Distributor Id help and cap recommendation
speedystar77
speedystar77 is offline
PostPosted: Sun Apr 10, 2016 8:43 pm    Post subject: Distributor Id help and cap recommendation Reply with quote
I believe this to be a SVDA distributor with electronic ignition (but not Pertronix brand). The cap looks to me like a Bosch cap.
The cap fit feels sloppy to me, like it doesn't mate snuggly to the distributor.
Is there a better cap for this distributor?
Thanks in advance.
1974 Baywindow Westfalia Bus
Tintop Campmobile
Production date: November 29, 1973
1700 cc engine with manual transmission
32/36 DFEV Weber Progressive
wcfvw69
Samba Purist
wcfvw69 is offline
PostPosted: Sun Apr 10, 2016 8:47 pm    Post subject: Re: Distributor Id help and cap recommendation Reply with quote
Are there any numbers on the side of the distributor? Most of those SVDA copies use the same caps as the DVDA distributors, 03010 is the short Bosch number.
The Samba member since 2004.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Mon Apr 11, 2016 6:19 am    Post subject: Re: Distributor Id help and cap recommendation Reply with quote
Its a Hot spark module and the cap is not Bosch. Looks like the Bosch 03 010 cap will fit.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
speedystar77
PostPosted: Mon Apr 11, 2016 6:35 am    Post subject: Re: Distributor Id help and cap recommendation Reply with quote
There are no numbers visible on the side that I can see (without removing it anyway).
Thanks guys.
Tintop Campmobile
Mr. 010
Glenn is offline
PostPosted: Mon Apr 11, 2016 7:23 am    Post subject: Re: Distributor Id help and cap recommendation Reply with quote
speedystar77 wrote:
[(without removing it anyway).
Thanks guys.
Use a mirror Wink
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
tasb
The Distributor Distributor
tasb is online now
PostPosted: Mon Apr 11, 2016 5:38 pm    Post subject: Re: Distributor Id help and cap recommendation Reply with quote
Bosch caps don't have those 90* intersecting lines. As above 03010 caps is what's needed.
Roads Scholar
Member# 2059
