Sodo Samba Member
Joined: July 06, 2007 Posts: 9623 Location: Western WA
Posted: Wed Aug 15, 2018 6:29 pm Post subject: Clutch dragging cant go into 1st (Morro Bay-broken disc springs) |
We are touring around while dropping off our daughter at Cal Poly SLO. Took a drive on Pismo beach and barely made it off (at the south entrance Pier Ave).
Clutch doesn’t release. So I had to put it in gear and get going with the starter motor, then shift with “emergency methods.
UPDATE: We made it back to our campsite reserved at Morro Strand Park (31 Miles from Pismo).
Just wanted to get a flag hoisted. Not sure what to do yet but the trans/clutch may need to come out.
I have a Smallcar bellhousing and new clutch. Clutch uses the concentric GTi throwout/slave. I bled it, no bubbles. Pedal feels “normal”.
We have several things to do in SLO involved with dropping my girl at college, then we need to drive back to Seattle, so this is kind of a big concern. We may have to rent a car. Would be really great if there are any nearby members with a driveway If I have to drop the trans.
Tom
cmayna Samba Member
Joined: August 18, 2014 Posts: 1148 Location: SF Bay area, CA
Posted: Wed Aug 15, 2018 7:33 pm Post subject: Re: Clutch problem at Morro Bay -anyone help? |
Tom,
Really wish I lived closer to Morro Bay (wife wants to retire and move there). Live 200 miles north, in Facebook land, Menlo Park, CA. Hopefully someone more locally will chime in. Keep us posted.
Craig _________________ '90 Westy / automatic.
If I'm not working on the camper or my '50 Chebbie truck, I'm either fishing with the wife or smoking Salmon.
Craig |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16508 Location: Brookeville, MD
Altoona Samba Member
Posted: Wed Aug 15, 2018 8:13 pm Post subject: Re: Clutch problem at Morro Bay -anyone help? |
Is it 281 or 271 |
owokie Samba Member
Posted: Wed Aug 15, 2018 8:18 pm Post subject: Re: Clutch problem at Morro Bay -anyone help? |
If you're intent on doing your own work, my brother has a carport he could probably lend for a few days. Tall enough to pop the top in, even.
On the other hand you might give Westywerks a call. Super nice guys and impressive shop. |
hdenter Samba Member
Joined: October 14, 2008 Posts: 2754 Location: San Luis Obispo, CA
Posted: Wed Aug 15, 2018 8:34 pm Post subject: Re: Clutch problem at Morro Bay -anyone help? |
I'm in the dirt so not much help with pulling the trans. Is there anything else you need? If you want to park it while you drive back in the rental and deal with it later, it could join the herd...
Hans _________________ '79 triple white convertible bug
'84 sunroof vanagon
'85 weekender |
Sodo Samba Member
Posted: Wed Aug 15, 2018 8:41 pm Post subject: Re: Clutch problem at Morro Bay -anyone help? |
Great offers, thanks. And http://www.westy-werks.com in SanLuis Obispo too. If it comes to that.
I have an offer of driveway space, ramps, tools by a Morro bay fella who’s gonna stop by the campsite and put a 2nd set of eyes on my problem.
At 9AM! This is true SAMBA! Very thankful! And my girls are thankful too. _________________
....KTMs, GasGas, SPOT mtb
cmayna Samba Member
Posted: Thu Aug 16, 2018 8:15 am Post subject: Re: Clutch problem at Morro Bay -anyone help? |
This is great news. Keep us posted. _________________ '90 Westy / automatic.
Craig |
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10254 Location: N. Idaho
Posted: Thu Aug 16, 2018 9:02 am Post subject: Re: Clutch problem at Morro Bay -anyone help? |
I no longer have a manual Syncro, but can you get one of the girls to depress the clutch pedal and see the clutch/flywheel through a gap in the bellhousing, or by removing an access plug? Or failing to get a visual through the gap, could you pick up the $70 Harbor Freight LCD remote camera/borescope and see if there is movement? If no movement, then the slave or clutch master is suspect and those are waaaaaay easier to replace.
Doug _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
Waldi Samba Member
Joined: February 28, 2014 Posts: 1752 Location: Germany
Posted: Thu Aug 16, 2018 9:09 am Post subject: Re: Clutch problem at Morro Bay -anyone help? |
No idea about Subi conversions, but if use the stock cluch shaft, did you weld it ?
