2332cc build
Page: 1, 2, 3, 4, 5  Next
scotty timmerman
scotty timmerman is offline
PostPosted: Tue Sep 19, 2017 7:55 pm    Post subject: 2332cc build Reply with quote
I have been collecting parts to build a 2332 for awhile now. I have reacently dropped off the rotating assembly to be dynamically balanced. What I have done so far is modified the the crank for better oiling, installed total seal rings, got some light weight wrist pins cut to lenght. The wrist pins are now 16 grams lighter then the ones that came with the aa pistions. Balanced the pistions and balanced the rods. Once I get the rotating assembly back I will start assembling the bottom end.
71 ghia coupe: Build thread http://www.thesamba.com/vw/forum/viewtopic.php?t=511738&highlight=
71 type 3 fastback auto
71 type 3 fastback manual
73 super beetle
57 oval: build thread: https://www.thesamba.com/vw/forum/viewtopic.php?p=8616563#8616563
63 beetle reassembly: http://www.thesamba.com/vw/forum/viewtopic.php?p=7458619#7458619
2332cc engine build: https://www.thesamba.com/vw/forum/viewtopic.php?p=8608429&highlight=#8608429
84 vanagon westfalia wolfsburg edition
Dauz
Dauz is offline
PostPosted: Tue Sep 19, 2017 8:20 pm    Post subject: Re: 2332cc build Reply with quote
Best of luck..
Onceler
Onceler is offline
PostPosted: Tue Sep 19, 2017 8:46 pm    Post subject: Re: 2332cc build Reply with quote
What did u modify on the crank for better oiling?
1972 Karmann Ghia
scotty timmerman
PostPosted: Tue Sep 19, 2017 9:22 pm    Post subject: Re: 2332cc build Reply with quote
I chamfered all the oil feed holes for the rods and mains.
73 super beetle
bugguy1967
bugguy1967 is offline
PostPosted: Tue Sep 19, 2017 9:41 pm    Post subject: Re: 2332cc build Reply with quote
It's best to balance after mock-up, just in-case you need to grind on the throws to avoid the camshaft. The oiling mods do change things, but it's probably too small of a difference.
Make sure also to prep those cylinders before installing those new rings in there.
pondervwmike
pondervwmike is offline
PostPosted: Thu Sep 21, 2017 3:25 pm    Post subject: Re: 2332cc build Reply with quote
Awesome build keep up the good work and keep us posted. I am building a stroker as well.
1967 Cal Look Beetle Street Car in re-restoration,customization. Mom and Dad bought it in 1983 when I was 4.
2010 VW Tiguan
2000 BMW 528i
1997 Jeep Cherokee
2127cc build thread https://www.thesamba.com/vw/forum/viewtopic.php?t=681556&highlight=
nsracing
nsracing is offline
PostPosted: Thu Sep 21, 2017 6:18 pm    Post subject: Re: 2332cc build Reply with quote
It does not make sense to get the crank balanced and then grind it/modify it again after it gets home. That defeats the purpose of the balance work.
Get it all mocked up to final stage and then when you are satisfied, get the parts balanced.
porkchop-rob
porkchop-rob is offline
PostPosted: Fri Sep 22, 2017 9:14 am    Post subject: Re: 2332cc build Reply with quote
If I am reading correctly, the OP did the crank modifications BEFORE he sent it to be balanced.
1965 Beetle
1968 Beetle Baja (Son's First Car)
1976 Bus with Subaru (Wife's Riviera Camper)
fivelugshortaxle
fivelugshortaxle is offline
PostPosted: Fri Sep 22, 2017 8:25 pm    Post subject: Re: 2332cc build Reply with quote
To everybody building a stroker. Make it as strong as your pocket will allow and research cam and heads. You won't regret it. Love my 2276...you'll love your buiilds.
Good things come to those who wait.
2332 with lots of goodies....
Rotating assembly balanced by Brothers VW
4340 84mm crank
AA 94mm p&c' s
Total seal 2nd ring, rest are Grants
5.5 h beams
Magnum straight cuts
Steve Long XR310 on a 106
CB 1.4 rockers
CB Magnaspark 2 distributor
NGK D7ea plugs
A1 lowdown 1 3/4 with single muffler
Dellorto 48's with 40 venturies
Kennedy Stage 2 with Daiken disc
scotty timmerman
PostPosted: Sat Oct 07, 2017 9:31 pm    Post subject: Re: 2332cc build Reply with quote
Mocked up the case with a crankshaft so I could cut it for a sand seal with my gene ber cutter.
