chazjustchaz Samba Member
Posted: Sun Aug 30, 2020 7:53 pm Post subject: Quick walk through questions |
Will walk through front seats metal (both the actual seats ) but the metal
From a 72 bus fit in my 67 split
thank you |
pyrOman Fire Master
Joined: July 21, 2003 Posts: 12571 Location: Over 2002 posts deleted!
Posted: Mon Aug 31, 2020 8:14 am Post subject: Re: Quick walk through questions |
You have to try them, specially if they are as comfy as vanAgone ones. I have a set of vanAgone ones in the '68 Plump Truck which the driver seat fit right into the rails but the "locking" lever doesn't work so I put a bolt on it at my preferred setting. The passenger one is also "fixed" in place. Good luck!  _________________ Some people are so busy being clever they don't have time enough to be wise. |
Clara  Samba Member
Posted: Mon Aug 31, 2020 8:19 am Post subject: Re: Quick walk through questions |
| chazjustchaz wrote: |
thank you |
Do the seats from a bay fit into a 68 w/t?
No, they do not fit the mounts in the 67.
You could just set them there.
I am not sure what you mean by "walk through front seats metal"
The parts are not the same.
There is thread on w/t front seats in the FAQ:
https://www.thesamba.com/vw/forum/viewtopic.php?t=71827 |
hitest Samba Member
Joined: September 30, 2008 Posts: 10332 Location: Prime Meridian, ID
Posted: Mon Aug 31, 2020 9:19 am Post subject: Re: Quick walk through questions |
Until the OP clarifies... It sounds like you want to convert a common bench split into a W/T using (plentiful) bay seat pedestals? _________________
| EverettB wrote: |
FU#5 |
Posted: Tue Sep 01, 2020 10:03 pm Post subject: Re: Quick walk through questions |
Sorry, just to clarify the PO
cut out about 16” out of the bulk head to make it a crawl through
He made seat frames out of wood and put cushions.
I wanted to know it I keep it as is and I buy two seats
Can I mount right where the bench was
Or can I get the pedestals from a 72 or 68 bus weld then in and mount the seats
velvetgreen Samba Member
Posted: Tue Sep 01, 2020 10:36 pm Post subject: Re: Quick walk through questions |
I would go back to stock seats and bin those "seats" asap. Not too many people on here that are fans of "sawzall" walk thru's so probably gonna get some grief for that too.
All depends how much you care about originality and/or resale value vs "comfort" |
