Headlight switch dismantle
babacoolwesty
babacoolwesty is offline
PostPosted: Thu Apr 13, 2017 10:22 am    Post subject: Headlight switch dismantle Reply with quote
Has anyone ever pulled appart a headlight switch?? Mine has been exposed outside for years and has sand in it.. it still works with some crunch but I would like to open it and clean it .. do I need to drill the small rivet? Is the shaft removable?
It has the wheel in it for a dimmer anyone knows the ohm value range that is normal??
I have bent the 4 corners but I wanted your experience feedback before forcing anything
THANKS!![/img]
kreemoweet
kreemoweet is online now
PostPosted: Thu Apr 13, 2017 5:12 pm    Post subject: Re: Headlight switch dismantle Reply with quote
Check it out: https://www.thesamba.com/vw/forum/viewtopic.php?t=658907
'67 bug: seized by the authorities
