HarryFD Samba Member
Joined: February 24, 2012 Posts: 751 Location: Portland, OR
Posted: Wed Nov 08, 2017 10:54 pm Post subject: 1970 Bus High Beams turn on when using turn signal |
In my 1970 Bus, any time I use my turn signal, my high beams come on. I can turn them off but it is a pain.
Can I repair the switch? How? I looked for a thread on this but no luck.
Thanks! _________________ 1970 Deluxe Sunroof Bay Brilliant Blue/Cloud White
1973.5 911 Targa
2009 MB C300 |
SGKent Samba Member
Posted: Mon Nov 13, 2017 9:56 am Post subject: Re: 1970 Bus High Beams turn on when using turn signal |
replace the switch _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Mon Nov 13, 2017 10:09 am Post subject: Re: 1970 Bus High Beams turn on when using turn signal |
SGKent wrote: |
replace the switch |
Thanks that is my Plan. Have part on bench but was curious is they could be repaired. _________________ 1970 Deluxe Sunroof Bay Brilliant Blue/Cloud White
1973.5 911 Targa
2009 MB C300 |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51182 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Mon Nov 13, 2017 10:10 am Post subject: Re: 1970 Bus High Beams turn on when using turn signal |
Post some pics, maybe we can see something obvious. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Mon Nov 13, 2017 5:22 pm Post subject: Re: 1970 Bus High Beams turn on when using turn signal |
busdaddy wrote: |
Post some pics, maybe we can see something obvious. |
Busdaddy. I decided just to get a new one. Due to some other needs I will be nursing my existing one along until sometime in December. When I pull it out, I will post photos to share with the brain trust.
FWIW my 911 developed a similar issue s few years back. On the Peilcan BBS they have a “quick fix” for it. I used it and on the third time it failed I decided to just get a replacement. _________________ 1970 Deluxe Sunroof Bay Brilliant Blue/Cloud White
1973.5 911 Targa
2009 MB C300
Posted: Mon Nov 13, 2017 6:07 pm Post subject: Re: 1970 Bus High Beams turn on when using turn signal |
I hope whoever you bought it from has a longer than 30 day return policy, it often takes 2 or 3 tries before you find a winner, those new switches are the vanguard of "lowest bidder gets the contract" manufacturing. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Thu Nov 23, 2017 1:29 pm Post subject: Re: 1970 Bus High Beams turn on when using turn signal |
I was looking at my Bentley for how to replace the turn signal. They want me to remove the ignition switch as part of the listed process. I am thinking that this step is unnecessary. I am thinking I will need to do the following:
1: Disconect the trun sgnal switch from the column.
2: Remove the steering wheel.
3: Loosen steering column from dash board.
4: Disconnect wires from under the dash to allow removal of old switch
5: Pull out old wires
6: Snake in new wires and install on terminals
7: Reverse steps 1-4 to complete.
Thoughts? _________________ 1970 Deluxe Sunroof Bay Brilliant Blue/Cloud White
1973.5 911 Targa
2009 MB C300 |
heimlich VWNOS.com
Joined: November 20, 2016 Posts: 6627 Location: Houston, Texas
Posted: Thu Nov 23, 2017 3:31 pm Post subject: Re: 1970 Bus High Beams turn on when using turn signal |
Do you use your high beams? Maybe just disconnect that wire. _________________ www.vwnos.com [email protected]
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10773 Location: iT StiNgeD iTseLf tO dEAd
Posted: Thu Nov 23, 2017 4:03 pm Post subject: Re: 1970 Bus High Beams turn on when using turn signal |
stop pulling up on the switch arm (it's easy to do) when you're using the turn signal. _________________ thebucket: I invested in hoodride, now DBD won't return my call?
hazetguy: invested?
thebucket: Yeah Haze, its where people put money into a company in hopes of a return on their money |
Posted: Thu Nov 23, 2017 5:49 pm Post subject: Re: 1970 Bus High Beams turn on when using turn signal |
kawfee wrote: |
Do you use your high beams? Maybe just disconnect that wire. |
Funny. Sorry, I want them to work. _________________ 1970 Deluxe Sunroof Bay Brilliant Blue/Cloud White
1973.5 911 Targa
2009 MB C300 |
Posted: Thu Nov 23, 2017 5:50 pm Post subject: Re: 1970 Bus High Beams turn on when using turn signal |
hazetguy wrote: |
stop pulling up on the switch arm (it's easy to do) when you're using the turn signal. |
I tried that. The switch has a hair trigger. I had a similar issue with my 911. Switch was filing. _________________ 1970 Deluxe Sunroof Bay Brilliant Blue/Cloud White
1973.5 911 Targa
2009 MB C300 |
