Steering Lock : differences
easy e
easy e is offline
PostPosted: Thu Jul 14, 2016 10:18 am    Post subject: Steering Lock : differences Reply with quote
Anybody have one handy & able to measure the length/width/height for me?
Thx,
e
The one on the right... 3/55-61
aka: Evan
easy e
easy e is offline
PostPosted: Thu Jul 14, 2016 12:24 pm    Post subject: Re: 55-58 steering lock: rectangular elec. cover dimensions Reply with quote
Outside L x W x H dimensions should be: 58.5 x 38.5 x 21.5
aka: Evan
Jacco Verveer
Jacco Verveer is offline
PostPosted: Thu Jul 14, 2016 1:04 pm    Post subject: Re: 55-58 steering lock: rectangular elec. cover dimensions Reply with quote
confirmed inside reads k 20723
easy e
easy e is offline
PostPosted: Thu Jul 14, 2016 1:10 pm    Post subject: Re: 55-58 steering lock: rectangular elec. cover dimensions Reply with quote
Great... thanks Jacco!
aka: Evan
Jacco Verveer
PostPosted: Thu Jul 14, 2016 1:13 pm    Post subject: Re: 55-58 steering lock: rectangular elec. cover dimensions Reply with quote
is this not for 55 and earlier?
65 Deluxe
65 Deluxe is offline
PostPosted: Thu Jul 14, 2016 1:18 pm    Post subject: Re: 55-58 steering lock: rectangular elec. cover dimensions Reply with quote
Evan,
I think thats barndoor pre 55
Think big drive a bus...
Own it, drive it, and don't make it a trailer queen...
The VW Junkie,
55 Oval
56 Euro 23 Window
58 Krankenwagen (Mr. Kranken)
59 Fjord Blue Bug
61 Ragtop
61 Double Cab
64 Euro Squareback Model S
65 21 Window (Blue)
71 Deluxe Bay Window
easy e
easy e is offline
PostPosted: Thu Jul 14, 2016 1:18 pm    Post subject: Steering Lock Reply with quote
67 only: column goes through lock, mounts to steering bracket, rounder elec. cover, no push button for start, smooth bezel by key.
61-66: column goes through lock, mounts to steering bracket, rounder elec. cover, no push button for start, words on bezel by key.
3/55-61: column goes through lock, mounts via column pinch bolt, rectangular cover (wires go in one end), has a white push button for start, words on bezel by key.
BD: lock goes over column, different style cover (extra hole on cover + wires go in on a different side), no white push button for start, words on bezel by key.
Left is 61-66... Right is 3/55-61
2nd pic shows a glimpse of the 3/55-61 white push button for start.
Barndoor follows these two pics...
Barndoor looks like this:
Two pics reference & lastly, pic from Technical Bulletin V2
aka: Evan
65 Deluxe
PostPosted: Thu Jul 14, 2016 2:39 pm    Post subject: Re: Steering Lock : differences Reply with quote
So the locking steering box is the same? just uses a different locking column pre 59. So I need the right lock for my 58 ambulance?
The VW Junkie,
55 Oval
56 Euro 23 Window
59 Fjord Blue Bug
61 Ragtop
61 Double Cab
65 21 Window (Blue)
easy e
easy e is offline
PostPosted: Thu Jul 14, 2016 2:44 pm    Post subject: Re: Steering Lock : differences Reply with quote
Steering box is the same... the steering shaft had a collar or 'locking shells' (as seen above) welded to it.
The shells can be made... or Wolfgang typically has some of the original locking boxes & columns.
Locating the shells/hole to cut in the column can be seen in the Technical Bulletin. Location of the collar/shells may vary based on BD or post-BD. Use the right Tech. Bulletin.
I'm making some corrections to the above posts of mine... based on Clara's info below.
Clara wrote:
If there is writing around where you insert the key , that says "Fahrt Start Garage Halt", (or the equivalent in another language), it is 62-66.
If there is no writing there, it is '67 and takes the L series key. Other than the key, there is not reall difference between the 62-66 and 67 units.
on the left, the 62-66 kind
on the right, the 3/55 through 61 kind
67 vvvvv
aka: Evan
