mikemtnbike Samba Member
Joined: March 26, 2015 Posts: 2798 Location: North Carolina
Posted: Fri Jan 26, 2018 5:46 pm Post subject: Re: Vanagon Engine Removal --n00b questions |
You could just have some strong oxidization between the two components- like a seatpost stuck in a bike frame. Try soaking the points of contact with PB blaster, Kroil, or other high-quality penetrant and letting it sit overnight. Then, go to town on it. If can find a good fulcrum, could try a lever and/or whacking it with a deadblow hammer.
It will come off. _________________ 1991 Vanagon GL 2.1 AT Westfauxlia. "Frankie" Totaled https://www.thesamba.com/vw/forum/viewtopic.php?t=764510&highlight=carnage
2020 GTI SE manual |
VicVan Samba Member
Joined: July 01, 2015 Posts: 1845 Location: Vancouver Island, BC
Posted: Fri Jan 26, 2018 5:52 pm Post subject: Re: Vanagon Engine Removal --n00b questions |
Here's what is in OP's previous topic:
misterfeathers wrote: |
My van is blowing white smoke (coolant) on start-up until it warms up. I pressured tested the coolant and its leaking out of both head gaskets. The compression test came back 110,120,110, 145 and the leak down 36%, 30%, 8%, 12%.
In that case, I guess removing and examining the heads is the way to go indeed. And in this case, removing the engine makes sense. _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22673 Location: NYC/Upstate/ROW
Posted: Sat Jan 27, 2018 4:55 am Post subject: Re: Vanagon Engine Removal --n00b questions |
Gentle prying between AC and mount will move it. No blows or impacts, just pressure _________________ .ssS! |
Posted: Sat Jan 27, 2018 5:54 am Post subject: Re: Vanagon Engine Removal --n00b questions |
Abscate is probably right. I was going from 0 to 99 with my suggestion. There's a lot of numbers in between those. I guess I was assuming you'd already tried steps like gentle prying. _________________ 1991 Vanagon GL 2.1 AT Westfauxlia. "Frankie" Totaled https://www.thesamba.com/vw/forum/viewtopic.php?t=764510&highlight=carnage
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32644 Location: Reading Pennsylvania
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6833 Location: Fort Lauderdale, Fl.
Posted: Sat Jan 27, 2018 6:19 am Post subject: Re: Vanagon Engine Removal --n00b questions |
Can't seem to make it past one job before I get stuck again...doh!
Don't worry. That happens a lot until you buy experience through more tools to handle the unexpected!
Just take one thing at a time and suddenly there won't be anymore things. _________________ This free advice is worth exactly what you paid for it.
Posted: Sat Jan 27, 2018 7:05 am Post subject: Re: Vanagon Engine Removal --n00b questions |
Forgot to add to hit those points with some good penetrant oil ( not WD40) a day before, too. _________________ .ssS! |
misterfeathers Samba Member
Posted: Sun Jan 28, 2018 10:16 am Post subject: Re: Vanagon Engine Removal --n00b questions |
You y'all are the best!! Thanks for the encouragement. Back at it today to see if we can make any progress!! |
Posted: Mon Feb 19, 2018 10:19 am Post subject: Re: Vanagon Engine Removal --n00b questions |
A/C is off ...penetrating oil and breaker bar did the trick.
Things are moving well but am stuck on how to remove the shields covering the rod tubes on the bottom side of the engine to access the coolant head drain plugs. The bolt I am having difficultly with is the one connected to the exhaust header pipe. It appears to be rusted and seized. I have tried penetrating oil and heat but to no avail. I'm worried about rounding off the head of the bolt with the level of force I am having to apply to the bolt. Any tips, tricks, suggestions!
Thanks In Advance! |
Posted: Mon Feb 19, 2018 11:55 am Post subject: Re: Vanagon Engine Removal --n00b questions |
Don't know what your mean by heat, but getting it red hot with an Oxy-Act torch should do the trick. A nice red spot on one side of the nut, a couple of quick cranks of the ratchet, then make a new hot spot again if need be. |
Posted: Mon Feb 19, 2018 3:06 pm Post subject: Re: Vanagon Engine Removal --n00b questions |
I heated it with a small butane torch. Will that temp be high enough to do the trick? I didn't leave on long enough to form a cherry spot. I had read that too much heat will weaken the stud. Is that true? |
Posted: Mon Feb 19, 2018 3:45 pm Post subject: Re: Vanagon Engine Removal --n00b questions |
With enough heat from an Oxy-Act rig you can get a cherry red spot on the nut without getting that much heat into the stud. This really probably can not be done with a butane torch as the heat flow just isn't high enough.
When you do get the nut off use copper plated nuts when you go back together. If you could find brass nuts they would work fine as well. There are definite alloy exhaust nuts for newer rigs that would do great here too, but I can't suggest a source off hand, maybe Mercedes or BMW? |
