sand3050 Samba Member
Posted: Mon Mar 21, 2016 3:26 pm Post subject: 1970 Squareback (Fat chick) 4 bolt to Wide 5 conversion question |
First of all, hello.
I'm new to the VW community, I recently purchased a 70 square and I have some questions on how to convert to a 5 wide pattern using adapters. I know CSP makes a disk brake conversion kit however I don't want to fork up that much $$ as of yet.
Is there a way to use adapters without hitting the caliper if I'm looking to use 17x7 raider wheels? Or any other way without converting to a drum brake or the expensive brake kit.
Thanks!  |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 23577 Location: Kimball, Mi
Posted: Mon Mar 21, 2016 9:14 pm Post subject: Re: 1970 Squareback (Fat chick) 4 bolt to Wide 5 conversion question |
| sand3050 wrote: |
Thanks!  |
Most of the adapters won't clear the caliper. Those that do, will push the rim/tire out toward the fender lip. And forget about lowering with spacers, as there's not enough room. _________________ Bob 65 Notch S with Sunroof
| Tram wrote: |
| "Friends are God's way of apologizing for relatives." |
| Tram wrote: |
| People keep confusing "restored" and "restroyed". |
