perello Samba Member
Joined: April 15, 2005 Posts: 830 Location: where social security comes for free
Posted: Mon Apr 23, 2018 12:15 am Post subject: 36hp okrasa on a bus, my first impressions |
Hi
As some of you may know, I did install a 36hp engine Okrasa engines in my recently restored bus.
The long-block was bought from Joe Ruiz and I completed the engine with parts I got from another okrasa engine. It has been converted to 12V using a porsche 90 mm generator. I kept an standard 36hp exhaust for a bus.
Only issue found so far is that I have a leak at the oil cooler seals. Already on my second set, I need to find good quality ones.
Is the first time I do have a double carburetor engine, and also the first time I drive a bus so I want to share in this thread my experiences with this combo ...
I must say, been driving a bug and a Thing all my life...the bus is a different beast . I need to get used to it yet.
As a first try I am using a 019 dizzy advanced to 10deg idle. The engine starts perfectly at first try and idles good. Although it has a smooth driving I see that is need time to rev up when I change gear. Seems it need the gas pedal to be really down.
However at low revs still shows good torque (helped by the RGB's?) and even in 4th gear can climb a slope.
I am sure it still need to run a lot more and see, I hope I learn how to tune it! _________________ Aug '58 pressed bumper SO23
1974 German Thing
1978 Bug 1200 |
fl59bug Samba Member
Joined: November 23, 2005 Posts: 1976 Location: North Carolina
Posted: Mon Apr 23, 2018 11:37 am Post subject: Re: 36hp okrasa on a bus, my first impressions |
Nice engine! I look forward to hearing more about it.
I have a 36hp "spare" engine with a new top end and one day want to get the Okrasa kit for it. I'm having too much fun though right now with my big bore 40hp which is currently installed.
I'm thinking that with the Okrasa dual port kit my 36 will run with, or even outrun the 40 when it comes time to swap.
Again, nice looking setup you have there. |
Braukuche Samba Member
Posted: Wed Apr 25, 2018 12:36 pm Post subject: Re: 36hp okrasa on a bus, my first impressions |
I ran a stroked 36 with dual stock carbs and stock crashbox in my '58 and could go 70 on flats easy and 60 up hill. You should not have to floor it to get revs up, maybe need to try an 010 that's what I ran. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now |
Posted: Fri Apr 27, 2018 12:07 am Post subject: Re: 36hp okrasa on a bus, my first impressions |
good. I installed a 010 and will try that. For some reason this one is set 90 degrees CCW compared to the 019....
1974 German Thing
1978 Bug 1200 |
hoss Samba Member
Joined: May 01, 2003 Posts: 788 Location: San Jose, CA
Posted: Fri Apr 27, 2018 10:52 pm Post subject: Re: 36hp okrasa on a bus, my first impressions |
What do you end up setting your timing at?
I have the same setup in my 58 bus
perello wrote: |
_________________ '54 Kombi | '57 356 Coupe | '57 Samba | '62 Notchback | '63 Beetle (36k Original Miles) | '66 Pigalle Sunroof Squareback | '70 Westy |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76955 Location: Sneaking up behind you
Posted: Sat Apr 28, 2018 1:54 am Post subject: Re: 36hp okrasa on a bus, my first impressions |
perello wrote: |
good. I installed a 010 and will try that. For some reason this one is set 90 degrees CCW compared to the 019.... |
It should not be. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Sat Apr 28, 2018 3:12 am Post subject: Re: 36hp okrasa on a bus, my first impressions |
hoss wrote: |
10deg@850rpm to start with
Glenn wrote: |
It should not be. |
What can be wrong? _________________ Aug '58 pressed bumper SO23
1974 German Thing
1978 Bug 1200 |
Glenn Mr. 010
Posted: Sat Apr 28, 2018 3:56 am Post subject: Re: 36hp okrasa on a bus, my first impressions |
perello wrote: |
Glenn wrote: |
It should not be. |
What can be wrong? |
Maybe soneone but a second mark on the edge of the body which you're assuming is the #1 mark.
The #1 mark on both the 010 and 019 is to CCW from the BOSCH name plate.
