djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32989 Location: Reading Pennsylvania
Terry Kay Banned
Posted: Tue Aug 16, 2016 2:58 pm Post subject: Re: Delayed auto trans upshift from 2nd - 3rd when cold |
Change the seals on the 2nd gear brake band piston, adjust the 2nd gear brake band--tighten it up a hair. _________________ T.K. |
newfisher Samba Member
Joined: January 05, 2012 Posts: 1764 Location: The wet spot--Oregon
Posted: Tue Aug 16, 2016 3:05 pm Post subject: Re: Delayed auto trans upshift from 2nd - 3rd when cold |
Hairline crack on an internal drum bleeding off pressure? Seal on a piston? Both of which are internal, sounds like you have covered all of the external possibilities. Maybe swap the valve body with a known good one? |
AtlasShrugged Samba Member
Joined: October 30, 2008 Posts: 1605 Location: Decatur, Ga. USA
Posted: Tue Aug 16, 2016 5:31 pm Post subject: Re: Delayed auto trans upshift from 2nd - 3rd when cold |
How is reverse when cold? I ask as if you have a direct/reverse clutch problem..it will show up in third and reverse. If only a third gear problem..then a governor/governor drive or valve body problem.
http://reflectionsandshadows.com/a1-tech/BIGATSG.pdf |
pablum Samba Member
Posted: Tue Aug 16, 2016 6:40 pm Post subject: Re: Delayed auto trans upshift from 2nd - 3rd when cold |
iirc the diagnostic also suggested a dirty governor could be the source. |
Terry Kay Banned
Posted: Tue Aug 16, 2016 8:31 pm Post subject: Re: Delayed auto trans upshift from 2nd - 3rd when cold |
Enough mung to keep the weights from slinging out freely.
However, the trans not making the the 2-3 shift until the trans heats up has about zero chance due to a stuck governor .
Scum, dirt, garbage in the governor is not a heat related item of interest.
Clean it up anyway, just for grins. _________________ T.K. |
Posted: Wed Aug 17, 2016 6:24 am Post subject: Re: Delayed auto trans upshift from 2nd - 3rd when cold |
I had the same problem with a hanging no shift third gear, when cold, in my daughter's VW Cabriolet..same 010 transmission as a Vanagon..different transaxle. Transmission had about 200k miles on it.
How many miles on your transmission?
I rebuilt the transmission using new parts and some better internals from a Porsche 924 automatic.
The reason for the "hanging 3rd gear up-shift when cold" was a worn separator plate in the valve body, where one of the ball bearings rides back and forth in the plate. It had developed a ridge which kept the ball from going back and sealing a port..till it got warmed up.
Those separator plates are NLA.
The solution is to use an axacto blade and trim the ridge..with care..then use a very fine scotch-brite pad and smooth the surface of the plate.
There are other ball bearing in the valve body too..with worn ports..cleaned up those too. They were not as bad..but needed to be done.
Disassembling the valve body is fiddly..and you must keep all the balls, pistons and springs separate and logically in order.
As to the governor.. I would remove it and be sure the drive end is not broken (I don't remember if the governor can be pulled out completely with the transmission in place..and I do recall some loose bit that might fall off the end of the drive into the diff..need to check)..but do check your valve body first. Thankfully you can do the valve body with the transmission in situ.
MarkWard Samba Member
Joined: February 09, 2005 Posts: 18834 Location: Retired South Florida
Posted: Wed Aug 17, 2016 9:32 am Post subject: Re: Delayed auto trans upshift from 2nd - 3rd when cold |
With all the fancy CNC cutters out there, I bet it would be easy for a machinist to make replacement valve body plates. They would just need an original for the measurements. |
MidwestDrifter Samba Member
Joined: June 13, 2012 Posts: 769 Location: Kicking Around Australia
Posted: Wed Aug 17, 2016 10:00 am Post subject: Re: Delayed auto trans upshift from 2nd - 3rd when cold |
MarkWard wrote: |
Indeed. A good shop with a Coordinate measurement machine can trace the old body in about an hour. Load the trace into CAD/CAM (another hour of work). Generate a toolpath, and send to the machine for cutting. Laser cutting should be close enough tolerance. Once the initial work it done, one of those plates would cost less than $50
Alternatively, you could weld the hole up (after measuring its location). Then use a horizontal grinder to take the weld flat. Then drill a new hole.
