Snap On tools for Volkswagen
diablosandwich
diablosandwich is offline
PostPosted: Sun Dec 25, 2016 6:55 pm    Post subject: Snap On tools for Volkswagen Reply with quote
I thought I would start a thread on Snap on tools for air cooled vw's. I have had some of these tools for over twenty years. These are well made tools that make a job a lot easier.
S5911 13/14mm manifold/obstruction wrench
S5922 13mm valve adjust wrench.
S5919 condenser install tool. For aluminum distributors from 60's. Drives condenser into bottom of distributor. No need for Muir's scout knife with one of these!
S5912 Brake adjuster
S5913 7/11mm brake bleeder wrench. This one is NOS with original sticker on it. I have a 7/11mm brake wrench made by KD that is a flared 11mm for soft brake lines that I like better than this one.
S5902 17/21mm Oil service wrench 21mm for engine oil drain plug and 17mm external for trans oil fill/drain plugs. A copy of the Hazet service wrench.
S5915 oil cooler 10mm wrench. Used to remove oil cooler with engine in car on non doghouse coolers. I have a similar Matra one.
S5914 Front engine seal installer. Threads into crankshaft and nut pushes installer in square. In original box.
I would like to see what other VW snap on tools are out there. Thanks, Casey
1966 Java Greens
gt1953
gt1953 is offline
PostPosted: Mon Dec 26, 2016 7:49 am    Post subject: Re: Snap On tools for Volkswagen Reply with quote
The S5912 Brake adjuster tool, I found that one at the local pawn shop for .75 cents. It still had the Snap On price sticker on it.
72 type 1
72 Squareback
60ragtop
Bonneville Belt Bitch
60ragtop is offline
PostPosted: Mon Dec 26, 2016 10:15 am    Post subject: Re: Snap On tools for Volkswagen Reply with quote
here's another Snap-On brake adjuster -bottom and a MAC on the top.
Have some of the other ones in my box as well for over 35 years.
Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote:
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote:
maybe he just snapped cause his car sucked Wink
vdubmyk
vdubmyk is offline
PostPosted: Fri Dec 30, 2016 11:51 am    Post subject: Re: Snap On tools for Volkswagen Reply with quote
I have a few of the Snap-on .006 12 inch long feeler gauges to adjust the valves.
64 stock bug, 12V (converted 6v unit), 40 hp, all documents even sales contract and dealer window sticker!
2Pack
2Pack is offline
PostPosted: Wed Jan 04, 2017 12:41 pm    Post subject: Re: Snap On tools for Volkswagen Reply with quote
Cool thread. I always like finding snap-on VW tools.
Here's one not posted yet. 36mm nut whacker. Date coded 1983.
Please buy my Treasure
Cusser
Cusser is offline
PostPosted: Mon Jan 30, 2017 3:05 pm    Post subject: Re: Snap On tools for Volkswagen Reply with quote
My only Snap-On tool, 8mm triple square drive bit for CV bolts, purchased pre-1975.
Lind
Lind is offline
PostPosted: Thu Feb 16, 2017 3:31 pm    Post subject: Re: Snap On tools for Volkswagen Reply with quote
S5908
tool for removing dash escutcheons.
Wanted:
diablosandwich
PostPosted: Sun Jul 02, 2017 7:42 am    Post subject: Re: Snap On tools for Volkswagen Reply with quote
Snap on 13mm Temperature sensor socket S5909
1966 Java Greens
diablosandwich
PostPosted: Tue May 22, 2018 7:06 pm    Post subject: Re: Snap On tools for Volkswagen Reply with quote
Snap on S5910 Ball joint eccentric tool. 36mm 13 inches long.
1966 Java Greens
rock25rock
rock25rock is offline
PostPosted: Thu Jun 04, 2020 12:29 pm    Post subject: Re: Snap On tools for Volkswagen Reply with quote
In need of the S5915 oil cooler tool. If anyone has one they are willing to sell, Or knows where to get one, please contact me, thanks.
oscarsnapkin
oscarsnapkin is offline
PostPosted: Sun Jan 03, 2021 6:38 am    Post subject: Re: Snap On tools for Volkswagen Reply with quote
Anyone know if Snap-On made a tool for removing the oil filler on Type 1 engines? I tried googling but I couldn’t come up with anything. Would love to get a part# if it exists.
- 1977 CEI Sunroof Bus 2.0L F.I. Hydraulic Lifters
- 1973 Thing
"It’s so easy to laugh, it’s so easy to hate, it takes strength to be gentle and kind."
61SNRF
61SNRF is offline
PostPosted: Sun Jan 03, 2021 8:08 am    Post subject: Re: Snap On tools for Volkswagen Reply with quote
Not unless you count this...
-Bruce
An ounce of prevention is worth a pound of cure.
61SNRF
61SNRF is offline
PostPosted: Fri Jan 08, 2021 4:16 pm    Post subject: Re: Snap On tools for Volkswagen Reply with quote
Special 8mm triple square magnetic socket for AutoStick torque converter bolts.
-Bruce
my3bugs
my3bugs is offline
PostPosted: Thu May 01, 2025 4:12 pm    Post subject: Re: Snap On tools for Volkswagen Reply with quote
now i would sure like to have the 13/14 S wrench . but i do have this 13/14 . when i first met my wife 30 some years back she had this wrench in a Dodge Astro van . i quickly confiscated that wrench some how Smile she is still here so all is well . it doesnt fit nearly as nice as the S wrench BUT it still gets the job done .... dont know if it was made for VW work . but i keep this wrench in the bug and HANDY !!!
fits like the rear carb nut , fits lots of things , takes quite a few resets but gets the job done .
now i just searched ebay for the 13/14 S wrench , it appears they can be had for 25 to 35 clams each , i never knew .
this one shows the off set 13MM angle best
iowegian Premium Member
Samba Curmudgeon
iowegian is offline
PostPosted: Fri May 02, 2025 1:08 pm    Post subject: Re: Snap On tools for Volkswagen Reply with quote
I don't own any VW specific Snap-On tools, but I sold my Beetle to the retired CEO/President/ Chairman of Snap-on. Does that count????
my3bugs
my3bugs is offline
PostPosted: Wed May 07, 2025 11:45 am    Post subject: Re: Snap On tools for Volkswagen Reply with quote
im telling ya , just talking about that S wrench the other day made me go n buy one Smile
it just arrived . so i run out to my bug and OH how sweet it fits getting to that back carb nut , the distributor clamp ect ....... im happy to have it .
Bruce
Bruce is offline
PostPosted: Wed May 14, 2025 2:46 am    Post subject: Re: Snap On tools for Volkswagen Reply with quote
This tool has a slotted screwdriver attached to the large knob, then takes a ½" drive socket.
This tool looks like it was specifically made to adjust the valves on a VW, but since it was made in 1954, it must have been for some other application.
Bruce
Bruce is offline
PostPosted: Wed May 14, 2025 2:50 am    Post subject: Re: Snap On tools for Volkswagen Reply with quote
Also works well to get the top inboard nut holding the heaterboxes to the heads.
As soon as I saw this S-wrench in the Snap-On catalog, I had to have it. That was over 30 years ago!
