chrissev2 Samba Member
Posted: Thu Jun 08, 2017 7:42 am Post subject: Vanagon Cooling Fan |
Interesting and so far unsolveable issue with an 86 Westy cooling fan. Fan is the two speed variety (dealer installed AC, no longer works). The radiator fan does not run, at all.
I have jumped all of the wires at the thermostat on the rad, in many different combinations, and all together at once. Nothing happens. I replaced the fan with a brand new unit which I bench tested on 12 volts. It ran fine on the bench test, does not run at all in the Vanagon. I replaced the radiator and the thermo switch. I bled the cooling system and it works fine. Rad heats up like it should. Got all the air out of the top bleeder hole.
I know old VW electrical systems can be frustrating. With my 1980 rabbit I simply gave up on the cooling fan circuit and I run the fan straight off the battery with a 30 amp in line fuse. It works great. Doesn't go near the fuse box.
Can I do this with the Vanagon? Ie, can I simply wire the two hot wires directly to the battery, through the thermo switch and to the fan? Or will this break something? I see that this Vanagon's low speed fan appears to run directly through the fuse box to the fan (but it doesn't work) and the high speed fan appears to use a relay. As I said, the fan does not run at all so I am just guessing as to how it might work.
Also, where is the ground? I see no ground wire. Just three red wires, hooked up to the fan motor. It should have a ground shouldn't it?
Thanks for any help or stickies on this subject.
Chris _________________ 2024 GLI Jetta 6spd manual
2023 VW Atlas 3.6 VR6 Highline
1978 Volkswagen super beetle convertible
1992 Eurovan 2.5 5spd westfalia |
kourt Samba Member
Joined: August 13, 2013 Posts: 2313 Location: Austin, TX
Posted: Thu Jun 08, 2017 8:35 am Post subject: Re: Vanagon Cooling Fan |
GoWesty sells a fan grounding kit that has some photos that might be informative. Check it out:
http://www.gowesty.com/product-details.php?v=&id=24359
One of the wires should be brown--that is the ground wire.
The cooling fan circuit is remarkably simple. It is always live (it can still run in key-off condition), and is regulated by the thermoswitch in the radiator. If this were my van I would try to preserve that system as originally designed.
If I had to rig up something else I would put a relay on one of the ignition wires and let that relay control the current to the fan directly from the battery, fused near the battery, with really good grounds... but try to fix it properly first.
kourt |
PDXWesty Samba Member
Joined: April 11, 2006 Posts: 6344 Location: Portland OR
atomatom Samba Member
Joined: May 15, 2012 Posts: 1911 Location: in an 84 Westy or Bowen Island, BC
Posted: Thu Jun 08, 2017 8:56 am Post subject: Re: Vanagon Cooling Fan |
Quote: |
Does the fan turn on when you turn the air conditioning fan on? It should run when the AC is on even though it is not hooked up. |
The fan does not turn on, at all. I have not been able to get it to run. Not with the AC turned on, not by jumping the leads on the radiator thermo switch. Nothing turns it on. I did bench test it (brand new fan) before I put it in, and it runs fine on 12 volts DC. But it will not run on the wiring in the van. I do not get any voltage anywhere in the fan circuit, at any time.
That is why I was wondering about the ground. I can't see one. I figured if the ground was loose or disconnected, it would cause the issue I am having as it would create a completely open circuit which could not function. _________________ 2024 GLI Jetta 6spd manual
Posted: Thu Jun 08, 2017 8:58 am Post subject: Re: Vanagon Cooling Fan |
kourt wrote: |
kourt |
That makes sense. Add a ground wire. I am going to do that and see if it works. I feel like I have an open circuit problem as I cannot get voltage anywhere. A bad ground would cause that. _________________ 2024 GLI Jetta 6spd manual
Posted: Thu Jun 08, 2017 9:04 am Post subject: Re: Vanagon Cooling Fan |
but one of your three red wires should be a ground. clean them up carefully before adding another ground. since you had the motor out, you may have switched them up, in which case, the fuse hopefully got it. _________________ 84 Vanagon Westy, 1.9L, California raised but defected to Canada. |
Vanagon Nut Samba Member
Joined: February 08, 2008 Posts: 10495 Location: Sunshine Coast B.C.
Posted: Thu Jun 08, 2017 9:43 am Post subject: Re: Vanagon Cooling Fan |
atomatom wrote: |
but one of your three red wires should be a ground. clean them up carefully before adding another ground. since you had the motor out, you may have switched them up, in which case, the fuse hopefully got it. |
Maybe I'm misunderstanding (OP mentions running new wires) but in 86+ AC diagrams, I see a brown wire from ground to fan motor.
@ the OP: I think your fan should be a 3 speed fan FWIW. This is what I see in '86 + Bentley diagrams. The resistor provides the first 2 speeds then the "3rd stage" is + controlled by a relay straight to fan, no resistors.
With battery(s) disconnected, its easy to use your VOM to check if ground wire is in fact connected to ground. It goes to "10" which is near the fuse panel. That would be at one of the ground stars.
