Transmission ID help please
ARTDECODON
ARTDECODON is offline
PostPosted: Fri Mar 16, 2018 6:41 pm    Post subject: Transmission ID help please Reply with quote
I pick up what I think is a barn door early trans with reduction gears. It is complete gland nut to gland nut. Can someone help me ID for year??
EmpiGT
EmpiGT is offline
PostPosted: Fri Mar 16, 2018 7:25 pm    Post subject: Re: Transmission ID help please Reply with quote
That is not a barndoor trans. that is a big nut splitty trans. I'm sure someone can narrow down the year by the numbers, but it will be somewhere between 64-67
ARTDECODON
PostPosted: Fri Mar 16, 2018 7:46 pm    Post subject: Re: Transmission ID help please Reply with quote
What vehicle does a big nut splitty trans go to. Hell....never even heard of that. Smile
PostPosted: Fri Mar 16, 2018 9:38 pm    Post subject: Re: Transmission ID help please Reply with quote
Big Nut is named for the larger 46mm nut on the brakes.
Big nut transmissions are 1964-67
Your transmission also has the circle on there for the rear rubber bumpers, I believe this is mid-1965-67 but someone can correct me if that is wrong.
With rubber
Clara Premium Member
Clara is offline
PostPosted: Sat Mar 17, 2018 8:02 am    Post subject: Re: Transmission ID help please Reply with quote
It came new in a mid 65-mid 67 split bus. (I don't see a reverse light switch which would make it later 67)
Splitty= split bus = 67 & earlier VW bus
It can easily be bolted into a mid 59 through 67 bus.
To fit it in an earlier bus takes some nose cone mount mods.
There are some trannies in the classifieds now for $150:
https://www.thesamba.com/vw/classifieds/search.php...ds_time=90
It may be worth more if you are in Alberta, evidently.
ARTDECODON
PostPosted: Sat Mar 17, 2018 8:21 am    Post subject: Re: Transmission ID help please Reply with quote
Thanks so much.
BarryL Premium Member
BarryL is offline
PostPosted: Sat Mar 17, 2018 10:25 am    Post subject: Re: Transmission ID help please Reply with quote
Does it have an "H" in front of the serial numbers? Below the input shaft inside the bellhousing are some tiny circles like this.
Can you do a photo of those close up?
easy e
easy e is offline
PostPosted: Sat Mar 17, 2018 10:54 am    Post subject: Re: Transmission ID help please Reply with quote
What are in those circles again?... cast on - week, year, work shift?
aka: Evan
BarryL is offline
PostPosted: Sat Mar 17, 2018 11:14 am    Post subject: Re: Transmission ID help please Reply with quote
Cast on. They are upside down.
First circle: day of month.
Second circle: month.
Third circle first character: shift.
Third circle last character: year.
If his is a bus H serial number I'm going to guess late '65 early '66 ish.
ARTDECODON
PostPosted: Sat Mar 17, 2018 1:16 pm    Post subject: Re: Transmission ID help please Reply with quote
Hi...There is no Alpha code in front of the numerical numbers. I could not find any marking like described in the previous post. Only what I took the picture of...hopefully you can see what is stamped. This is what I think it says:
1
5s30
These look to be hand stamped.
BarryL is offline
PostPosted: Sat Mar 17, 2018 6:42 pm    Post subject: Re: Transmission ID help please Reply with quote
Look inside the opposite end of the big middle part below where the shaft with the splines on it goes inside. You're at the other end.
ARTDECODON
PostPosted: Sat Mar 17, 2018 7:17 pm    Post subject: Re: Transmission ID help please Reply with quote
Are you telling me to remove the nose cone? Could you send a pic that shows more of the tranny so I can get a reference point?
ARTDECODON
PostPosted: Sun Mar 18, 2018 4:36 am    Post subject: Re: Transmission ID help please Reply with quote
OK....I found the data. 24 9 15
RWK
RWK is offline
PostPosted: Sun Mar 18, 2018 6:44 am    Post subject: Re: Transmission ID help please Reply with quote
I have an H 0xxx I took it out of a 67 years ago, it was the original,
have a 5 something in my 62
73 Type 181
63 Type 113
63 Type 261- 428 071
62 Type 241-378 025 178 530
ARTDECODON
PostPosted: Sun Mar 18, 2018 6:47 am    Post subject: Re: Transmission ID help please Reply with quote
I wonder why this one does not have a Alpha code. Interesting.
RWK
RWK is offline
PostPosted: Sun Mar 18, 2018 6:55 am    Post subject: Re: Transmission ID help please Reply with quote
like the engines, they were all numbers for a while then the letter prefix.
as above posted probably 65-66? I posted about this before doesn't seem to be a list anywhere.
73 Type 181
63 Type 113
ARTDECODON
PostPosted: Sun Mar 18, 2018 6:59 am    Post subject: Re: Transmission ID help please Reply with quote
It is dated to 1965...I guess they got lazy or ran out of numbers. Thanks for you input it really helped.
BarryL is offline
PostPosted: Sun Mar 18, 2018 9:54 am    Post subject: Re: Transmission ID help please Reply with quote
Your center section is from a Beetle that has had the ring gear flipped to become a bus with reduction boxes. The reduction boxes reverse the axle rotation so in essence the third motion differential turns backwards to make the wheel stub axle turn forward. In a Beetle the axles would be straight to the wheels and turn forward already.
cru62
cru62 is offline
PostPosted: Sun Mar 18, 2018 1:57 pm    Post subject: Re: Transmission ID help please Reply with quote
I was under the impression that all the Tunnel-case castings were 113 xxx xxx because the case itself was the same. It is possible (and done frequently) to flip the R & P in a bus trans when doing a SAK.
"My biggest worry is that when I die, my wife will sell all my parts for what I told her I paid for them"-Jon
Jokes about German sausage are the wurst.
BarryL is offline
PostPosted: Sun Mar 18, 2018 6:48 pm    Post subject: Re: Transmission ID help please Reply with quote
Bus tunnel case would most likely have an H before the serial number.
