KevinsKamper Samba Member
Joined: November 17, 2014 Posts: 72 Location: Massachusetts
Posted: Fri Nov 28, 2014 3:17 pm Post subject: Oil leak....whats this?? |
Hi, New Westfalia owner here and first time poster.....picked up a 1990 one owner van last week, searched for months and found a real nice example 15 min from my house!....anyway have been spending the past week going over the vehicle and getting familiar with it. I have a service manual on order but hasn't arrived yet so here goes my 1st question...What is the slotted disc in this picture?...it appears the motor has a oil leak coming from this part and was wondering what it is and if its a easy fix like a rubber O ring or gasket.....any info appreciated!....Kevin
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32989 Location: Reading Pennsylvania
ftp2leta Samba Member
Joined: October 11, 2004 Posts: 3271 Location: Montreal
Posted: Fri Nov 28, 2014 5:52 pm Post subject: |
welcome.
Like stated it's the oil pressure relief valve.
Inside there is a spring so it's on tension. It's not a soft O-ring but a metal ring.
You will have to remove this one and if I remember right you will loose oil.
Dry it with brake cleaner, go buy a product called "The Right Stuff"
Put some on thread and let it dry for a day before putting oil back
It will NEVER leak again
Trust me
Ben _________________ Working with rust, grease, dirt and dust is a sad truth.
FI part for sale: http://www.benplace.com/parts_sale1.htm
My site: http://www.benplace.com/vw2.htm
Subi conversion: http://www.benplace.com/vanaru_eng.htm
Youtube http://www.youtube.com/user/ftp2leta |
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10357 Location: N. Idaho
Posted: Fri Nov 28, 2014 7:17 pm Post subject: |
I would drive it for a while and be sure it is not something above leaking down before messing with it. You have a very clean looking engine. Perhaps the seller steam cleaned the engine before putting it up on the market. There is a large o ring on the oil cooler that is above that point, and that's also to the rear of several common leaks where airflow on the road would deposit it. Dry it off and above it, and drive for a bit before concluding that the lowest point on the engine is also the source of an oil leak.
DougM _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1993 Toyota LandCruiser, 2002 BMW 325iX, 1982 Toyota Sunrader |
the joker Samba Member
Posted: Fri Nov 28, 2014 7:20 pm Post subject: |
make sure it's leaking from there, sometimes oil travels to and from weird places check around the top of the eng maybe coming from the dizzy o ring |
Posted: Sat Nov 29, 2014 6:25 am Post subject: |
Thanks guys!....I have cleaned the area and am confident its the source of the leak.....Ben, I have some Right stuff and will try your suggestion, now to get the plug out!.... |
AtlasShrugged Samba Member
Joined: October 30, 2008 Posts: 1605 Location: Decatur, Ga. USA
Posted: Sat Nov 29, 2014 8:14 am Post subject: |
Could be the sealing ring on the oil pressure relief threaded plug...they really don't leak very often. If you are going to replace the sealing ring, install a new pressure relief spring too. Part number for the spring 021.115.421B..$5.50 and the sealing ring N.013.829.3 $1.78 from Van Cafe. Your old spring is probably original. There is a spec for the length of the spring..the springs are always partially collapsed after a couple of decades. Cheap enough parts and may help with oil pressure issues in the future.
A more probable suspect for your oil leak is the oil pressure warning switch just above the oil pressure relief plug and the oil cooler gasket. There is a blind plug inserted into the engine case up there too. Those blind case plugs will leak. Clean the plug area with brake clean and use JB Weld over the plug if that is your problem. The blind plug is concealed by the rear engine support and is just below the threaded boss in the engine case.
Here is a picture of your oil leak area..the blind plug, the oil pressure switch and oil cooler gasket area.
Posted: Sat Nov 29, 2014 8:46 am Post subject: |
thanks Atlas, I will check out that area....good info..Kevin |
61Scout Samba Member
Joined: November 06, 2011 Posts: 1297 Location: Shoreline/Yakima WA
Posted: Sat Nov 29, 2014 10:28 am Post subject: |
I would just try and tighten what you have before going on a buying spree. I just have a large diameter hardened washer I ground down the fit the slot and use a pair of vicegrips to turn it. Crude but effective.
Looks like someone may have tried to tighten yours with a punch.
Welding or brazing a nut to the plug is another solution. I don't think you need to drain the oil from the engine when removing the plug, others may know better. |
Posted: Sat Nov 29, 2014 11:03 am Post subject: |
I will try the drag link socket idea....my local sears didn't have one in stock so I ordered one on line.....for what its worth I tried to see if it was loose and couldn't get it to move with a screwdriver. Kevin |
Posted: Sat Nov 29, 2014 12:20 pm Post subject: |
where in mass are you?
mark your calender for transporterfest Oct 2015 brookline
check or replace your fuel lines
buy two new fire extiqusters
welcome to the madness |
Posted: Sat Nov 29, 2014 6:24 pm Post subject: |
Thanks Joker...I'm down near Attleboro/ Rhode Island line....will mark my calendar.....got new fuel lines and coolant hoses on order...its in very good shape but needs updating 25 yr old components......Kevin |
Tobias Duncan Samba Member
Joined: January 15, 2013 Posts: 1412 Location: Taos NM
Posted: Tue Sep 22, 2015 4:58 pm Post subject: |
I have an oil leak that looks just like this one.
Mine was not tight at all when I put a screwdriver to it.
Do you need to drain the oil for this?
How did the OPs come out?
So many questions... |
Posted: Tue Sep 22, 2015 5:55 pm Post subject: |
Tobias Duncan wrote: |
Don't need to drain the oil..some oil will come out when you/if you remove the slotted threaded plug. About a cup.
If the plug is loose..then surely tighten it and order the sealing washer and just for laughs..a new spring. Wildthings suggestion using a large washer ground down to a flat on one edge and vise-grips is a good idea. |
Posted: Tue Sep 22, 2015 6:09 pm Post subject: |
Thanks Atlas , it was not so much loose as just barely snug. I was sure it was leaking but I cranked it down then cleaned the area with brake cleaner and took it around the block.
Crawled under and it was bone dry. However you can see nice little droplet forming nearby....
Any idea where that one might be coming from?
The aforementioned oil pressure sensor?
Posted: Wed Sep 23, 2015 7:11 am Post subject: |
Very well could be the oil pressure switch..look at the switch from up top with a flashlight..when they leak they are wet with oil. |
borninabus  Samba R&D Dept.
Joined: May 18, 2006 Posts: 4729 Location: Arizona Highways
Posted: Wed Sep 23, 2015 9:09 am Post subject: |
the drip is on the oil pump cover. _________________ 88 Van WBX, A/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport |
Posted: Wed Sep 23, 2015 7:49 pm Post subject: |
AtlasShrugged wrote: |
Mine is dry |
Posted: Wed Sep 23, 2015 7:50 pm Post subject: |
borninabus wrote: |
the drip is on the oil pump cover. |
I dont like the sound of that one bit... |