(VW Gas I4)
1988 Westy DIY 50º ABA
VE7TBN |
Posted: Thu Jun 08, 2017 10:18 am Post subject: Re: Vanagon Cooling Fan |
The cooling fan relay could be bad too or have a loose connection. Start in the lower left corner of the wiring diagram posted above, at the fan, and start checking components. The line at the bottom of the diagram is the ground. Wires marked BR are brown and grounds. _________________ 89 Westy 2.1 Auto |
termuehlen  Samba Member
Joined: May 02, 2012 Posts: 1032 Location: Redwood City
Posted: Thu Jun 08, 2017 10:29 am Post subject: Re: Vanagon Cooling Fan |
The fan motor should have two electrical posts. One is hot and one is ground. You can see them in the gowesty "additional ground wire" picture linked above by Kourt. Two red wires go to the 12V post. One brown wire goes to the ground post. I would check to make sure you are wired correctly at the fan motor and that the ground is indeed, grounded. _________________ 1988 Westfalia automatic Subaru OBD1
1986 syncro tintop wbx |
Posted: Fri Jun 09, 2017 9:19 am Post subject: Re: Vanagon Cooling Fan |
Thanks for all of the helpful suggestions. Going to tackle this tomorrow (Saturday). One thing I still don't understand is there is no brown wire going to the fan. There are two red wires, going together and then a striped red and black wire. I'll take a pic over the weekend. I have not been able to find a brown wire.
What I'm going to do is just hook the ground terminal on the fan directly to the van body with some of the brown ground wire I have lying around. See if that works. _________________ 2024 GLI Jetta 6spd manual
Posted: Fri Jun 09, 2017 9:50 am Post subject: Re: Vanagon Cooling Fan |
chrissev2 wrote: |
In OEM form, there should be a brown wire. I think what you may be looking at is the connector to the thermo switch at the radiator.
This may not be exactly the same as your model but an image of rad fan connector from the gallery here. Lower your spare tire "clam" and have a look. You should see something like this:
connector to thermo switch at radiator:
Relays aside, the thermo switch is what turns the fan on/off. _________________ 1981 Westy DIY 15º ABA
(VW Gas I4)
VE7TBN |
Posted: Sat Jun 10, 2017 8:13 pm Post subject: Re: Vanagon Cooling Fan |
So I dug into this mystery on Saturday. Determined the following:
1. Ground to the fan was open. So I have wired a second ground to the van body. Following that, still nothing worked.
2. The resistor behind the driver's side headlight was bad. I had a spare one so I swapped it out. The connector for the resistor was also very rusty, so spent time time cleaning that. When I was done, the low speed fan worked!
3. High speed fan: This one was tricky. The relay is supposed to be relay #5 as per Bentley and the fuse is supposed to be fuse position #1. Neither of these turned out to be true. The relay was actually sitting up top of the fuse box, on the firewall, under one of the heater ducts. It was of course covered in rust and not working as the windshield seal used to be bad before I replaced it, and water got all over it. Swapped in a new relay and cleaned up the connectors, and I had a high speed fan again.
While I was in there I figured out why the ground was not working. The ground tree that it is attached to was covered in rust. So cleaned that up, and I now have the fan properly grounded in two places.
So the usual Vanagon cluster f*ck situation. Pretty much everything was broken.
Interestingly enough, the only thing that WAS working was the feed wire from the battery. That is the first thing I noticed when I checked stuff with the multi testor. Testing on the main red lead to the rad thermo sensor across to the body (ground) gave me hot 12 volts. So I was like, this feed wire is hot, so all the problems have to be after the feed wire.
As I said, turned out pretty much everything was causing problems. _________________ 2024 GLI Jetta 6spd manual
Posted: Sat Jun 10, 2017 8:16 pm Post subject: Re: Vanagon Cooling Fan |
timichango Samba Member
Joined: April 07, 2012 Posts: 858 Location: Squamish, BC, Canada
Posted: Sat Jun 10, 2017 9:52 pm Post subject: Re: Vanagon Cooling Fan |
I've mentally added all of the mentioned failure points to my "list of potential causes for van shenanigans" repository. _________________ . . . . . . . . . . . . . . . . . . .
Vroomhilde-San: Our 1991 Silver Vanagon Westy automatic + Subie EJ25 |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32987 Location: Reading Pennsylvania
Paulbeard Samba Member
Posted: Sun Jun 11, 2017 9:53 am Post subject: Re: Vanagon Cooling Fan |
timichango wrote: |
"van shenanigans". |
Vanagon shenanigans?  _________________ Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
Formerly -> Steward of a 73 Super Beetle (Beater) and 67 Beetle 1300 (Little Max) both names by POs
— dhaavers |
Wendy.the.Westy Samba Member
Joined: August 27, 2012 Posts: 93 Location: Redding, CA
Posted: Sun Jun 11, 2017 12:10 pm Post subject: Re: Vanagon Cooling Fan |
djkeev wrote: |
FYI...... Bentley's wiring diagram and VW's actual wiring on the early 2.1 A/C radiator fans do NOT agree.
Dave |
Exactly correct for a dealer added AC system. The actual wiring color coding is a mix between the non-AC schematic and the AC specific schematic. I recommend using the AC specific schematic but adding corrective notes to effectively as-built the system. _________________ ID.BUZZ |
Posted: Mon Jun 12, 2017 11:05 am Post subject: Re: Vanagon Cooling Fan |
Thanks for all the help. Next job is to figure out why the instrument panel lights don't work (headlights work fine, but no panel lighting at all). I expect that will be another problem with multiple causes..... _________________ 2024 GLI Jetta 6spd manual
Posted: Mon Jun 12, 2017 11:18 am Post subject: Re: Vanagon Cooling Fan |
chrissev2 wrote: |
Thanks for all the help. Next job is to figure out why the instrument panel lights don't work (headlights work fine, but no panel lighting at all). I expect that will be another problem with multiple causes..... |
Burnt out bulbs are extremely common. I'd buy some new ones and try that first. _________________ 89 Westy 2.1 Auto |
