dwnghia Samba Member
Joined: January 02, 2018 Posts: 1 Location: Redondo Beach
Posted: Sun Jul 29, 2018 6:54 pm Post subject: Front blinker placement |
| I removed my larger blinkers on my 72 Ghia and am replacing them with the smaller blinker. Can someone tell me how many inches below the headlight the lights go? In inches? |
kiwighia68 Samba Member
Joined: October 20, 2013 Posts: 2953 Location: Auckland, New Zealand
Posted: Sun Jul 29, 2018 7:22 pm Post subject: Re: Front blinker placement |
The top screw hole (of the bullet type "blinker") is 1.5 inches below the headlight bucket, measured inside the wheel arch. The hole for the wiring is 3.5 inches below the headlight bucket also measured inside the wheel arch.
On my '68 Ghia.
Do you need a photo? _________________ Festina lente - hasten slowly
1968 Ghia named Emiko
Resto completed Dec 2015 |
Posted: Sun Jul 29, 2018 7:28 pm Post subject: Re: Front blinker placement |
The tape is a bit off-center in the photo and there's a bit of paralax error there, but the measurements are accurate. 1.5" and 3.5" respectively to the centres of the holes . _________________ Festina lente - hasten slowly
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32987 Location: Reading Pennsylvania
runamoc  Samba Member
Joined: June 19, 2006 Posts: 6488 Location: 37.5N 77.1W
Posted: Mon Jul 30, 2018 4:22 pm Post subject: Re: Front blinker placement |
| Quote: |
| 72 Ghia and am replacing them with the smaller blinker. |
Did the same for my '72. To keep the vertical straight with the headlight I taped a string inline with the fender ridge and weighted it with a nut. This helps keep the holes you will drill centered with the headlight center line. _________________ Daily driver: '69 Baja owned 45 yrs - Plan B: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs- '80 Rabbit Diesel
VW Wiring = It's just wires |