It may even be possible to braze the hole close as well, but warping would be a concern. _________________ 2004 Dodge/Mercedes Sprinter (Custom Camper)
2000 Jetta TDI
1982 Diesel Westy W/ ABA I4 hybrid (Sold)
Epic Road Tripping since 08/05/12 | http://VagariesAbound.blogspot.com/
My Current Build | http://sprinter-source.com/forum/showthread.php?t=41215 |
Posted: Wed Aug 17, 2016 10:12 am Post subject: Re: Delayed auto trans upshift from 2nd - 3rd when cold |
Porsche still sells the valve 010 bodies..amazingly enough. Fits 944/924S..late model transmissions..could be part number 087325037C ($ 204.82) or 087325037J..probably the "J" is a later. Cost $ 235.83 for the "J" from Jim Ellis Porsche..brand new.
Porsche is my go to for VW NLA 010 transmission parts...they are more devoted to the old cars. Did not know they still sold valve bodies new.
I know the 944 valve body will work in a Vanagon..I ran one for a while and then transplanted the 944 valve body into the VW Cabriolet, which works fine there too.
I don't remember if the 944 valve body was a "J" or "C"..think it was a "J".
Last edited by AtlasShrugged on Wed Aug 17, 2016 10:14 am; edited 1 time in total |
Terry Kay Banned
Posted: Wed Aug 17, 2016 10:14 am Post subject: Re: Delayed auto trans upshift from 2nd - 3rd when cold |
What the heck---
90% of vanagonland uses, promotes, suggests using JB weld for worse situations than this, I think Dave being the grand poobah of experimentation, and side stepping the inevitable, should repair that wallowed out port with some JB, sand it slick , snd report back with his findings.
I don't think this is the issue hindering the trans to shift when the trans is cold, but what the hay, good time to play with some JB Weld in the trans valve body. _________________ T.K. |
pablum Samba Member
Posted: Wed Aug 17, 2016 12:10 pm Post subject: Re: Delayed auto trans upshift from 2nd - 3rd when cold |
Since the JBW has been so warmly recommended you can hardly NOT try it now, right?
But maybe it's a combination of things that bring the temperature into play, like VB + oil pressure, or something? |
Posted: Wed Aug 17, 2016 12:20 pm Post subject: Re: Delayed auto trans upshift from 2nd - 3rd when cold |
I doubt JB Weld would be a solution. I find it helpful..but not here. The ball bearing rocks back and forth on the plate..as you can see the steel will wear out. JB Weld, I would suspect, will wear out faster and may come loose and plug up somewhere.
Back to the new Porsche valve bodies..got a reply about the $200 087325037C. Thank you for contacting Porsche Atlanta Perimeter. Porsche is only showing one left of these in the world at the moment and would take about 3 weeks to get in out of Germany (if their inventory is actually correct). On the 087325037J, ($240) This one is Germany as well, but they are showing 21 of them
I may order the "C" valve body and C what happens. $1200 less than retail. |
pablum Samba Member
Posted: Wed Aug 17, 2016 3:25 pm Post subject: Re: Delayed auto trans upshift from 2nd - 3rd when cold |
Sir, I believe you are more serious-minded than the previous poster. |
Posted: Wed Aug 17, 2016 4:58 pm Post subject: Re: Delayed auto trans upshift from 2nd - 3rd when cold |
djkeev wrote: |
Reverse is fine all of the time as are the lower gears.
Dave |
djkeev..I just re-read your original post and missed the part where you did do your valve body separator plate..very sorry..assuming your valve body clean-up worked..you need to explore your governor.
I thought this YouTube was interesting and maybe applicable:
Posted: Fri Nov 24, 2017 8:51 am Post subject: Re: Delayed auto trans upshift from 2nd - 3rd when cold |
Interesting video! ^^^
Digging this thread up from the dead,
I put in a new valve body from Porsche to absolutely rule out the possibility of it causing my delayed 3rd gear upshift.
Every morning, it takes 6-8 miles before a 3rd gear upshift.
If I stop for a period of time, it can be several miles before an upshift happens, it doesn't take long to cool off!
The colder the weather, the longer it is before the upshift.
Fortunately It never failed to upshift on a recent 8,000 mile journey.
I do use a considerable amount of ATF, it leaks. I used about 12 qts during the trip.
The exact leak location eludes me, I'll need to clean it up and find the source.
I am about ready to pull and reseal the unit though it works so well, outside of the cold delay shift, I'm hesitant to do so.
Ghia
Vanagon
Beetle
Posted: Fri Nov 24, 2017 7:00 pm Post subject: Re: Delayed auto trans upshift from 2nd - 3rd when cold |
How full is your final drive?
When the suction filter failed on my 91 filling the tranny with crap and it quit shifting properly taking forever to shift until the unit warmed up. I took the entire valve body apart and found no obvious problems. Sent it in for a repair and the problem was still there when it came back from the rebuilder. Over time it did slowly fix itself, but when allowed to sit for a month or three the symptoms return and take a while to disappear once it was put back into service. I have guessed that it is the seals on one of the pistons getting hung up on a groove or something similar, but really have no clue. |