Edit:
I mean the levers to the shaft. |
Sodo Samba Member
Posted: Thu Aug 16, 2018 12:16 pm Post subject: Re: Clutch problem at Morro Bay -anyone help? |
Yes it behaves exactly like the broken clutch fork. But it has the Smallcar GTi concentric slave/throwout. Current plan is to loosen the engine bolts and lever the trans forward and look into the gap. I’m disconnecting driveline and under-bars and (cough-cough) transaxle cooling monkey business...(cough) hope not to make an oil slick at the campsite.
Pic of #vanlife girls doing old-school Van yoga.
Note: they have the app so they threw dad under the bus & Uber’d outta here
Leveling the van for a special type of driveway campsite _________________
....KTMs, GasGas, SPOT mtb |
E1 Samba Member
Joined: January 21, 2013 Posts: 6590 Location: Westfalia, Earth
Posted: Thu Aug 16, 2018 1:14 pm Post subject: Re: Clutch problem at Morro Bay -anyone help? |
Westy Lesson #1259
Want happy kids? Break down more often!
Hence, Westy defines perfection once again!
Thanks for the update Bud, hope you're having as much as they are.
(suspect "not even close")
Hang in There! _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
jberger Samba Member
Sodo,
you will have to pull the transaxle back at least 2.5-3" to see behind.. and even that will be limited. Consider drilling a hole or two and using a scope to investigate. Or, if your spot is chill enough, just commit to dropping the transaxle and taking care of business. It's not that much more work.
Jason |
Sodo Samba Member
Posted: Thu Aug 16, 2018 1:41 pm Post subject: Re: Clutch problem at Morro Bay -anyone help? |
Hole.....
what about removing the starter and look inside with a scope?
See something? Drop the trans.
Can’t see anything? Then gotta drop the trans.
Doesn’t look like there’s any way around dropping the trans.
EXCEPT. If it’s air in the line and can be bled. But how do you get air in the line? Underbars are off, driveline off..... but I’ve half a mind to try bleeding again. _________________
E1 Samba Member
Posted: Thu Aug 16, 2018 2:09 pm Post subject: Re: Clutch problem at Morro Bay -anyone help? |
Sodo, we've also driven out to that Beach, and through deep sand when a line of trailers blocked the wet hardpack "route" about 3.5 miles in right as the tide came in.
Perhaps a long shot, but is there any way that sand got in somewhere and jammed anything?
I've never had this apart and so may be way off, but just a thought. Not a great mechanic on the big stuff here, but do wonder if the sand route could be connected...
Good Luck! _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
Sodo Samba Member
Posted: Thu Aug 16, 2018 2:31 pm Post subject: Re: Clutch problem at Morro Bay -anyone help? |
Jake de Villiers wrote: |
I see that your family is acquainted with the correct way to hold and operate basic garage tools - well done, Dad!!! |
The girls operated their Uber app, went to town & came back with the best and most reliable tool they could find (a rental Toyota)
Sand in the clutch would do exactly the problem I’m having (clutch dragging HARD). And the open Smallcar flywheel was my first thought (and Syncroshop and ejimmi) but we drove 15mph on packed wetted sand, there was no sand anywhere on anything. If sand were flying around it would be piled ontop of the skid bars. Not a grain.
AZ Landshaper Samba Member
Joined: February 08, 2009 Posts: 1698 Location: The Old Pueblo
Posted: Thu Aug 16, 2018 5:11 pm Post subject: Re: Clutch problem at Morro Bay -anyone help? |
Good luck man. Ive been on many a road trip where the engine was pulled to fix this r that. At least your peeps smiled for the picture. Thats a good sign. You didnt think they were gonna rent a VW did ya? _________________ Support Small Business.
85 Weekender w/ EJ22
Previously
64, 71, 72, 73, 76, 81, 84, 85 & 87 Campmobiles and Westfalias
and a 67 bug. |
E1 Samba Member
Posted: Thu Aug 16, 2018 5:18 pm Post subject: Re: Clutch problem at Morro Bay -anyone help? |
Dang it Sodo, you were s'posed to lie and say I nailed it.
Hope you don't mind a little humah, better coping mechanism than beer and no bad after effects.
Thanks for keeping us all updated, you'll get there.
(Please start the Toyota afire when fixed to get even with the Cosmos) _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
