vanagon overheating
vagabondvanagon
vagabondvanagon is offline
PostPosted: Mon Aug 31, 2015 10:09 pm    Post subject: vanagon overheating Reply with quote
New to site. Thanks for any help in advance. My 84 vanagon 1.9 appears to be overheating. Red flashing then solid light says so. However I do not think I have lost any coolant. Where is first place to begin? !. Bleed lines and flush? 2> check sensors and fan switch? 3. check for leaks in hoses and resevoirs? All Suggestions appreciated.[/list]
WestyBob
WestyBob is offline
PostPosted: Mon Aug 31, 2015 10:44 pm    Post subject: Re: vanagon overheating Reply with quote
Is your water (coolant) pump working ?
jimf909
jimf909 is offline
PostPosted: Mon Aug 31, 2015 11:46 pm    Post subject: Reply with quote
Check:
1 - Water pump belt
2 - radiator fan working
3 - radiator gets hot (use infrared thermometer or similar...hand). If it doesn't get hot top to bottom it's probably plugged.
- Jim
Butcher wrote:
Guilty as charged.
Terry Kay
Banned
Terry Kay is offline
PostPosted: Tue Sep 01, 2015 7:45 am    Post subject: Reply with quote
# 1 usual suspect----
T.K.
crazyvwvanman
crazyvwvanman is offline
PostPosted: Tue Sep 01, 2015 8:40 am    Post subject: Re: vanagon overheating Reply with quote
What is the temp gauge needle reading? What red flashing light are you referring to? The coolant warning light only flashes, never turns on solid. Do you have an owner's manual to look at?
Mark
