Tachometer Questions
Blue Bear
Blue Bear is offline
PostPosted: Tue Sep 13, 2016 5:44 pm    Post subject: Tachometer Questions Reply with quote
So know there have been a lot of post made about making the 3 1/8" VDO Tachometer fit into the extra Bay of the Dash cluster. Every time one of those post was followed up with a post to BusBoys and their retaining ring to hold it in. Any body out there have a method of making it fit in that extra bay without using that ring from BusBoys or found another place that has that ring? I've made several attempts to contact BusBoys and have gotten no where.
1979 Westy
richparker
richparker is offline
PostPosted: Tue Sep 13, 2016 6:18 pm    Post subject: Re: Tachometer Questions Reply with quote
I'm pretty sure Bus Boys is out of business. As far as the ring goes, you can just make one. It's really not that hard, that's how mine is held into place.
__________
’71 Westy build
Adventure thread
’65 Deluxe Build
Randy in Maine
Randy in Maine is offline
PostPosted: Tue Sep 13, 2016 6:24 pm    Post subject: Re: Tachometer Questions Reply with quote
http://www.germansupply.com/home/customer/product.php?productid=17749&cat=&page=1
Might try over there.
Blue Bear
PostPosted: Tue Sep 13, 2016 7:51 pm    Post subject: Re: Tachometer Questions Reply with quote
YES! Thank you! I have order items from them before but I completely spaced checking them for this.
That's what I found after posting this. There's a thread in the "Buyer and Sellers Feedback" Forum where they seem to have come to conclusion that they've gone out of business. From what they were posting about the BusBoys, I can't say I'm surprised.
1979 Westy
BayCreamPuff
BayCreamPuff is offline
PostPosted: Tue Sep 13, 2016 8:02 pm    Post subject: Re: Tachometer Questions Reply with quote
I made this template a while back. I just cut mine out of thin sheet metal.
https://www.dropbox.com/s/cl1b6i7i0nhx72i/gauge-mounting-plate-1.pdf?dl=0
Cream Puff
'79 CA Stock FI Deluxe Campmobile
Earl Grey
'87 GoWesty 2.2 Westfalia
Marsha Mellow
'00 Eurovan VR6 Full Camper
madmike
madmike is offline
PostPosted: Wed Sep 14, 2016 6:43 am    Post subject: Re: Tachometer Questions Reply with quote
Just trim the block off plate w/Dreamial Wink
65 Baja (sold)
68 VolksRod Coupe(sold)
Porsche/Laser 917(sold)
'Black Ice'Drag Buggy 1915 'Turbo'
Mid-Engine Dragster 2332 w/IDA's(gone)
'White Out' 76 Drag/Street bug 2276 'Turbo' 11:85 @113 MPH
70 MicroBus 2110 w/40 IDF's
I build my own Motor's & transmission's
OB Bus
OB Bus is offline
PostPosted: Wed Sep 14, 2016 6:59 am    Post subject: Re: Tachometer Questions Reply with quote
madmike wrote:
Just trim the block off plate w/Dremel Wink
This ^^^
I took my block off plate and reversed it, then used a hole saw to cut the opening. Just took a few minutes to do.
Larry in OB
69 Westfalia and 2002 Eurovan Camper.
chabanais
chabanais is offline
PostPosted: Wed Sep 14, 2016 11:23 am    Post subject: Re: Tachometer Questions Reply with quote
Their website still works:
http://www.bus-boys.com/
"I spud therefore I yam."
Starbucket
Starbucket is offline
PostPosted: Wed Sep 14, 2016 3:09 pm    Post subject: Re: Tachometer Questions Reply with quote
I put a Sunpro Tach in my 71 Westy about 15 years ago. It fit up against the original trim and I think whatever held the dummy plate in place holds this in (been so long I can't remember). Was supper easy install and I think looks original @1st look. I posted a pic.
airschooled Premium Member
Air-Schooled
airschooled is offline
PostPosted: Wed Sep 14, 2016 3:49 pm    Post subject: Re: Tachometer Questions Reply with quote
The water was still turned on at their property, but the electricity wasn't when I was there two months ago. There is also tons of product just sitting out rusting, and all the donor cars are gone…
Robbie
www.airschooled.com
Randy in Maine
PostPosted: Wed Sep 14, 2016 5:32 pm    Post subject: Re: Tachometer Questions Reply with quote
I liked Walter over there. Good guy.
pittwagen
pittwagen is offline
PostPosted: Wed Sep 14, 2016 8:14 pm    Post subject: Re: Tachometer Questions Reply with quote
I just cut the center out of a spare block off plate like others. Fit perfect and hasn't moved in over five years. No need to buy one pre made.
captincanuck
captincanuck is offline
PostPosted: Wed Sep 14, 2016 9:09 pm    Post subject: Re: Tachometer Questions Reply with quote
Robbie
Just curious, how do know the water was on? Did you wash your bus in there driveway? Wink
1979 Westfalia "FireFly" Subaru 2.2 with Subaru gears 5spd.
Build Thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=634777&postdays=0&postorder=asc&start=0
Amskeptic
Amskeptic is offline
PostPosted: Wed Sep 14, 2016 11:12 pm    Post subject: Re: Tachometer Questions Reply with quote
Robbie
Couple of Vanagons and a lovely sad little BMW 2002 when I stopped by on August 1st.
Colin
www.itinerant-air-cooled.com
Air-Schooled
PostPosted: Thu Sep 15, 2016 10:18 am    Post subject: Re: Tachometer Questions Reply with quote
AHEM! I'll have you know I do not was my bus in drought-struck states unless the water can be reclaimed. I legitimately checked their utilities to see if the business was still in operation; I assume the water is left on for fire protection if necessary.
Colin
The little BMW was cute, but I didn't figure it was part of their inventory! Did they have the mountain of rear axle parts still rusting out in the rain?
www.airschooled.com
VWsArent4Hippies
VWsArent4Hippies is offline
PostPosted: Thu Sep 15, 2016 6:46 pm    Post subject: Re: Tachometer Questions Reply with quote
I think Wolfgang sells those retainers as well
Buuut, IMO you should spend another $100 and get one that matches the rest of the gauges. I just put one of the Smith tachs from CIP1 in, it's pretty noice
