tmart Samba Member
Posted: Thu Dec 14, 2017 8:55 pm Post subject: Re: Too little endplay? |
jberger - no, I got rid of that one. That was the one that made me think I needed to JB Weld though. Not necessary with this new washer. _________________ 1990 Vanagon 2.2L Manual
The van that samba built |
tmart Samba Member
Posted: Thu Dec 14, 2017 11:42 pm Post subject: Re: Too little endplay? |
It worked!
It took a few iterations to get the spacers the right dimensions but it worked. It took 2 spacers and was right on the money - .004"!
A few pics:
Thanks for the help everyone! _________________ 1990 Vanagon 2.2L Manual
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32639 Location: Reading Pennsylvania
Bulli Klinik Samba Member
Joined: January 16, 2005 Posts: 2079 Location: Bulli Klinik, Colorado Springs
Posted: Fri Dec 15, 2017 9:06 am Post subject: Re: Too little endplay? |
That's an interesting way of doing things. Hopefully the paper doesn't interfere with the rubber o-ring or decompose under use.
By the way, it's not always necessary to use three shims to reach your goal of .003-.006 end play. Use two or four if that's what it takes. The motor wont know the difference. _________________ I've never met a Bus I didn't like.
Mike K
Bulli Klinik
Colorado Springs |
jberger Samba Member
Posted: Fri Dec 15, 2017 9:43 am Post subject: Re: Too little endplay? |
Check the runout on the flywheel now. I know early bugs used a "paper" gasket.. but I just don't like the looks of that. Something else is amiss here.
J |
Posted: Fri Dec 15, 2017 10:25 am Post subject: Re: Too little endplay? |
Bulli Klinik wrote: |
By the way, it's not always necessary to use three shims to reach your goal of .003-.006 end play. Use two or four if that's what it takes. The motor wont know the difference. |
Well, the three shims is a much talked about procedure.
While some say four is OK virtually no one accepts two as a viable option.
Think of a roller bearing, outer race, inner race and center roller race.
The center of the three shims is in essence the rollers. It gets lubricated and they all spin, or not, at varying speeds.
Two shims simply takes the bearing comparison out and introduces the possibility of wear, over heating and siezure becoming very real.
No matter, Err on the side of caution..... use three shims.
Ghia
Vanagon
Beetle
Posted: Fri Dec 15, 2017 11:49 am Post subject: Re: Too little endplay? |
I would think that two would be fine with an automatic tranny. Really don't know for a manual with the pressure from the clutch being taken up by the shims. That said, an awfully lot of engines just have a thrust bearing sized to fit against the crank so the bearing to crank interface sees the full speed differential. |
Posted: Fri Dec 15, 2017 12:30 pm Post subject: Re: Too little endplay? |
All Porsche 356's and 912's use one shim. Same design except they get revved to 6500 rpm.
Ideally I would use a three shim stack, but what really matters is where it's set. I've used two and I've used four in air cooled motors. _________________ I've never met a Bus I didn't like.
Mike K
Bulli Klinik
Colorado Springs |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22671 Location: NYC/Upstate/ROW
Posted: Fri Dec 15, 2017 5:57 pm Post subject: Re: Too little endplay? |
I think this thread is done, right?
Cuddling, listening ,and not falling asleep works for me _________________ .ssS! |
tmart Samba Member
Posted: Sat Dec 16, 2017 10:42 am Post subject: Re: Too little endplay? |
Eh I went with three. My issue is I didn't have the right shims regardless. I would've needed 2 of the the hard to find .24mm shims. I did check the runout with and w/o the paper gasket. Pretty much unchanged. _________________ 1990 Vanagon 2.2L Manual
