the seal. Then you can pull on the heads of the screws.
To install the new seal, find a piece of tubing or pipe the right diameter and tap it in.
60ragtop
Bonneville Belt Bitch
60ragtop is offline
PostPosted: Fri Jun 19, 2015 5:17 pm    Post subject: Reply with quote
Or one of these works well
http://www.amazon.com/Lisle-56750-Seal-Puller/dp/B...moval+tool
I have just used a large flat screw driver to pop them out.
Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote:
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote:
maybe he just snapped cause his car sucked Wink
