Which e brake cables to install `66 single cab with `62 trans
bastardbus
bastardbus is offline
PostPosted: Thu Oct 13, 2022 3:12 pm    Post subject: Which e brake cables to install `66 single cab with `62 trans Reply with quote
I have a beater 66 single cab I have been driving daily for close to 30 years now and I figure it is time to finally install some e brake cables.
So the bus is a `66 but it has a small nut `62 bus transmission. Which eBrake cables should I use and is there any mods that are needed?
Thanks
Samba Member #95
Who.Me?
Who.Me? is offline
PostPosted: Fri Oct 14, 2022 6:24 am    Post subject: Re: Which e brake cables to install `66 single cab with `62 trans Reply with quote
From the FAQs https://www.thesamba.com/vw/forum/viewtopic.php?t=222339
https://www.thesamba.com/vw/forum/viewtopic.php?t=427334
https://www.thesamba.com/vw/forum/viewtopic.php?t=188724
https://www.thesamba.com/vw/forum/viewtopic.php?t=404574
I've tried most of the methods described and so far the best and most reliable and user-friendly has been Glide King's solution with wire rope ferrules...
https://www.thesamba.com/vw/forum/viewtopic.php?p=7985754#7985754
Any decent wire rope swaging tool works. I used an IWISS swager designed for crimps from 1.2mm to 3.5mm with 3mm oval copper swages.
Andy
Looking for info on my truck's history. Are you from Campbell California or nearby. Do you recognise it? ... http://www.thesamba.com/vw/forum/viewtopic.php?t=636786
chrisflstf
chrisflstf is offline
PostPosted: Fri Oct 14, 2022 9:15 am    Post subject: Re: Which e brake cables to install `66 single cab with `62 trans Reply with quote
Assuming you have stock 62 bus brakes, and not a straight axle setup, stock 62 e brake cables will work