010
019
Member #1009
#BlueSquare |
Posted: Tue May 01, 2018 2:04 am Post subject: Re: 36hp okrasa on a bus, my first impressions |
Thanks Glenn
I did check number 1 mark. Found that when they both point #1 the bottom is different
1974 German Thing
1978 Bug 1200 |
Glenn Mr. 010
Posted: Tue May 01, 2018 4:35 am Post subject: Re: 36hp okrasa on a bus, my first impressions |
I have no explanation. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Wed May 02, 2018 6:43 am Post subject: Re: 36hp okrasa on a bus, my first impressions |
Glenn wrote: |
I have no explanation. |
hmm lets leave this as a mistery for now
Concerning my weak torque low-end, the change to 010 made just a minor difference.
What I tried now is to adjust the throttle fuel pump bolt. I gave it two full turns and this really improved the carb progression. I mean the bolt at the top side of this picture.
I am not sure about how to set this, and if it is really a good idea to play with it. But I keep experimenting. _________________ Aug '58 pressed bumper SO23
1974 German Thing
1978 Bug 1200 |
Posted: Mon May 14, 2018 12:18 am Post subject: Re: 36hp okrasa on a bus, my first impressions |
Some updates....
Found that I have a problem with the fuel valve, seems it only works good on reserve mode...but not in normal mode, the engine starts to choke. Need to check that.
Out of that, the engine seems to be getting smoother, and now I am more used to drive the bus....I am really enjoying it
I still miss an stronger low end with this engine, but might be that it needs to be run more. _________________ Aug '58 pressed bumper SO23
1974 German Thing
1978 Bug 1200 |
Peter_N Samba Member
Joined: February 19, 2014 Posts: 323 Location: The Netherlands
Posted: Wed May 16, 2018 6:43 am Post subject: Re: 36hp okrasa on a bus, my first impressions |
Hi Perello,
That's a great looking engine. Do you still run the splitcase gearbox and small nut RGB's?
I also have a stock '58 splitbus and I'm looking into options to get a bit more power. Especially since I want to add a simple interior to it. _________________ My 1958 PGSG project topic |
Posted: Wed May 16, 2018 7:06 am Post subject: Re: 36hp okrasa on a bus, my first impressions |
Peter_N wrote: |
Hi Perello,
I also have a stock '58 splitbus and I'm looking into options to get a bit more power. Especially since I want to add a simple interior to it. |
Yes, its a stock small nut RGB and split gearbox. Just don't expect a great increase on top speed, but it should improve low end torque...at least this is what I wanted. _________________ Aug '58 pressed bumper SO23
1974 German Thing
1978 Bug 1200 |
Posted: Fri May 18, 2018 6:17 am Post subject: Re: 36hp okrasa on a bus, my first impressions |
My bus (completely empty in the back) feels like it has enough torque in the first 3 gears actually.
I can fully imagine though how adding some weight eats a lot of that power.
Enjoy your new setup and please keep us updated
Cheers,
Peter _________________ My 1958 PGSG project topic |
Posted: Mon Jun 25, 2018 6:30 am Post subject: Re: 36hp okrasa on a bus, my first impressions |
some updates...
ride it for 200 miles...and still shows to be weak rev'ing up. A trick I tried is to slightly pump on the throttle, and that gave kind of an immediate boost.
I will open the mixture screw a little bit to see if that makes a any difference..will also check spark plugs to see if it goes lean as I suspect.
1974 German Thing
1978 Bug 1200 |
Posted: Fri Jul 20, 2018 2:05 am Post subject: Re: 36hp okrasa on a bus, my first impressions |
pulled out engine as, stupid me, I put the throttle tube backwards and was impossible to change it with engine in.
1974 German Thing
1978 Bug 1200 |
Posted: Mon Aug 20, 2018 6:25 am Post subject: Re: 36hp okrasa on a bus, my first impressions |
after a 300 miles trip I decided to pull out the engine and take alook to the oil cooler seals.
clearly I was using a 10 mm cooler on 8 mm engine, so those seals are not right. One of them was starting to break.
I ordered an aluminium cooler from CIP1 with the green 10 to 8 mm seals and will try that. _________________ Aug '58 pressed bumper SO23
1974 German Thing
1978 Bug 1200 |
Posted: Mon Aug 27, 2018 12:26 am Post subject: Re: 36hp okrasa on a bus, my first impressions |
new aluminium oil cooler from cip1 is in with the green adapter seals..lets see the outcome
1974 German Thing
1978 Bug 1200 |
txoval Samba Member
Joined: January 23, 2004 Posts: 3553 Location: The Woodlands, TX
Posted: Mon Aug 27, 2018 8:08 pm Post subject: Re: 36hp okrasa on a bus, my first impressions |
Green seals are the key...8 to 10mm
The others will leak like crazy |
