Evangelinesdream Samba Member
Posted: Tue Nov 19, 2024 4:14 pm Post subject: Hall effect sensor connector |
| Hello! I am looking to replace the connector to my hall effect sensor as the wiring has gone bad. The mechanic said the sensor itself looks good just the wiring. I'm having a bit of trouble finding a replacement and was told the volkswagen does not make them anymore. Any advise would be greatly appreciated! (For context, I have a 1981 volkswagen vanagon). |
E1 Samba Member
Joined: January 21, 2013 Posts: 8621 Location: Westfalia, Earth
Posted: Tue Nov 19, 2024 4:29 pm Post subject: Re: Hall effect sensor connector |
Being it doesn’t show as working for an air-cooled, this probably won’t.
But just showing it IS available on later water-cooleds.
Also this is a wonderful vendor, takes phone calls, and Ken loves to help. He’ll know your options as well as anyone.
https://www.vanagain.com/product/hall-sending-unit-plug-repair-kit
Aside, Welcome! _________________ If ever twice as rich, we’re gettin’ a double-wide
’84 “Westfailure”/2.1 Digijet/5.43 Ring & Pinion/Peloquin/D-rated BFG KO2s
AI has spoken to further illiteracy, to steal, to cheat, and to replace humans |
Posted: Tue Nov 19, 2024 6:42 pm Post subject: Re: Hall effect sensor connector |
| Unless you know for sure that your Hall sensor isn't all that old, I would just replace it as the electronic don't last forever. |
borninabus Samba R&D Dept.
Joined: May 18, 2006 Posts: 4774 Location: Arizona Highways
Posted: Tue Nov 19, 2024 9:32 pm Post subject: Re: Hall effect sensor connector |
here are your pics from the gallery
unfortunately, the plug is specific to air cooled, CA spec'd vans
i can see some questionable wiring that will need to be cleaned up, probably cut back and properly replaced. if the plug is not physically broken, you're either going to have to try and use it (possibly retro-fit the guts of a replacement module to what you have?) or adapt to a whole new digifant style plug. _________________ 88 Van WBX, A/T - 93 Multivan 5cyl 5M/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport |
do.dah Samba Member
Joined: August 27, 2015 Posts: 850 Location: Washington
Posted: Sat Nov 23, 2024 10:15 am Post subject: Re: Hall effect sensor connector |
| borninabus wrote: |
i can see some questionable wiring that will need to be cleaned up, probably cut back and properly replaced. if the plug is not physically broken, you're either going to have to try and use it (possibly retro-fit the guts of a replacement module to what you have?) or adapt to a whole new digifant style plug. |
Just an FYI. Vanagain is now 3d printing digifant and digijet hall plugs.
I have no experience with either one, I'm just on his mailing list and noticed them. |
Posted: Sat Nov 23, 2024 3:09 pm Post subject: Re: Hall effect sensor connector |
| borninabus wrote: |
Since the aircooled and the Digijet both have vacuum advance, can the Digifant parts be used on either? |