73 super beetle
hobbybob517
hobbybob517 is offline
PostPosted: Sun Oct 08, 2017 1:01 am    Post subject: Re: 2332cc build Reply with quote
Very nice tool, looks like a good clean cut.
THE BUILD http://www.thesamba.com/vw/forum/viewtopic.php
SBD wrote:
3 million rpm? Well there's your problem! No wonder it blew up!
scotty timmerman
PostPosted: Thu Oct 12, 2017 8:27 pm    Post subject: Re: 2332cc build Reply with quote
I have been doing the bob Hoover oiling modifications to the case. Got the extra oil gallary drilled and cam saddle oil groves widened. Also opened up the D shaped passage for the cam scraper and the passages under the center main saddle.
One question I have is about the lifter modification connecting the two oil groves. Should I do it to all the lifters or only the four that go on the 1/2 side?
I believe i have the original engine number from the car that this engine will be going in to. So I got some steel stamps and stamped it in to the case.
73 super beetle
vwracerdave
vwracerdave is offline
PostPosted: Thu Oct 12, 2017 8:32 pm    Post subject: Re: 2332cc build Reply with quote
Modify all 8 lifters.
croSSeduP
croSSeduP is offline
PostPosted: Thu Oct 12, 2017 8:59 pm    Post subject: Re: 2332cc build Reply with quote
Nicely done, Scott. Great pics.
Gig Harbor, eh? I live across the Narrows. We should connect. I know VERY FEW aircooled VW gear heads in the area. It's like a wasteland. Those of us around here who are into it should connect.
BTW, the engine sitting on my stand REALLY close to getting fired for cam break in is a 48 IDA'd 2276 monster. Check out my '67 progress.
Peace.
Please check my '67 sedan project progress!
http://www.thesamba.com/vw/forum/viewtopic.php?t=502253&highlight=
scotty timmerman
PostPosted: Fri Oct 13, 2017 9:31 am    Post subject: Re: 2332cc build Reply with quote
I go to most the shows around here usually in my ghia (build thread in my discription). I might be at the octobugfest meet up in Tacoma on the 28th in my orange and white bus.
73 super beetle
scotty timmerman
PostPosted: Tue Oct 31, 2017 9:05 pm    Post subject: Re: 2332cc build Reply with quote
Got the rotating assembly back. Also had the main bearings grooved so there is 360 degrees of oiling to the rods.
73 super beetle
scotty timmerman
PostPosted: Sat Nov 04, 2017 8:51 pm    Post subject: Re: 2332cc build Reply with quote
Got the crank assembled and set in the case. Rods are 5.5 Chevy journal. Did a little bit of clearance go on the cam for the rods. Didn't need much. The cam is a w130. No clearance issues between the lobes and crank.
73 super beetle
fivelugshortaxle
PostPosted: Sat Nov 04, 2017 10:58 pm    Post subject: Re: 2332cc build Reply with quote
Looking good. I'll be posting pics of my own 2332 build within the next couple of weeks. Interesting you're using a w130. I went with a SLR XR310 on 110 lobe.
4340 84mm crank
AA 94mm p&c' s
5.5 h beams
CB 1.4 rockers
NGK D7ea plugs
scotty timmerman
PostPosted: Fri Nov 10, 2017 12:00 am    Post subject: Re: 2332cc build Reply with quote
Final assembly on the bottom end.
73 super beetle
nsracing
nsracing is offline
PostPosted: Fri Nov 10, 2017 12:31 am    Post subject: Re: 2332cc build Reply with quote
When I build a stroker, I will do the trial assembly all the way to the rocker geometry. I will install everything except for the rings. I mount light springs for the topend so I can observe the rocker system in movement.
Once I am happy w/ the rocker system, then I will cut the pushrods to final size.
When everything checks out, then I will take it apart and clean the parts for the last time to get ready for the sealing.
I do not seal that lower end until the whole engine has been mocked up to its finality. Everybody has their way, but I find it is more efficient to do the mockup all the way to the end see it work together before deciding to seal it.
I know people that have sealed the lower end and something hangs up and then had to clean everything. But ..your engine so you do your way.
It is all good.
Page 1 of 5
