TheWilliamAlan Samba Member
Posted: Mon Aug 21, 2017 6:07 pm Post subject: Hitch receiver for Cargo Carrier |
My father in law gave me a little cargo tray about 4'x2' that hooks into a tow hitch receiver. My 91 Syncro doesn't have a hitch. If I only use it for this cargo tray would I be safe building a hitch that just bolts to the loops under the bumper? _________________ '58 Euro Spec Beetle
'91 Vanagon Syncro 2.1 |
pedrokrusher Samba Member
Joined: July 11, 2011 Posts: 654 Location: Montreal, Quebec, Canada
Sodo Samba Member
Joined: July 06, 2007 Posts: 10597 Location: Western WA
Posted: Mon Aug 21, 2017 7:35 pm Post subject: Re: Hitch receiver for Cargo Carrier |
Thx PedroC glad u like my hitch design. But the hitch I had before I rebuilt it .... was the standard style that attaches to the two "tow loops" and it was rated for 500 lb. thats a LOT of cargo. (!! ERROR !! , I don't have the sticker anymore but I think it was rated for 100lbs of tongue weight at the ball)
500 lbs is a large motorcycle (that's too much for a vanagon!) I think it would be fine for your cargo shelf. I doubt you'll even have 200 lbs, that would be so much it would cover the van.
....KTMs, GasGas, SPOT mtb
Posted: Tue Aug 22, 2017 8:09 am Post subject: Re: Hitch receiver for Cargo Carrier |
Ok. So I could bolt to the loops and run some supports to the bars under the motor. No prob. Thanks! I saw that thread but didn't realize he had removed the loops so I wasn't sure what he had done. Reading more carefully he welded to the supports for the loops instead of bolting to them. _________________ '58 Euro Spec Beetle
Sodo Samba Member
Posted: Tue Aug 22, 2017 9:41 am Post subject: Re: Hitch receiver for Cargo Carrier |
My hitch (modified extensively) attaches to the tow loops but has added supports to the Syncro skid bars below, to be able to carry a motorcycle (with confidence). _________________
campism Samba Member
Joined: September 07, 2007 Posts: 4665 Location: Richmond VA
Posted: Tue Aug 22, 2017 3:53 pm Post subject: Re: Hitch receiver for Cargo Carrier |
Sodo wrote: |
...500 lbs is a large motorcycle (that's too much for a vanagon!) I think it would be fine for your cargo shelf. |
Five hundred pounds is about average for many midsized street bikes. The large ones easily top 800. _________________ '87 Westy in Wolfram Grey Metallic, tragically crushed by a falling hickory tree in my own driveway and now gone, leaving me Vanagonless and with no plans to replace it, alas. |
jberger Samba Member
Posted: Tue Aug 22, 2017 4:13 pm Post subject: Re: Hitch receiver for Cargo Carrier |
Cargo trays should not be installed on the typical bolt-on-to-tow-hook receiver hitches without other means of support. I have seen many tow hooks bend under quite minimal load and your tray will be dragging ground. Tongue weights are usually rated at the ball or close to it. If you put 500lbs 24" off the CL of the ball, well.. that's quite a lever. |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32983 Location: Reading Pennsylvania
Sodo Samba Member
Posted: Tue Aug 22, 2017 4:44 pm Post subject: Re: Hitch receiver for Cargo Carrier |
jberger wrote: |
Yes that's way too much. 200 lbs; 12" rearward might be a good limit for a cargo shelf on a Vanagon with a tow-hook mounted hitch.
Maybe filnd a 200 lb person, have them stand in the center of your cargo shelf and bounce on it. If you see any flexing, then find a different monkey that woughs less (150 lbs, 100 lbs) and reduce the 'weight limit' of your cargo extension accordingly. _________________
....KTMs, GasGas, SPOT mtb |
Wolfram Samba Member
Joined: June 23, 2005 Posts: 184 Location: Waiheke Island/On The Road USA
Posted: Tue Aug 22, 2017 4:47 pm Post subject: Re: Hitch receiver for Cargo Carrier |
As DJKEEV notes, Burley is the way to go. We have one and it is rock solid. Bolts to chassis rails. _________________ 88 Westy, '07 EJ25 Vanaru.
Either van-less on Waiheke Island in New Zealand where we spend the Southern summer, or Wolfram is in Seattle/Olympia in storage. |
Posted: Tue Aug 22, 2017 10:33 pm Post subject: Re: Hitch receiver for Cargo Carrier |
Sodo wrote: |
jberger wrote: |
Maybe filnd a 200 lb person, have them stand in the center of your cargo shelf and bounce on it. If you see any flexing, then find a different monkey that woughs less (150 lbs, 100 lbs) and reduce the 'weight limit' of your cargo extension accordingly. |
Re-read your post above. You make it sound like the tow-loop receiver hitch can carry 500lbs on a carrier. It simply can not. |
Sodo Samba Member
Posted: Wed Aug 23, 2017 10:42 am Post subject: Re: Hitch receiver for Cargo Carrier |
jberger wrote: |
Sodo wrote: |
Yes that's way too much. 200 lbs; 12" rearward might be a good limit for a cargo shelf on a Vanagon with a tow-hook mounted hitch. |
If anyone thinks I suggested 500 lbs, I apologize for that, and don't want wrong info on TheSamba. I walked out to the van and looked at the tow-loops. My hitch-rating sticker is long-gone but in my foggy memory it that may have stated 100 lbs tongue weight??? Certainly not 500 lbs! That rating means 100 lbs about 6 inches behind the bumper. Note that "200 lbs, 12 inches behind the bumper" is 4X overweight of the rating. It would take a lot of effort to get 200 lbs onto a cargo shelf, so that's not likely anyway.
A hitch mounted cargo carrier will clear out space inside the van and is useful. I would trust --->myself<--- to assess it's carrying capacity with some simple tests. But to stay within the hitch's tongue weight rating, the cargo shelf PLUS its cargo should be limited to 50 lbs. That's not much, but you can choose bulky, lightweight items. _________________
Zeitgeist 13 Samba Member
Joined: March 05, 2009 Posts: 12161 Location: Port Manteau
Posted: Wed Aug 23, 2017 10:58 am Post subject: Re: Hitch receiver for Cargo Carrier |
I like having a cargo carrier for carrying large bulky but not too heavy items that take up space inside the cabin. I made my own from a swing-down bike carrier, but next year I'll use a swing-out base unit. I needed to have the load platform higher in order to clear the road when I back out of my sloped driveway. I might use this one on my Vanagon if I can convert it to 1.25"
_________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
kamzcab86 Samba Moderator
Posted: Fri Aug 25, 2017 4:40 pm Post subject: Re: Hitch receiver for Cargo Carrier |
GoWesty receiver hitch (which uses the loops & reinforcement T-bar) + riser adapter + aluminum Hitch Haul (drilled new hitch pin holes for it to mount closer to the bumper):
Works for me... _________________ ~Kamz
2016 Golf GTI S
